單片機源程序如下:- #define MAIN_Fosc 22118400L //定義主時鐘
- #include "STC15Fxxxx.H"
- #include <string.h>
- #define Baudrate1 115200UL
- #define Baudrate2 115200UL
- bit B_TX1_Busy; //發(fā)送忙標志
- bit B_TX2_Busy; //發(fā)送忙標志
- void UART1_config(u8 brt); // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer1做波特率.
- void UART2_config(u8 brt); // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 無效.
- void PrintString1(u8 *puts);
- void PrintString2(u8 *puts);
- bit Haertbeat_Flag;
- bit Haertbeat_Detection;
- u8 Rec_Char;
- void PrintString_Text(u8 *puts);
- void wifi_Inti();
- void Delay10000ms() ;
- void Delay3000ms();
- void RH(void);
- void COM(void);
- void Delay18ms();
- void Delay_10us() ;
- void PrintString_Data(u8 *puts);
- void Up_temperature();
- void Up_humidity();
- //----------------定義區(qū)--------------------//
- u8 U8FLAG;
- u8 U8count,U8temp;
- u8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
- u8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
- u8 U8comdata;
- u8 disbuf_h[]={0,0};
- u8 disbuf_t[]={0,0};
- u8 code temperature_Data1[]={0X80,0X15,0X00,0X05,0X00,0X11,0X2C,0X3B,0X74,0X65,0X6D,0X70,0X65,0X72,0X61,0X74,0X75,0X72,0X65,0X20,0X2C,0xff};
- u8 code humidity_Data2[]={0X80,0X12,0X00,0X05,0X00,0X0E,0X2C,0X3B,0X68,0X75,0X6D,0X69,0X64,0X69,0X74,0X79,0X20,0X2C,0xff};
- u8 Rec_Char;
- u8 Rec_Num;
- u8 Com_Turn_Light ;
- void Fire_Detection();
- u8 code Fire[]={0X80,0X17,0X80,0X00,0X09,0X35,0X31,0X39,0X34,
- 0X33,0X37,0X32,0X38,0X35,0X05,0X00,0X08,0X2C,0X3B,0X66,0X69,0X72,0X65,0X2C,0X30,0xff};
- u8 Rec_Fax_Text[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- unsigned char code Heartbeat[]={0xC0,0x00,0xff};
- u8 code Connect_Com[]={0X10,0X32,0X00,0X03,0X45,0X44,0X50,0X01,0X40,0X01,0X2C,0X00,0X09,
- 0X35,0X31,0X38,0X39,0X38,0X38,0X32,0X37,0X31,0X00,0X1C,0X63,0X52,0X6E,0X67,0X4F,0X50,0X4B,
- 0X3D,0X33,0X6C,0X4D,0X65,0X78,0X32,0X41,0X75,0X45,0X69,0X32,0X41,0X37,0X63,0X6D,0X58,0X58,0X38,0X63,0X3D,0xff};
- u8 code Save_Data[]={0X80,0X63,0X00,0X01,0X00,0X5F,0X7B,0X0A,0X09,0X22,0X64,0X61,0X74,0X61,0X73,0X74,0X72,
- 0X65,0X61,0X6D,0X73,0X22,0X3A,0X09,0X5B,0X7B,0X0A,0X09,0X09,0X09,
- 0X22,0X69,0X64,0X22,0X3A,0X09,0X22,0X74,0X65,0X6D,0X70,0X65,0X72,0X61,0X74,0X75,
- 0X72,0X65,0X22,0X2C,0X0A,0X09,0X09,0X09,0X22,0X64,0X61,0X74,0X61,0X70,0X6F,0X69,0X6E, 0X74, 0X73,0X22,0X3A,
- 0X09,0X5B,0X7B,0X0A,0X09,0X09,0X09,0X09,0X09,0X22,0X76,0X61,0X6C,0X75,0X65,0X22,0X3A,0X09,0X38,0X30,
- 0X0A,0X09,0X09,0X09,0X09,0X7D,0X5D,0X0A,0X09,0X09,0X7D,0X5D,0X0A,0X7D,0xff};
- void Haertbeat_Response()
- unsigned char j;
- for(j=0;j<3;j++)
- PrintString_Text(Heartbeat);
- Delay3000ms();
- Delay3000ms();
- if( Haertbeat_Flag == 1)
- break;
- Haertbeat_Flag = 0;
- else
- wifi_Inti();
- Delay3000ms();
- PrintString_Text(Connect_Com);
- Delay3000ms();
- // 函數(shù): void main(void)
- // 描述: 主函數(shù)。
- // 參數(shù): none.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2014-11-28
- // 備注:
- int main(void)
- P0M1 = 0; P0M0 = 0; //設置為準雙向口
- P1M1 = 0; P1M0 = 0; //設置為準雙向口
- P2M1 = 0; P2M0 = 0; //設置為準雙向口
- P3M1 = 0; P3M0 = 0; //設置為準雙向口
- P4M1 = 0; P4M0 = 0; //設置為準雙向口
- P5M1 = 0; P5M0 = 0; //設置為準雙向口
- P6M1 = 0; P6M0 = 0; //設置為準雙向口
- P7M1 = 0; P7M0 = 0; //設置為準雙向口
- UART1_config(1); // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer1做波特率.
