查看: 6658|回復: 7
51單片機做的音樂盒,帶八段數碼管顯示程序+Proteus仿真
ID:362094 發表于 2019-7-2 18:20 | 顯示全部樓層 |閱讀模式
之前的上傳錯了附件程序在下面,可能因為有調子,有點多,要在附件下載
  1. #include <reg52.h>
  3. #define uint  unsigned int
  4. sbit key1=P3^2;//按key1可以暫停播放
  5. sbit key2=P3^3;//按key2可切換歌曲
  6. sbit fm=P3^7;//蜂鳴器連續的IO口
  7. uchar code shuzi0=0x3f;
  8. uchar code shuzi1=0x06;//數字1
  9. uchar code shuzi2=0x5b;//數字2
  10. uchar code shuzi3=0x4f;
  11. uchar code shuzi4=0x66;
  12. uchar code shuzi5=0x6d;
  13. uchar code shuzi6=0x7d;
  14. uchar code shuzi7=0x07;
  15. uchar code shuzi8=0x7f;
  16. uchar count1;//播放暫停標志
  17. uchar count2;//歌曲標志
  18. uchar timeh,timel,i;
  19. //---------------------------簡譜---------------------------------------
  20. /*unsigned char code Music_Same[]={ 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x66, 0x18,0x03,
  21.                                   0x17,0x02, 0x15,0x02, 0x16,0x01, 0x15,0x02, 0x10,0x02,
  22.                                   0x15,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x02,
  23.                                   0x17,0x03, 0x18,0x03, 0x19,0x02, 0x15,0x02, 0x18,0x66,
  24.                                   0x17,0x03, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x00,
  25.                                   0x17,0x01, 0x19,0x02, 0x1B,0x02, 0x1B,0x70, 0x1A,0x03,
  26.                                   0x1A,0x01, 0x19,0x02, 0x19,0x03, 0x1A,0x03, 0x1B,0x02,
  27.                                   0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x18,0x66, 0x18,0x03,
  28.                                   0x19,0x02, 0x1A,0x02, 0x19,0x0C, 0x18,0x0D, 0x17,0x03,
  29.                                   0x16,0x01, 0x11,0x02, 0x11,0x03, 0x10,0x03, 0x0F,0x0C,
  30.                                   0x10,0x02, 0x15,0x00, 0x1F,0x01, 0x1A,0x01, 0x18,0x66,
  31.                                   0x19,0x03, 0x1A,0x01, 0x1B,0x02, 0x1B,0x03, 0x1B,0x03,
  32.                                   0x1B,0x0C, 0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x1F,0x01,
  33.                                   0x1A,0x01, 0x18,0x66, 0x19,0x03, 0x1A,0x01, 0x10,0x02,
  34.                                   0x10,0x03, 0x10,0x03, 0x1A,0x0C, 0x18,0x0D, 0x17,0x03,
  35.                                   0x16,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x70,
  36.                                   0x18,0x03, 0x17,0x02, 0x15,0x03, 0x15,0x03, 0x16,0x66,
  37.                                   0x16,0x03, 0x16,0x02, 0x16,0x03, 0x15,0x03, 0x10,0x02,
  38.                                   0x10,0x01, 0x11,0x01, 0x11,0x66, 0x10,0x03, 0x0F,0x0C,
  39.                                   0x1A,0x02, 0x19,0x02, 0x16,0x03, 0x16,0x03, 0x18,0x66,
  40.                                   0x18,0x03, 0x18,0x02, 0x17,0x03, 0x16,0x03, 0x19,0x00,
  41.                                   0x00,0x00 };
  42. //兩只蝴蝶
  43. unsigned char code Music_Two[] ={ 0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03,
  44.                                   0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02,
  45.                                   0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03,
