查看: 2690|回復(fù): 0
stm32中斷產(chǎn)生ev1527編碼
ID:279326 發(fā)表于 2019-7-10 14:13 | 顯示全部樓層 |閱讀模式
利用tim3生成ev1527編碼(270K,1200us)
TIM3_PWM_Init(1199,71);        //分頻后1us,窄脈沖4LCK,寬脈沖12LCK,脈沖周期16LCK;同步周期128LCK(4LCK脈沖,124LCK空白);待生成脈沖周期為1200us
//通過改變TIM3->CCR2的值來改變占空比
#define LED0_PWM_DUTY TIM3->CCR2
#define PULSE_CODE    0xD2F672
unsigned int pulse_count=0;
void TIM3_PWM_Init(u16 arr,u16 psc)
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);  //①使能定時器 3時鐘
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|
RCC_APB2Periph_AFIO, ENABLE);            //①使能 GPIO AFIO 復(fù)用功能時鐘
GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3,ENABLE); //②重映射 TIM3_CH2->PB5
//設(shè)置該引腳為復(fù)用輸出功能,輸出 TIM3 CH2 PWM 脈沖波形 GPIOB.5
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_5;             //TIM_CH2
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP;    //復(fù)用推挽輸出
GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;
GPIO_Init(GPIOB,&GPIO_InitStructure);               //①初始化 GPIO
//初始化 TIM3
TIM_TimeBaseStructure.TIM_Period =arr;            //設(shè)置在自動重裝載周期值
TIM_TimeBaseStructure.TIM_Prescaler=psc;          //設(shè)置預(yù)分頻值
TIM_TimeBaseStructure.TIM_ClockDivision =0; //設(shè)置時鐘分割:TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode =TIM_CounterMode_Up; //TIM 向上計數(shù)模式
TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);   //③初始化 TIMx
//初始化 TIM3 Channel2 PWM模式
TIM_OCInitStructure.TIM_OCMode =TIM_OCMode_PWM1;     //選擇 PWM 模式 1
TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable; //比較輸出使能
TIM_OCInitStructure.TIM_OCPolarity =TIM_OCPolarity_High;  //輸出極性高
TIM_OCInitStructure.TIM_Pulse    = 1200;
TIM_OC2Init(TIM3,&TIM_OCInitStructure);                //④初始化外設(shè) TIM3 OC2
TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable);  //使能預(yù)裝載寄存器
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
         TIM_ClearFlag(TIM3,TIM_IT_Update);
TIM_ITConfig(TIM3,TIM_IT_Update, ENABLE);
TIM_Cmd(TIM3, ENABLE);                          //⑤使能 TIM3
void TIM3_IRQHandler(void)
if(TIM_GetITStatus(TIM3, TIM_IT_Update) == SET)
                   TIM_ClearITPendingBit(TIM3,TIM_IT_Update);
                   if(pulse_count<24)  //編碼部分
                            if(PULSE_CODE&(1<<(23-pulse_count))) //按位判斷PULSE_CODE的二進制從前面開始,如果當前位==1,寬脈沖900,==,窄脈沖300
                               LED0_PWM_DUTY = 900;
                               pulse_count++;
                                     LED0_PWM_DUTY= 300;
                               pulse_count++;
                   elseif(pulse_count == 24) //同步頭
                            LED0_PWM_DUTY= 300;
                            pulse_count++;
                   elseif(pulse_count<31) //同步低電平部分
                            LED0_PWM_DUTY= 0;
                            pulse_count++;
                            LED0_PWM_DUTY= 0;
                            pulse_count= 0;
參與人數(shù) 1黑幣 +50 收起 理由