- UART2_config(2); // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 無效.
- EA = 1; //允許全局中斷
- wifi_Inti();
- // Delay10000ms();
- // PrintString_Text(Save_Data);
- Delay3000ms();
- while(1)
- Haertbeat_Response();
- Delay18ms();
- RH();
- Delay_10us() ;
- Up_temperature();
- Delay_10us() ;
- Up_humidity();
- Delay_10us() ;
- Fire_Detection();
- // 函數(shù): void PrintString1(u8 *puts)
- // 描述: 串口1發(fā)送字符串函數(shù)。
- // 參數(shù): puts: 字符串指針.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2014-11-28
- // 備注:
- for (; *puts != 0; puts++) //遇到停止符0結束
- SBUF = *puts;
- B_TX1_Busy = 1;
- while(B_TX1_Busy);
- // 函數(shù): void PrintString2(u8 *puts)
- // 描述: 串口2發(fā)送字符串函數(shù)。
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2014-11-28
- // 備注:
- for (;*puts != 0;puts++) //遇到停止符0結束
- S2BUF = *puts;
- B_TX2_Busy = 1;
- while(B_TX2_Busy);
- for (;*puts != 0xff;puts++) //遇到停止符0結束
- S2BUF = *puts;
- B_TX2_Busy = 1;
- S2BUF = *puts;
- B_TX2_Busy = 1;
- // 函數(shù): SetTimer2Baudraye(u16 dat)
- // 描述: 設置Timer2做波特率發(fā)生器。
- // 參數(shù): dat: Timer2的重裝值.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2014-11-28
- // 備注:
- void SetTimer2Baudraye(u16 dat)
- AUXR &= ~(1<<4); //Timer stop
- AUXR &= ~(1<<3); //Timer2 set As Timer
- AUXR |= (1<<2); //Timer2 set as 1T mode
- TH2 = dat / 256;
- TL2 = dat % 256;
- IE2 &= ~(1<<2); //禁止中斷
- AUXR |= (1<<4); //Timer run enable
- // 函數(shù): void UART1_config(u8 brt)
- // 描述: UART1初始化函數(shù)。
- // 參數(shù): brt: 選擇波特率, 2: 使用Timer2做波特率, 其它值: 使用Timer1做波特率.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2014-11-28
- // 備注:
- /*********** 波特率使用定時器2 *****************/
- if(brt == 2)
- AUXR |= 0x01; //S1 BRT Use Timer2;
- SetTimer2Baudraye(65536UL - (MAIN_Fosc / 4) / Baudrate1);
- /*********** 波特率使用定時器1 *****************/
- else
- TR1 = 0;
- AUXR &= ~0x01; //S1 BRT Use Timer1;
- AUXR |= (1<<6); //Timer1 set as 1T mode
- TMOD &= ~(1<<6); //Timer1 set As Timer
- TMOD &= ~0x30; //Timer1_16bitAutoReload;
- TH1 = (u8)((65536UL - (MAIN_Fosc / 4) / Baudrate1) / 256);
- TL1 = (u8)((65536UL - (MAIN_Fosc / 4) / Baudrate1) % 256);
- ET1 = 0; //禁止中斷
- INT_CLKO &= ~0x02; //不輸出時鐘
- TR1 = 1;
- SCON = (SCON & 0x3f) | 0x40; //UART1模式, 0x00: 同步移位輸出, 0x40: 8位數(shù)據(jù),可變波特率, 0x80: 9位數(shù)據(jù),固定波特率, 0xc0: 9位數(shù)據(jù),可變波特率
- // PS = 1; //高優(yōu)先級中斷
- ES = 1; //允許中斷
- REN = 1; //允許接收
- P_SW1 &= 0x3f;
- //P_SW1 |= 0x00;
- //P_SW1 |= 0x80; //UART1 switch to, 0x00: P3.0 P3.1, 0x40: P3.6 P3.7, 0x80: P1.6 P1.7 (必須使用內(nèi)部時鐘)
- // PCON2 |= (1<<4); //內(nèi)部短路RXD與TXD, 做中繼, ENABLE,DISABLE
- B_TX1_Busy = 0;
- // 函數(shù): void UART2_config(u8 brt)
- // 描述: UART2初始化函數(shù)。
- // 參數(shù): brt: 選擇波特率, 2: 使用Timer2做波特率, 其它值: 無效.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2014-11-28
- // 備注:
- void UART2_config(u8 brt) // 選擇波特率, 2: 使用Timer2做波特率, 其它值: 無效.
