查看: 1866|回復: 0
stm32f10x 移植contiki源程序
ID:337456 發表于 2019-7-8 22:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
1.使用std庫
2.移植了contiki
3.運行兩個thread正常
  1. #include "contiki.h"
  2. unsigned int idle_count = 0;
  3. static struct etimer et_on;
  4. PROCESS(led_on, "led_on");
  5. PROCESS_THREAD(led_on, ev, data)
  6. {
  7.     static int on = 0;
  8.         PROCESS_BEGIN();
  9.         while(1)
  10.         {
  11.            on++;
  12.            etimer_set(&et_on, CLOCK_SECOND);              // etimer溢出時間為5s
  13.        PROCESS_WAIT_EVENT_UNTIL(etimer_expired(&et_on));  // 等待定時器溢出
  14.         }
  15.         PROCESS_END();
  16. }
  17. static struct etimer et_off;
  18. PROCESS(led_off, "led_off");
  19. PROCESS_THREAD(led_off, ev, data)
  20. {
  21.     static int off = 0;
  22.         PROCESS_BEGIN();
  23.         while(1)
  24.         {
  25.            off++;
  26.            etimer_set(&et_off, CLOCK_SECOND);              // etimer溢出時間為5s
  27.        PROCESS_WAIT_EVENT_UNTIL(etimer_expired(&et_off));  // 等待定時器溢出
  28.         }
  29.         PROCESS_END();
  30. }
  31. AUTOSTART_PROCESSES(&led_on,&led_off);
  32. int main(void*arg)
  33. {
  34.         clock_init();
  35.         process_init();
  36.         process_start(&etimer_process,NULL);
  37.         autostart_start(autostart_processes);
  38.         while(1){
  39.                 while(process_run()> 0);
  40.                 idle_count++;
  41.         }
  42. }
stm32-contiki-master.zip (350.96 KB, 下載次數: 11)