  46.                                   0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x16,0x03,
  47.                                   0x17,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01,
  48.                                   0x10,0x03, 0x15,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
  49.                                   0x16,0x03, 0x15,0x03, 0x10,0x03, 0x15,0x03, 0x16,0x01,
  50.                                   0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03,
  51.                                   0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02,
  52.                                   0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03,
  53.                                   0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x19,0x03,
  54.                                   0x19,0x01, 0x19,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x01,
  55.                                   0x16,0x03, 0x16,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
  56.                                   0x16,0x03, 0x15,0x03, 0x10,0x03, 0x10,0x0D, 0x15,0x00,
  57.                                   0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03,
  58.                                   0x1B,0x03, 0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03,
  59.                                   0x16,0x0D, 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03,
  60.                                   0x1A,0x02, 0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03,
  61.                                   0x16,0x01, 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03,
  62.                                   0x19,0x02, 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E,
  63.                                   0x1B,0x04, 0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E,
  64.                                   0x1B,0x04, 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03,
  65.                                   0x17,0x0D, 0x16,0x03, 0x17,0x03, 0x19,0x01, 0x19,0x03,
  66.                                   0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03, 0x1B,0x03,
  67.                                   0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03, 0x16,0x03,
  68.                                   0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03, 0x1A,0x02,
  69.                                   0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x01,
  70.                                   0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03, 0x19,0x03,
  71.                                   0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
  72.                                   0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
  73.                                   0x17,0x16, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
  74.                                   0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x0F,0x02,
  75.                                   0x10,0x03, 0x15,0x00, 0x00,0x00 };