- if(brt == 2)
- SetTimer2Baudraye(65536UL - (MAIN_Fosc / 4) / Baudrate2);
- S2CON &= ~(1<<7); // 8位數(shù)據(jù), 1位起始位, 1位停止位, 無校驗
- IE2 |= 1; //允許中斷
- S2CON |= (1<<4); //允許接收
- P_SW2 &= ~0x01;
- //P_SW2 |= 1; //UART2 switch to: 0: P1.0 P1.1, 1: P4.6 P4.7
- B_TX2_Busy = 0;
- // 函數(shù): void UART1_int (void) interrupt UART1_VECTOR
- // 描述: UART1中斷函數(shù)。
- // 參數(shù): nine.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2014-11-28
- // 備注:
- void UART1_int (void) interrupt UART1_VECTOR
- if(RI)
- RI = 0;
- if(TI)
- TI = 0;
- B_TX1_Busy = 0;
- // 函數(shù): void UART2_int (void) interrupt UART2_VECTOR
- // 描述: UART2中斷函數(shù)。
- // 參數(shù): nine.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2014-11-28
- // 備注:
- void UART2_int (void) interrupt UART2_VECTOR
- if((S2CON & 1) != 0)
- S2CON &= ~1; //Clear Rx flag
- Rec_Char = S2BUF;
- SBUF = Rec_Char;
- //SBUF = S2BUF;
- if(Rec_Char == 0xD0)
- Haertbeat_Detection = 1;
- else
- if ((Rec_Char == 0x00) && (Haertbeat_Detection == 1))
- Haertbeat_Flag=1;
- else
- Haertbeat_Detection = 0;
- Rec_Fax_Text[Rec_Num] = Rec_Char;
- if (Rec_Char=='{')
- Com_Turn_Light = 1;
- if (Com_Turn_Light == 1)
- if (Rec_Fax_Text[Rec_Num] == '}')
- Com_Turn_Light = 0;
- Rec_Num=0;
- if(strstr((const char*)Rec_Fax_Text,"LED01")!=null)
- P00 = 0;
- else
- if (strstr((const char*)Rec_Fax_Text,"LED00")!=null)
- P00 = 1;
- else Rec_Num++;
- if((S2CON & 2) !=0)
- S2CON &= ~2; //Clear Tx flag
- B_TX2_Busy = 0;
- // 函數(shù):
- // 備注:
- void wifi_Inti()
- PrintString2("+++");
- Delay10000ms();
- Delay10000ms();
- PrintString2("AT\r\n");
- Delay10000ms();
- PrintString2("AT+CWMODE=3\r\n");
- Delay10000ms();
- PrintString2("AT+RST\r\n");
- Delay10000ms();
- PrintString2("AT+CWJAP=\"TP-LINK_F00D\",\"hygcx807\"\r\n");
- //PrintString2("AT+CWJAP=\"QQ_MI\",\"12345678\"\r\n");
- // PrintString2("AT+CWJAP=\"iPhoneSE\",\"12345678\"\r\n");
- Delay10000ms();
- Delay10000ms();
- Delay10000ms();
- Delay10000ms();
- Delay10000ms();
- Delay10000ms();
- PrintString2("AT+CIPSTART=\"TCP\",\"183.230.40.39\",876\r\n");
- Delay10000ms();
- Delay10000ms();
- PrintString2("AT+CIPMODE=1\r\n");
- Delay10000ms();
- PrintString2("AT+CIPSEND\r\n");
- Delay10000ms();
- // 函數(shù):
- // 備注:
- void Delay10000ms() //@11.0592MHz
- unsigned char i, j, k;
- _nop_();
- _nop_();
- i = 165;
