查看: 2703|回復: 0
藍牙點燈最簡單的做法 STC15f2k60s2單片機程序
ID:535575 發表于 2019-7-7 16:35 | 顯示全部樓層 |閱讀模式
  1. #include<stc15f2k60s2.h>
  2. sbit LED0=P0^0;
  3. sbit LED1=P0^1;
  4. sbit LED2=P0^2;
  5. sbit LED3=P0^3;
  6. sbit LED4=P0^4;
  7. sbit LED5=P0^5;
  8. sbit LED6=P0^6;
  9. sbit LED7=P0^7;
  10. unsigned char key=255;
  11. void UartInit(void)                //9600bps@11.0592MHz
  12. {
  13.         SCON = 0x50;                //8位數據,可變波特率
  14.         AUXR |= 0x01;                //串口1選擇定時器2為波特率發生器
  15.         AUXR |= 0x04;                //定時器2時鐘為Fosc,即1T
  16.         T2L = 0xE0;                //設定定時初值
  17.         T2H = 0xFE;                //設定定時初值
  18.         AUXR |= 0x10;                //啟動定時器2
  19. }
  20. void tongxin() interrupt 4
  21. {
  22. if(RI==1)
  23. {
  24.    key=SBUF;
  25.    SBUF=key;
  26.    RI=0;
  27. }
  28. else if(TI==1)
  29. {
  30.   TI=0;
  31. }
  32.
  33. }
  34. void main()
  35. {
  36.   EA=1;
  37.   ES=1;
  38.   UartInit();
  39.   while(1)
  40.   {
  41.           switch(key)
  42.           {
  43.             case 00:LED0=0;key=255;break;
  44.             case 01:LED0=1;key=255;break;
  45.                 case 10:LED1=0;key=255;break;
  46.             case 11:LED1=1;key=255;break;
  47.                 case 20:LED2=0;key=255;break;
  48.             case 21:LED2=1;key=255;break;
  49.                 case 30:LED3=0;key=255;break;
  50.             case 31:LED3=1;key=255;break;
  51.                 case 40:LED4=0;key=255;break;
  52.             case 41:LED4=1;key=255;break;
  53.                 case 50:LED5=0;key=255;break;
  54.             case 51:LED5=1;key=255;break;
  55.                 case 60:LED6=0;key=255;break;
  56.             case 61:LED6=1;key=255;break;
  57.                 case 70:LED7=0;key=255;break;
  58.             case 71:LED7=1;key=255;break;
  59.
  60.           }
  61.
  62.   }
  63. }
藍牙控制小燈.rar (10.39 KB, 下載次數: 25)
