- #include <stc12c5a60s2.h>
- #include <intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define MAX_Delay 8
- #define MIN_Delay 1
- sbit S_1 = P1 ^ 1;
- sbit S_2 = P1 ^ 2;
- unsigned int pwm;
- unsigned char TimeDelay = 10;
- unsigned char Mode = 1;
- unsigned char code tabP2[]={0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F}; //掃描
- uchar s=0;
- void DELAY_MS (uchar i){
- // unsigned int i;
- // while( --a != 0){
- // for(i = 0; i < 600; i++);
- uchar x,j;
- for(j=0;j<i;j++)
- for(x=0;x<=148;x++);
- void Adc_Delay (uint a){
- uint i;
- while( --a != 0){
- for(i = 0; i < 600; i++);
- void Delay(uint z)
- uint x,y;
- for(x=80;x>0;x--)
- for(y=z;y>0;y--);
- void timer1_init()
- TMOD |= 0x10;
- TH1 = 0;
- TL1 = 0;
- ET1 = 1;
- TR1 = 1;
- EA = 1;
- ********************** AD轉(zhuǎn)換函數(shù) **************/
- unsigned char Read (unsigned char CHA)
- unsigned char AD_FIN=0; //存儲(chǔ)A/D轉(zhuǎn)換標(biāo)志
- CHA &= 0x07; //選擇ADC的8個(gè)接口中的一個(gè)(0000 0111 清0高5位)
- ADC_CONTR = 0x00; //ADC轉(zhuǎn)換的速度(0XX0 0000 其中XX控制速度,請(qǐng)根據(jù)數(shù)據(jù)手冊(cè)設(shè)置)
- _nop_();
- ADC_CONTR |= CHA; //選擇A/D當(dāng)前通道
- _nop_();
- ADC_CONTR |= 0x80; //啟動(dòng)A/D電源
- Adc_Delay(1); //使輸入電壓達(dá)到穩(wěn)定(1ms即可)
- ADC_CONTR |= 0x08; //啟動(dòng)A/D轉(zhuǎn)換(0000 1000 令A(yù)DCS = 1)
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- while (AD_FIN ==0)
- { //等待A/D轉(zhuǎn)換結(jié)束
- AD_FIN = (ADC_CONTR & 0x10); //0001 0000測(cè)試A/D轉(zhuǎn)換結(jié)束否
- ADC_CONTR &= 0xE7; //1111 0111 清ADC_FLAG位, 關(guān)閉A/D轉(zhuǎn)換,
- return (ADC_RES); //返回A/D轉(zhuǎn)換結(jié)果(8位)
- ************* AD電容式觸摸按鍵檢測(cè)程序 ******************/
- //bit 1表示有感應(yīng)物,0表示沒有感應(yīng)物 S1
- bit S1(void)
- unsigned char R,mm=0,i,j,k;
- bit aa;
- j=0;k=0;
- for(i=0;i<10;i++)
- { //一次采集數(shù)據(jù)的數(shù)量
- Adc_Delay(3);
- R=Read(1); //讀對(duì)應(yīng)的口,觸發(fā)對(duì)應(yīng)的觸摸按鍵
- if(R<0x2f)
- { //此參數(shù)可調(diào)整感應(yīng)靈敏度值在0x01到0x2F
- k++;
- if(R == 0xFF)
- j++;
- if(k>1 && j>1)
- mm++;
- else
- mm=0;
- if(mm>0)
- aa =1;
- else
- aa=0;
- return(aa);
- // S2
- bit S2(void)
- bit aa;
- j=0;k=0;
- for(i=0;i<10;i++)
- Adc_Delay(3);
- R=Read(2);
- if(R<0x2F)
- k++;
- if(R == 0xFF)
- j++;
- if(k>1 && j>1)
- mm++;
- else
- mm=0;
- if(mm>0)
- aa =1;
- else
- aa=0;
- return(aa);
- //結(jié)束呼吸燈專用
- uchar code table[]={
- 0,0,1,2,3,4,5,6,7,8,9,10,
- 11,12,13,14,15,16,17,18,
- 19,20,21,22,23,24,25,26,27,
- 28,29,30,31,32,33,34,35,36,
- 37,38,39,40,41,42,43,44,45,
- 46,47,48,49,50,51,52,53,54,
- 55,56,57,58,59,60,61,62,63,
- 64,65,66,67,68,69,70,71,72,
- 73,74,75,76,77,78,79,80,81,82,
- 83,84,85,86,87,88,89,90,91,
- 92,93,94,95,96,97,98,99,100,101,102,103,104,105,106,107,108,109,
- 110,111,112,113,114,115,116,117,118,119,120,121,122,123,124,125,126,127,128,129,130,131,132,133,134,135,136,137,138,139,140,141,142,143,144,145,146,147,148,149,150,
- void PwmUp(uint a, uchar c)
- uchar i;
- if(c == 1)
- P3 = 0X00;
- else
- P0 = 0X00;
- P2 = 0X00;
- i = table[a];
- Delay(i);
- if(c == 1)
- P3 = 0XFF;
- else
- P0 = 0XFF;
- P2 = 0X00;
- Delay(150-i);
- void PwmDown(uint a,uchar c)
- uchar i;
- if(c == 1)
- P3 = 0XFF;
- else
- P0 = 0XFF;
- P2 = 0X00;
- i = table[a];
- Delay(i);
- if(c == 1)
- P3 = 0X00;
- else
- P0 = 0X00;
- P2 = 0X00;
- Delay(150-i);
- void PwmAllon(uchar c)
- int i;
- for(i = 0; i < 150 ;i++)
- PwmDown(i,c);
- if(c == 1)
- P3 = 0X00;
- else
- P0 = 0X00;
- P2 = 0X00;
- void PwmOff(uchar c)
- int i;
- // P3 = 0XFF;
- // P2 = 0X00;
- // Delay(100);
- for(i = 0; i < 150; i++)
- PwmUp(i,c);
- //P3 = 0X00;
- void Allfalloff(uchar c,uchar time) //由全亮到下落關(guān)閉只剩一排
- unsigned char code tabP0[5][8]={
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
- {0x00,0xFF,0xFF,0xFF,0x00,0xFF,0xFF,0xFF},
- {0x00,0x00,0xFF,0xFF,0x00,0x00,0xFF,0xFF},
- {0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0xFF},
- {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
- int j,k,i;
- if(c==1)
- P3 = 0X00;
- else if(c==2)
- P0 = 0X00;
- else
- P3 = 0XFF;
- P0 = 0XFF;
- for(j=0;j<5;j++)
- for(k=0;k<15;k++)
- for(i=0;i<8;i++)
- // P0=0;
- P2=tabP2[i];
- if(c == 1)
- P0=tabP0[j][i];
- else if(c == 2)
- P3 = tabP0[j][i];
- else
- P0=tabP0[j][i];
- DELAY_MS(time);
復(fù)制代碼 |
彩色光立方4源程序.zip
2019-7-7 16:19 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
112.14 KB, 下載次數(shù): 6, 下載積分: 黑幣 -5