- j = 59;
- k = 28;
- do
- do
- while (--k);
- } while (--j);
- } while (--i);
- void Delay3000ms() //@11.0592MHz
- _nop_();
- _nop_();
- i = 127;
- j = 18;
- k = 107;
- do
- do
- while (--k);
- } while (--j);
- } while (--i);
- void Delay_10us() //@22.1184MHz
- unsigned char i;
- _nop_();
- _nop_();
- _nop_();
- i = 52;
- while (--i);
- void Delay18ms() //@22.1184MHz
- _nop_();
- i = 2;
- j = 132;
- k = 67;
- do
- do
- while (--k);
- } while (--j);
- } while (--i);
- // 函數(shù):
- // 備注:
- void COM(void)
- u8 i;
- for(i=0;i<8;i++)
- U8FLAG=2;
- while((!P20)&&U8FLAG++);
- Delay_10us();
- Delay_10us();
- Delay_10us();
- U8temp=0;
- if(P20)U8temp=1;
- U8FLAG=2;
- while((P20)&&U8FLAG++);
- //超時則跳出for循環(huán)
- if(U8FLAG==1)break;
- //判斷數(shù)據(jù)位是0還是1
- //如果高電平高過預定0高電平值則數(shù)據(jù)位為 1
- U8comdata<<=1;
- U8comdata|=U8temp; //0
- }//rofc
- // 函數(shù):
- // 備注:
- void RH(void)
- //主機拉低18ms
- P20=0;
- Delay18ms();
- P20=1;
- //總線由上拉電阻拉高 主機延時20us
- Delay_10us();
- Delay_10us();
- Delay_10us();
- Delay_10us();
- //主機設為輸入 判斷從機響應信號
- P20=1;
- //判斷從機是否有低電平響應信號 如不響應則跳出,響應則向下運行
- if(!P20) //T !
- U8FLAG=2;
- //判斷從機是否發(fā)出 80us 的低電平響應信號是否結束
- U8FLAG=2;
- //判斷從機是否發(fā)出 80us 的高電平,如發(fā)出則進入數(shù)據(jù)接收狀態(tài)
- //數(shù)據(jù)接收狀態(tài)
- COM();
- U8RH_data_H_temp=U8comdata;
- COM();
- U8RH_data_L_temp=U8comdata;
- COM();
- U8T_data_H_temp=U8comdata;
- COM();
- U8T_data_L_temp=U8comdata;
- COM();
- U8checkdata_temp=U8comdata;
- P20=1;
- //數(shù)據(jù)校驗
- U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
- if(U8temp==U8checkdata_temp)
- U8RH_data_H=U8RH_data_H_temp;
- U8RH_data_L=U8RH_data_L_temp;
- U8T_data_H=U8T_data_H_temp;
- U8T_data_L=U8T_data_L_temp;
- U8checkdata=U8checkdata_temp;
- disbuf_h[0]=U8RH_data_H/10+0x30;
- disbuf_h[1]=U8RH_data_H%10+0x30;
- disbuf_t[0]=U8T_data_H/10+0x30;
- disbuf_t[1]=U8T_data_H%10+0x30;
- }//fi
- }//fi
- // 函數(shù):
- // 備注: (u8 *puts)
- u8 i;
- PrintString_Data(humidity_Data2);
- for (i=0;i<2;i++)
- S2BUF=disbuf_h[i];
- B_TX2_Busy = 1;
- // 函數(shù):
- // 備注: (u8 *puts)
- u8 i;
- PrintString_Data(temperature_Data1);
- for (i=0;i<2;i++)
- S2BUF=disbuf_t[i];
- B_TX2_Busy = 1;
- if(P21==0)
- Delay18ms();
- Delay18ms();
- Delay18ms();
- if(P21==0)
- PrintString2(Fire);
全部程序51hei下載地址:
C語言.zip
(96.9 KB, 下載次數(shù): 7)
2019-7-7 16:37 上傳
下載積分: 黑幣 -5