  76. //北京歡迎你
  77. unsigned char code Music_Code[]={ 0x17,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x17,0x03,
  78.                                   0x16,0x03, 0x17,0x02, 0x17,0x67, 0x16,0x03, 0x10,0x03,
  79.                                   0x15,0x03, 0x17,0x03, 0x16,0x66, 0x16,0x03, 0x15,0x03,
  80.                                   0x10,0x03, 0x15,0x03, 0x16,0x03, 0x17,0x03, 0x19,0x03,
  81.                                   0x16,0x03, 0x17,0x03, 0x1A,0x03, 0x19,0x03, 0x0F,0x03,
  82.                                   0x16,0x03, 0x15,0x66, 0x16,0x03, 0x15,0x03, 0x10,0x03,
  83.                                   0x15,0x03, 0x16,0x03, 0x17,0x03, 0x19,0x03, 0x16,0x03,
  84.                                   0x17,0x03, 0x1A,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x01,
  85.                                   0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x19,0x67,
  86.                                   0x1A,0x04, 0x17,0x02, 0x10,0x03, 0x17,0x03, 0x16,0x03,
  87.                                   0x16,0x03, 0x15,0x66, 0x17,0x03, 0x19,0x03, 0x1F,0x03,
  88.                                   0x19,0x03, 0x1A,0x66, 0x19,0x03, 0x1A,0x03, 0x19,0x03,
  89.                                   0x17,0x03, 0x17,0x03, 0x19,0x03, 0x19,0x66, 0x17,0x03,
  90.                                   0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x20,0x03, 0x1F,0x03,
  91.                                   0x19,0x03, 0x17,0x03, 0x16,0x03, 0x19,0x02, 0x17,0x03,
  92.                                   0x17,0x01, 0x17,0x03, 0x19,0x03, 0x1F,0x03, 0x19,0x03,
  93.                                   0x1A,0x66, 0x1F,0x03, 0x20,0x67, 0x1F,0x04, 0x19,0x03,
  94.                                   0x17,0x03, 0x19,0x03, 0x1F,0x03, 0x1A,0x66, 0x17,0x03,
  95.                                   0x16,0x03, 0x17,0x03, 0x1A,0x03, 0x21,0x03, 0x20,0x66,
  96.                                   0x20,0x03, 0x1F,0x01, 0x1F,0x66, 0x17,0x03, 0x19,0x03,
  97.                                   0x15,0x03, 0x19,0x03, 0x1A,0x66, 0x1F,0x03, 0x20,0x66,
  98.                                   0x1F,0x04, 0x19,0x03, 0x17,0x03, 0x19,0x03, 0x1F,0x03,
  99.                                   0x1A,0x66, 0x17,0x03, 0x16,0x03, 0x17,0x03, 0x1A,0x03,
  100.                                   0x21,0x03, 0x20,0x0B, 0x20,0x0B, 0x20,0x0B, 0x20,0x0B,
  101.                                   0x20,0x02, 0x1F,0x03, 0x1F,0x0B, 0x1F,0x0B, 0x1F,0x0B,
  102.                                   0x1F,0x0B, 0x1F,0x0B, 0x00,0x00 };
  103. //奧運主題曲:我和你
  104. unsigned char code Music_Code1[]={ 0x17,0x02, 0x19,0x02, 0x15,0x01, 0x16,0x02, 0x17,0x02,
  105.                                   0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x02, 0x19,0x02,
  106.                                   0x16,0x00, 0x17,0x02, 0x19,0x02, 0x15,0x01, 0x16,0x02,
  107.                                   0x17,0x02, 0x10,0x01, 0x16,0x02, 0x0F,0x02, 0x16,0x02,
  108.                                   0x17,0x02, 0x15,0x00, 0x1A,0x01, 0x19,0x01, 0x1A,0x01,
