只需一步,快速開(kāi)始
查看: 5637|回復(fù): 6
STM32F103C8T6藍(lán)牙動(dòng)感音箱源程序
ID:387744 發(fā)表于 2019-7-7 16:16 | 顯示全部樓層 |閱讀模式
單片機(jī)源程序如下:
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "stm32f10x.h"
  4. #include "lcd.h"
  5. #include "usart.h"
  6. #include "adc.h"
  7. extern __IO uint16_t ADC_Value;
  8. // 局部變量,用于保存轉(zhuǎn)換計(jì)算后的電壓值
  9. float ADC_ValueLocal=0;
  10. int ValueLocal=0;
  11. int main(void)
  12. {
  13.    int i;
  14.          SystemInit ();
  15.         delay_init();                     //延時(shí)函數(shù)初始化
  16.         USART_Config(115200);         //串口初始化為115200
  17.          LED_Init();                  //LED端口初始化
  18.          Adc_Init();                                  //ADC初始化
  19. //        TIM3_PWM_Init(899,0);         //不分頻。PWM頻率=72000000/900=80Khz
  20.         //         KEY_Init();
  21.         while (1)
  22.         {
  23.                 for(i=0;i<50;i++)
  24.                 {
  25.                 ADC_ValueLocal =(float) ADC_Value/4096*5+ADC_ValueLocal;
  26.                 }
  27.                 ADC_ValueLocal=ADC_ValueLocal/50;
  28.                 printf("\r\n The current ADC_ValueLocal = %f V \r\n",ADC_ValueLocal);
  29.         if(ADC_ValueLocal<=1.7&&ADC_ValueLocal>1.4)
  30.         {
  31.                   ValueLocal=0;
  32.         }else if(ADC_ValueLocal<=2.0&&ADC_ValueLocal>1.7)
  33.         {
  34.             ValueLocal=1;
  35.         }else if(ADC_ValueLocal<=2.4&&ADC_ValueLocal>2.0)
  36.         {
  37.             ValueLocal=2;
  38.         }else if(ADC_ValueLocal<=2.8&&ADC_ValueLocal>2.4)
  39.         {
  40.             ValueLocal=3;
  41.         }
  42.         else if(ADC_ValueLocal<=3.3&&ADC_ValueLocal>2.8)
  43.         {
  44.             ValueLocal=4;
  45.         }else if(ADC_ValueLocal<=3.6&&ADC_ValueLocal>3.3)
  46.         {
  47.             ValueLocal=5;
  48.         }else if(ADC_ValueLocal<=4&&ADC_ValueLocal>3.6)
  49.         {
  50.             ValueLocal=6;
  51.         }else if(ADC_ValueLocal<=5&&ADC_ValueLocal>4)
  52.         {
  53.             ValueLocal=7;
  54.         }else ValueLocal=8;
  55.         switch(ValueLocal)
  56.                         {
  57.         case 0:
  58.                                               LED0=1;LED1=LED2=LED3=LED4=LED5=LED6=LED7=0;break;
  59.                                  case 1:
  60.                                               LED1=1;LED0=1; LED2=LED3=LED4=LED5=LED6=LED7=0;break;
  61.                                   case 2:
  62.                                               LED2=1; LED1=1;LED0=1;LED3=LED4=LED5=LED6=LED7=0;break;
  63.                                          case 3:
  64.                                               LED3=1; LED2=1; LED1=1;LED0=1;LED4=LED5=LED6=LED7=0; break;
  65.                                           case 4:
  66.                                               LED4=1;LED3=1; LED2=1; LED1=1;LED0=1;LED5=LED6=LED7=0;break;
  67.                                                  case 5:
  68.                                               LED5=1;LED4=1;LED3=1; LED2=1; LED1=1;LED0=1;LED6=LED7=0;break;
  69.                                                   case 6:
  70.                                               LED6=1;LED5=1;LED4=1;LED3=1; LED2=1; LED1=1;LED0=1;LED7=0;break;
  71.                                                          case 7:
  72.                                               LED7=1; LED6=1;LED5=1;LED4=1;LED3=1; LED2=1; LED1=1;LED0=1;break;
  73.                                                         case 8:
  74.        LED0=LED1=LED2=LED3=LED4=LED5=LED6=LED7=0;break;
  75.                         }
  76.
  77.         }
  78.         }
所有程序51hei提供下載:
STM32F103C8T6藍(lán)牙音箱.7z (219.12 KB, 下載次數(shù): 70)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
ID:328014 發(fā)表于 2019-7-7 22:22 | 顯示全部樓層
好東東 樓主能分享或者說(shuō)明點(diǎn)電路圖嗎?
ID:579837 發(fā)表于 2019-7-8 11:25 | 顯示全部樓層
可以可以,好東西
ID:246618 發(fā)表于 2021-4-29 10:34 | 顯示全部樓層
有PCB我自己也弄一個(gè)
ID:246618 發(fā)表于 2021-4-29 10:35 | 顯示全部樓層
能分享PCB不
無(wú)效樓層,該帖已經(jīng)被刪除
ID:1097630 發(fā)表于 2023-10-30 09:12 | 顯示全部樓層
只有程序,沒(méi)有電路圖?
ID:766282 發(fā)表于 2024-3-23 11:13 來(lái)自觸屏版 | 顯示全部樓層
有原理圖分享一下就好了
