查看: 2228|回復: 2
STM32利用L298N控制電機正反轉。
ID:575929 發表于 2019-7-8 18:08 | 顯示全部樓層 |閱讀模式
//main.c
#include "led.h"
#include "delay.h"
#include "sys.h"
int main(void)
        delay_init();                     //延時函數初始化
        LED_Init();             //初始化與LED連接的硬件接口
                GPIO_ResetBits(GPIOB,GPIO_Pin_5); //IN3輸出低
                GPIO_SetBits(GPIOB,GPIO_Pin_6);//IN4輸出高
                delay_ms(500);
                GPIO_ResetBits(GPIOB,GPIO_Pin_6);//IN4輸出低
                delay_ms(1000);
                GPIO_ResetBits(GPIOB,GPIO_Pin_6); //IN3輸出低
                GPIO_SetBits(GPIOB,GPIO_Pin_5);//IN4輸出高
                delay_ms(500);
//led.c
#include "led.h"
void LED_Init(void)
GPIO_InitTypeDef  GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);         //使能PB端口時鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;                                 //端口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度為50MHz
GPIO_Init(GPIOB, &GPIO_InitStructure);                                         //根據設定參數初始化GPIOB.0
GPIO_ResetBits(GPIOB,GPIO_Pin_5);                                                 //PB.5 輸出高
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;               //PB.6 端口配置
GPIO_ResetBits(GPIOB,GPIO_Pin_6);                             //PB.6輸出高
//led.h
#ifndef __LED_H
#define __LED_H
#include "sys.h"
void LED_Init(void);//初始化
#endif
ID:421308 發表于 2019-7-22 10:39 | 顯示全部樓層
不錯,學習
ID:588621 發表于 2019-8-2 18:27 來自觸屏版 | 顯示全部樓層
不是控制電機嗎怎么是燈呢
