查看: 2398|回復: 1
這個單片機程序能不能用藍牙控制步進電機?求幫助
ID:578680 發表于 2019-7-7 00:23 來自觸屏版 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
50黑幣
//上電時電機啟動,加減檔位,電機采用單雙八拍方式
//電機轉速一共10檔,通過按鍵調節轉速
#include<reg51.h>
#include <intrins.h>
#include <math.h>
uchar receive=0;
uchar send=0xff;
sbit out1=P3^0;
sbit out2=P3^1;
sbit out3=P3^2;
sbit s1 = P1^0;
sbit s2 = P1^1;
//按鍵定義,s1正轉,s2反轉,s3加1,s4減1
sbit a = P2^7;sbit b = P2^6;sbit c = P2^5;sbit d = P2^4;//脈沖信號輸入端定義
uchar code time_counter[10][2]={{0xda,0x1c},{0xde,0xe4},{0xe1,0xec},{0xe5,0xd4},{0xe9,0xbc},  //9.7 ----1ms
                                                            {0xed,0xa4},{0xf1,0x8c},{0xf5,0x74},{0xf9,0x5c},{0xfc,0x18}};
uchar num1 = 0;//控制取勵磁信號變量
uchar num2 = 8;
char k=0;//加減檔位控制,1為最小檔
char pause=1;//暫停時保存之前的轉速,開機默認1
bit flag1 = 0;//初始正轉,正反轉標志
//================================定時器0/1初始化函數================================
void T0_T1_init()
        TMOD = 0x11;//定時器0/1均工作于方式1,16位計時方式
           TH1 = time_counter[k-1][0];
        TL1 = time_counter[k-1][1];//定時器1,定時10ms用于步進電機轉速控制
        TR1 = 0;
        ET1= 1;//開定時器中斷
        EA = 1;//開總中斷
//================================ms級延時函數=======================================
void delay1m(uint x)
    uint i,j;
    for(i=0;i<x;i++)      //連數x次,約 x ms
             for(j=0;j<120;j++);   //數120 次,約1 ms
void Com_Init(void)
     TMOD = 0x20;
     PCON = 0x00;
     SCON = 0x50;
     TH1 = 0xfd;    //設置波特率 9600
     TL1 = 0xfd;
     TR1 = 1;                //啟動定時器1
         ES = 1;                //開串口中斷
         EA = 1;                //開總中斷
//開關操作函數,接收到一次數據改變一次狀態
void alloff()
        P1=0xff;
void Delay_1ms(uint i)//1ms延時
        uchar x,j;
        for(j=0;j<i;j++)
        for(x=0;x<=148;x++);
//================================主函數=============================================
         Delay_1ms(100);
        Com_Init();//串口初始化
  while (1)
                T0_T1_init();
        a=b=c=d=0;
                if(s1 == 0)
                        delay1m(3);
                        if(s1 == 0)
                                flag1 = 0;//正轉
                        while(!s1);
                if(s2 == 0 )
                        delay1m(3);
                        if(s2 == 0)
                                flag1 = 1;//反轉
                        while(!s2);
                if(out1 == 0)           //速度加1檔
                        delay1m(3);
                        if(out1 == 0)
                                k++;
                                TR1=1;
                                if(k > 10 )
                                        k = 1;
                        while(!out1);
                if(out2 == 0)         //速度減1檔
                        delay1m(3);
                        if(out2 == 0)
                                k--;
                                TR1=1;
                                if(k <= 0)
                                        k = 10;
                        while(!out2);
                if(out3==0)
                        delay1m(3);
                        if(out3==0)
                                if(TR1==1)
                                        pause=k;
                                        k=0;
                                        TR1=0;
                                        a=b=c=d=0;
                                else if(TR1==0)
                                        k=pause;
                                        TR1=1;
                                while(!out3);
void Com_Int(void) interrupt 4
        EA = 0;
        if(RI == 1)   //當硬件接收到一個數據時,RI會置位
                receive = SBUF ; //
                RI = 0;
                switch (receive)
                        case 0x00: alloff();break;
                        case 0x10: out1=1;break;
                        case 0x11: out1=0;break;
                        case 0x20: out2=1;break;
                        case 0x21: out2=0;break;
                        case 0x30: out3=1;break;
                        case 0x31: out3=0;break;
                        default:break;
        EA = 1;
//==================================定時器1中斷函數,用于脈沖頻率控制=====================================
void time1_interrupt()interrupt 3
        static num1 = 0;
        static num2 = 0;
        TL1 = time_counter[k-1][1];//定時器1,定時1 用于步進電機轉速控制
        if(flag1 == 0)//正轉
                switch(num1)
                        case 0:a = 1;b = 0;c = 0;d = 0;break;
                        case 1:a = 1;b = 1;c = 0;d = 0;break;
                        case 2:a = 0;b = 1;c = 0;d = 0;break;
                        case 3:a = 0;b = 1;c = 1;d = 0;break;
                        case 4:a = 0;b = 0;c = 1;d = 0;break;
                        case 5:a = 0;b = 0;c = 1;d = 1;break;
                        case 6:a = 0;b = 0;c = 0;d = 1;break;
                        case 7:a = 1;b = 0;c = 0;d = 1;break;
                num1++;
                if(num1 == 8)num1 = 0;
        else                  //反轉
                switch(num2)
                        case 0:a = 1;b = 0;c = 0;d = 1;break;
                        case 1:a = 0;b = 0;c = 0;d = 1;break;
                        case 2:a = 0;b = 0;c = 1;d = 1;break;
                        case 3:a = 0;b = 0;c = 1;d = 0;break;
                        case 4:a = 0;b = 1;c = 1;d = 0;break;
                        case 5:a = 0;b = 1;c = 0;d = 0;break;
                        case 6:a = 1;b = 1;c = 0;d = 0;break;
                        case 7:a = 1;b = 0;c = 0;d = 0;break;
                num2++;
                if(num2 == 8)num2 = 0;
s1,s2兩個按鍵不知道能不能用,求大神幫幫忙幫我看看。
ID:125016 發表于 2019-7-9 10:55 | 只看該作者
s1,s2是怎么產生的中斷