  109.                                   0x15,0x01, 0x17,0x02, 0x10,0x02, 0x17,0x66, 0x19,0x03,
  110.                                   0x16,0x00, 0x17,0x02, 0x19,0x02, 0x15,0x01, 0x16,0x02,
  111.                                   0x17,0x02, 0x10,0x01, 0x16,0x02, 0x0F,0x02, 0x16,0x02,
  112.                                   0x17,0x02, 0x15,0x00, 0x00,0x00 };*/
  113. uchar code muqin[]={ //母親
  114. 0x52,0x51,0x61,0x82,0x71,0x62,0x31,0x21,0x14,0x32,0x92,0x91,0x71,0x61,0x31,0x58,
  115. //你入學的新書包有人給你拿
  116. 0x52,0x51,0x61,0x82,0x71,0x62,0x51,0x61,0x34,0x62,0x61,0x51,0x51,0x31,0x28,
  117. //你雨中的花折傘有人給你打
  118. 0x32,0x31,0x21,0x52,0x51,0x31,0x22,0x31,0x21,0x12,0x21,0x32,0x51,0x71,0x61,0x52,0x68,
  119. //你愛吃的(那)三鮮餡有人(他)給你包
  120. 0x82,0x81,0x61,0x82,0x81,0x62,0x51,0x31,0x24,0x62,0x51,0x31,0x31,0x21,0x14,
  121. //你委屈的淚花有人給你擦
  122. 0x81,0x91,0xa1,0xa2,0xa1,0x92,0xa1,0x91,0x84,
  123. //啊,這個人就是娘
  124. 0x61,0x81,0x91,0x92,0xa1,0x91,0x71,0x61,0x71,0x61,0x58,
  125. //啊,這個人就是媽
  126. 0x61,0x82,0x61,0x82,0x81,0x61,0x52,0x61,0x51,0x64,
  127. //這個人給了我生命
  128. 0x62,0x81,0xa1,0x91,0x82,0x94,
  129. //給我一個家
  130. 0x81,0x91,0xa1,0xa2,0xa1,0x92,0xa1,0x91,0x84,
  131. //啊,不管你走多遠
  132. 0x61,0x81,0x92,0x71,0x61,0x71,0x61,0x58,
  133. //無論你在干啥
  134. 0x61,0x81,0x81,0x61,0x82,0x81,0x61,0x52,0x61,0x51,0x34,
  135. //到什么時候也離不開
  136. 0x62,0xa2,0x91,0x81,0x62,0x88,
  137. //咱的媽
  138. 0x62,0xa2,0x91,0x81,0x62,0x84,
  139. //咱的媽
  140. 0x81,0x91,0x62,0xf2,0x91,0x81,0x62,0x88,
  141. 0XFF,
  142. } ;
  143. uchar code jmszl[]={ //寂寞沙洲冷
  144. 0x12,0x12,0x22,0x32,0x31,0x22,0x21,0x22,
  145. //自你走后心憔悴
  146. 0x21,0x31,0x51,0x52,0x31,0x52,0x61,0x15,0x14,
  147. //白色油桐風中紛飛
  148. 0x51,0x52,0x31,0x52,0x62,0x13,0x11,0x13,0x32,0x28,0x08,0x28,
  149. //落花似人有情 這個季節
  150. 0x31,0x32,0x31,0x32,0x11,0x21,0x51,0x52,0x51,0x52,
  151. //河畔的風放肆拼命地吹
  152. 0x51,0x51,0x31,0x32,0x31,0x32,0x81,0x72,0x63,
  153. //不斷撥弄離人的眼淚
  154. 0x62,0x71,0x81,0x72,0x61,0x61,0x52,0x31,0x21,0x32,0x51,0x54,
  155. //那樣濃烈的愛再也無法給
  156. 0x22,0x12,0x11,0x12,0x11,0x12,0x12,0x14,0x26,0x32,0x26,
  157. //傷感一夜一夜
  158. 0x32,0x61,0x51,0x51,0x31,0x31,0x21,0x31,0x51,0x61,0x51,0x31,0x51,
  159. //當記憶的線纏繞過往支離破碎
  160. 0x02,0x32,0x81,0x81,0x81,0x81,0x62,0x52,0x34,
  161. //是慌亂占據了心扉
  162. 0x31,0x81,0x81,0x81,0x61,0x91,0x82,
  163. //有花兒伴著蝴蝶
  164. 0x51,0x51,0x51,0x51,0x31,0x61,0x53,
  165. //孤雁可以雙飛
  166. 0x21,0x11,0x21,0x11,0x22,0x11,0x21,0x26,
  167. //夜深人靜獨徘徊
  168. 0x32,0x61,0x51,0x51,0x31,0x31,0x21,0x31,0x51,0x61,0x51,0x31,0x51,0x52,
  169. //當幸福戀人寄來紅色分享喜悅
  170. 0x31,0x31,0x81,0x81,0x81,0x61,0x91,0x81,0x61,0x31,0x56,
  171. //閉上雙眼難過頭也不敢回
  172. 0x32,0x32,0x81,0x81,0x81,0x81,0x91,0x81,0x61,0x81,0x61,0x51,0x31,0x51,0x34,
  173. //仍然撿盡寒枝不肯安歇微帶著后悔
  174. 0x21,0x31,0x51,0x31,0x21,0x11,0x61,0x21,0x16,
  175. //寂寞沙洲我該思念誰
  176. 0xff};
  177. uchar code mamahao[]={ //世上只有媽媽好
  178. //世上只有媽媽好
  179. 0x68,0x52,0x34,0x54,0x84,0x62,0x52,0x68,
  180. //世上只有媽媽好
  181. 0x34,0x52,0x62,0x54,0x34,0x12,0xc2,0x52,0x32,0x28,
  182. //有媽的孩子像個寶
  183. 0x24,0x32,0x54,0x52,0x62,0x34,0x24,0x18,
  184. //投進了媽媽的懷抱
  185. 0x54,0x32,0x22,0x12,0xc2,0x12,0xb8,0x04,0xff,
  186. //幸福享不了
