查看: 5594|回復: 1
stm32f103控制迪文串口屏程序
ID:582775 發表于 2019-7-12 10:12 | 顯示全部樓層 |閱讀模式
迪文串口屏
stm32f103
  1. #include "stm32f10x.h"
  2. #include "sys.h"
  3. #include "delay.h"
  4. #include "usart.h"
  5. #include "beep.h"
  6. #include "led.h"
  7. #include "diwen.h"
  8. u8 pic[3]={0xaa,0x70,0x08};      //顯示第8幅圖片
  9. u8 wenben1[20]={0xaa,0x6f,0x00,0x08,0x00,0x0a,0x31,0x30,0x30,0x20,0x6d,0x6d,0x2f,0xb7,0xd6,0xd6,0xd3,0x20,0x20,0x20};
  10.                         //在x,y處顯示24*24漢字100 mm/分鐘   ;坐標8,10;
  11. u8 wenben2[20]={0xaa,0x6f,0x00,0x08,0x00,0x0a,0x20,0x39,0x30,0x30,0x20,0x6d,0x6d,0x2f,0xb7,0xd6,0xd6,0xd3,0x20,0x20};
  12.                           //在x,y處顯示24*24漢字 900 mm/分鐘   ;
  13. u8 color[6]={0xaa,0x40,0xf8,0x00,0x00,0x1f};  //設置當前調色板前景(紅)后景(藍)
  14. u8 clr[2]={0xaa,0x52};       //清屏
  15. u8 clr1[15]={0xaa,0x71,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0xef,0x00,0x00,0x00,0x00};
  16.                            //把第0幅圖的x,y、到x1,y1處粘貼到當前圖的x,y處
  17. u8 shuaxin[10]={0xaa,0x54,0x00,0x4b,0x00,0x7f,0x31,0x32,0x2e,0x34};
  18. int main(void)
  19. {
  20.         //u8 i,j;
  21.         delay_init();
  22.         BEEP_Init();
  23.         LED_Init();
  24.         beep_set(1);
  25.         uart_init(115200);
  26.         acklcd();               //發送握手指令,等待LCD就緒
  27.         color[5]=0x00;          //背景色設置為 黑 色;
  28.         send_str(color,6);
  29.         en();                  //發送設置調色板指令前景  紅,背景  黑;
  30.         delay_ms(500);
  31.         send_str(clr,2);       //清屏
  32.   en();
  33.
  34.           delay_ms(500);
  35.         pic[1]=0x70;
  36.                 pic[2]=18;
  37.   send_str(pic,3);
  38.         en();
  39.         color[2]=0x00;
  40.                 color[3]=0x1f;
  41.                 color[4]=0xff;
  42.                 color[5]=0xff;
  43.                 send_str(color,6);
  44.                 en();
  45.                 color[2]=0xf8;
  46.                 color[3]=0x00;
  47.                 color[4]=0x00;
  48.                 color[5]=0x1f;
  49.         while(1)
  50.         {
  51.     gongkong(0x4b,0x7f,1,2,3);         //(75,127)顯示
  52.                 gongkong(0xf5,0x7f,2,3,1);          //(245,127)顯示
  53.                 gongkong(0x4b,0xb9,3,2,1);          //(75,185)顯示
  54.                 gongkong(0xf5,0xb9,1,1,1);          //(245,185)顯示
  55.                 delay_ms(500);
  56.                 delay_ms(500);
  57.
  58.         }
  59. }
迪文試驗-工控.7z (185.41 KB, 下載次數: 143)
ID:822447 發表于 2020-10-14 21:19 | 顯示全部樓層
給樓主贊一個!剛需學習下