  187. };
  188. uchar code exql[]={ //兒行千里
  189. // 兒行千里
  190. 0x62,0x61,0x61,0x61,0x72,0x51,0x68,
  191. //衣裳在添幾件,
  192. 0x62,0x61,0x61,0x61,0x71,0x51,0x38,
  193. //飯菜多吃幾口,
  194. 0x32,0x31,0x62,0x31,0x21,0x31,0x14,0x22,0x21,0x21,0x12,0x61,0x38,
  195. //出門在外沒有媽熬的小米粥,
  196. 0x62,0x62,0x61,0x72,0x51,0x68,
  197. //一會兒看看臉,
  198. 0x62,0x62,0x61,0x72,0x51,0x38,
  199. //一會兒摸摸手,
  200. 0x34,0x62,0x61,0x31,0x22,0x21,0x31,0x14,
  201. //一會兒又把囑咐的話,
  202. 0x22,0x21,0x31,0x12,0x61,0x68,
  203. //裝進兒的兜;
  204. 0x62,0x84,0x62,0x92,0x84,0x72,0x61,0x71,0x51,0x32,0x31,0x52,0x64,
  205. //如今要到了,離開家的時候,
  206. 0x62,0x84,0x62,0x91,0xa1,0x84,0x72,0x61,0x71,0x62,0x52,0x51,0x61,0x34,
  207. //才理解兒行千里母擔憂,
  208. 0x32,0x62,0x62,0x31,0x21,0x32,0x34,0x02,0x32,0x62,0x62,0x31,0x21,0x12,0x14,0x02,
  209. //千里的路啊,我還一步沒走,
  210. 0x71,0x72,0x61,0x22,0x31,0x31,0x52,0x31,0x52,0x62,
  211. //就看見淚水在媽媽眼里,
  212. 0x82,0x81,0x71,0x61,0x62,0x28,0x62,0x61,0x71,0x52,0x31,0x68,0x68,0xff,
  213. //媽媽眼里流,媽媽眼里流;
  214. };
  215. uchar code ganen[]={//感恩的心
  216. 0x12,0x14,0x22,0x32,0x54,
  217. //我來自偶然,
  218. 0x32,0x84,0x72,0x62,0x54,
  219. //像一顆塵土,
  220. 0x02,0x62,0x62,0x52,0x54,0x12,0x22,0x32,0x28,
  221. //有誰看出我的脆弱,
  222. 0x12,0x14,0x22,0x32,0x54,
  223. //我來自何方,
  224. 0x32,0x84,0x92,0x82,0x54,
  225. //我情歸何處,
  226. 0x32,0x24,0x21,0x61,0x54,0x22,0x32,0x12,0x18,
  227. //誰在下一刻呼喚我,
  228. 0x22,0x24,0x12,0x24,0x11,0x21,0x34,0x32,0x21,0x31,0x34,
  229. //天地雖寬 這條路卻難走
  230. 0x12,0x22,0x22,0x22,0x11,0x21,0x22,0x64,0x52,0x52,0x32,0x38,
  231. //我看遍這人間坎坷辛苦
  232. 0x31,0x52,0x51,0x52,0x31,0x51,0x58,
  233. //我還有多少愛
  234. 0x31,0x82,0x81,0x82,0x31,0x61,0x68,
  235. //我還有多少淚
  236. 0x62,0x62,0x62,0x51,0x61,0x64,0x61,0x82,0x61,0x9c,
  237. //要蒼天知道 我不認輸
  238. 0x52,0xa4,0x92,0xa4,0x32,0x84,0x72,0x64,
  239. //感恩的心 感謝有你
  240. 0x62,0x94,0x82,0x94,
  241. //伴我一生
  242. 0x61,0x81,0x92,0x91,0x91,0x92,0x81,0xa1,0xa2,0x92,0x94,
  243. //讓我有勇氣做我自己
  244. 0x52,0xa4,0x92,0xa4,0x32,0x84,0x72,0x64,
  245. //感恩的心 感謝命運
  246. 0x52,0x62,0x81,0x81,0x82,0x92,0xa2,0x94,0x82,0x72,0x82,0x88,
  247. //花開花落我一樣會珍惜
  248. };
  249. uchar code tiger[]={//兩只老虎
  250. 0x14,0x24,0x34,0x14,0x14,0x24,0x34,0x14,
  251. //兩只老虎兩只老虎
  252. 0x34,0x44,0x58,0x34,0x44,0x58,
  253. //跑得快跑得快
  254. 0x52,0x61,0x52,0x41,0x34,0x14,0x52,0x61,0x52,0x41,0x34,0x14,
  255. //一只沒有眼睛一只沒有尾巴
  256. 0x14,0xb4,0x18,0x14,0xb4,0x18,0xff,
  257. //真奇怪真奇怪
  258. };
  259. uchar code qizige[]={ //七子之歌
  260. 0x54,0x32,0x52,0x32,0x54,
  261. //你可知MACAU
  262. 0x62,0x52,0x32,0x62,0x54,
  263. //不是我真姓
  264. 0x14,0x12,0x22,0x34,0x52,0x32,
  265. //我離開你太久了
  266. 0x02,0x32,0x58,
  267. //母親
  268. 0x52,0x52,0x62,0x52,0x32,0x54,0x52,0x62,0x52,0x82,0x62,0x58,
  269. //但是他們擄去的是我的肉體
  270. 0x14,0x52,0x32,0x22,0x12,0x24,0x32,0x54,0x2,0x22,0x34,0x1f,0x18,
  271. //你依然保管我內心的靈魂
  272. 0x04,0x54,0xa4,0x92,0x81,0x62,0x52,0x54,0x62,0x64,0x52,0x62,0x81,0xa2,0x82,0x9c,
  273. //那三百年來夢寐不忘的生母啊
  274. 0x02,0x52,0xa4,0x92,0x81,0x62,0x52,0x54,
  275. //請叫兒的乳名:
  276. 0x62,0x64,0x52,0x64,0xa2,0x92,0x9f,
  277. //叫我一聲--澳門
  278. 0xa4,0x92,0x81,0x62,0x52,0x54,
  279. //母親!母親!
  280. 0x84,0x62,0x52,0x32,0x22,0x14,
  281. //我要回來
  282. 0x04,0x22,0x32,0x58,0x58,0x04,0x52,0x62,0x8f,0xff,
  283. //母親!母親!
  284.   };
  285. uchar code qnzl[]={  //千年之戀
  286. 0x12,0x22,0x34,0x84,0x74,0x54,0x38,0x42,0x32,0x22,0x42,0x34,0x84,0x72,0x82,0x94,0xA8,0x08,
  287. //前奏
  288. 0x32,0x31,0x21,0x32,0x52,0x32,0x31,0x21,0x32,0x62,
  289. //竹林的燈火 到過的沙漠
  290. 0x32,0x31,0x21,0x32,0x82,0x71,0x81,0x71,0x51,0x32,0x22,
  291. //七色的國度 不斷飄逸風中
  292. 0x32,0x31,0x21,0x32,0x52,0x32,0x31,0x21,0x32,0x62,
  293. //有一種神秘 灰色的旋渦
  294. 0x32,0x31,0x21,0x32,0x83,0x82,0x71,0x72,0x02,
  295. //將我卷入了迷霧中
  296. 0x63,0xA1,0xA2,0x62,0x92,0x82,0x52,
  297. //看不清的雙手
  298. 0x31,0x51,0x63,0x51,0x63,0x51,0x63,0x51,0x62,0x82,0x7C,0x02,
  299. //一朵花傳來誰經過的溫柔
  300. 0x61,0x71,0x82,0x71,0x62,0xA2,0x71,0x76,
  301. //穿越千年的傷痛
  302. 0x61,0x71,0x82,0x71,0x62,0x52,0x31,0x36,
  303. //只為求一個結果
  304. 0x61,0x71,0x82,0x71,0x62,0xA3,0x73,0x62,0x53,
  305. //你留下的輪廓 指引我
  306. 0x42,0x63,0x83,0x83,0x91,0x91,
  307. //黑夜中不寂寞
  308. 0x61,0x71,0x82,0x71,0x62,0x0A2,0x71,0x76,
  309. //穿越千年的哀愁
  310. 0x61,0x71,0x82,0x71,0x62,0x52,0x31,0x36,
  311. //是你在盡頭等我
  312. 0x61,0x71,0x82,0x71,0x62,0xA3,0x73,0x62,0x53,
  313. //最美麗的感動 會值得
  314. 0x42,0x82,0x88,0x02,0x74,0x93,0x89,0xff//結束標志
  315. //用一生守候
  316. };
  317. //----------------------------簡譜音調對應的定時器初值---------------------------
  318. //適合11.0592M的晶振
  319. uchar code cuzhi[]={
  320.   0xff,0xff,//占位
  321.   0xFC,0x8E,//中央C調1-7
  322.   0xFC,0xED,
  323.   0xFD,0x43,
  324.   0xFD,0x6A,
  325.   0xFD,0xB3,
  326.   0xFD,0xF3,
  327.   0xFE,0x2D,
  328.   0xFE,0x47, //高八度1-7
  329.   0xFE,0x76,
  330.   0xFE,0xA1,
  331.   0xFE,0xC7,
  332.   0xFE,0xD9,
  333.   0xFE,0xF9,
  334.   0xFF,0x16
  335.   };
  336. uchar yinyue[]={0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,0x0,0x0};//將節拍轉換成燈亮的節奏
  337. void delay1(uint z); //延時1MS
  338. void delay(uint z); //延時165MS,即十六分音符
  339. void song();
  340. void beep();//蜂鳴器叫一聲
  341. main()
  342. {
  343.         P1=shuzi0;
  344. EA=1;//開總中斷
  345. EX0=1;//開外部中斷0
  346. IT0=1;//外部中斷0下降沿觸發方式
  347. EX1=1;//開外部中斷1
  348. IT1=1;//外部中斷1下降沿觸發方式
  349. TMOD=0x01;//定時器0工作在方式1
  350. TH0=0;
  351. TL0=0;
  352. ET0=1;
  353. while(1)
  354. {
  355.
  356.   if(count2!=0)
  357.   {
  358.    switch(count2)
  359.    {
  360.     case 1:
  361.
  362.      {
  363.
  364.            song();
  365.
  366.
  367.         break;
  368.      }
  369.     break;
  370.
  371.    }
  372.   }
  373.   else
  374.   {
  375.
  376.   }
  377. }
  378. }
  379. /*void key1() interrupt3
  380. {
  381.    EA=1;
  382.    EX0=1;
  383.    IT0=0;
  384.
  385.    }
  386. */
  387. void int1() interrupt 2      //用于按鍵key2引起的中斷
  388. {
  389. EA=0;//關總中斷
  390. delay1(1);//去抖
  391. if(key2==0)
  392. {
  393.   TR0=1;
  394.   i=0;//從頭開始唱
  395.   count2++;
  396.   if(count2==9)
  397.           count2=1;
  398. }
  399. EA=1;//開總中斷
  400. }
  401. void timer0() interrupt 1  //用于產生各種音調
  402. {
  403. TH0=timeh;
  404. TL0=timel;
  405. fm=~fm;
  406. }
  407. void song()
  408. {
  409. uint temp;
  410. uchar jp;//jp是簡譜
  411. int i=0;
  412. while(1)
  413. {
  414.   if(count2==1) //選曲
  415.   { P1=shuzi1;
  416.      if(key1==0)
  417.       while(1)
  418.       {
  419.          fm=0;
  420.          if(key1==1)
  421.          break;
  422.         }
  423.         temp=muqin[i];}
  424.   if(count2==2)
  425.   {P1=shuzi2;
  426.       if(key1==0)
  427.       while(1)
  428.       {
  429.          fm=0;
  430.          if(key1==1)
  431.          break;
  432.         }temp=jmszl[i];}
  433.   if(count2==3)
  434.   {P1=shuzi3;
  435.       if(key1==0)
  436.       while(1)
  437.       {
  438.          fm=0;
  439.          if(key1==1)
  440.          break;
  441.         }temp=mamahao[i];}
  442.   if(count2==4)
  443.   {P1=shuzi4;
  444.       if(key1==0)
  445.       while(1)
  446.       {
  447.          fm=0;
  448.          if(key1==1)
  449.          break;
  450.         }temp=exql[i];}
  451.   if(count2==5)
  452.   { P1=shuzi5; if(key1==0)
  453.       while(1)
  454.       {
  455.          fm=0;
  456.          if(key1==1)
  457.          break;
  458.         }temp=ganen[i];}
  459.   if(count2==6)
  460.   { P1=shuzi6;
  461.       if(key1==0)
  462.       while(1)
  463.       {
  464.          fm=0;
  465.          if(key1==1)
  466.          break;
  467.         }temp=tiger[i];}
  468.   if(count2==7)
  469.   {P1=shuzi7;
  470.       if(key1==0)
  471.       while(1)
  472.       {
  473.          fm=0;
  474.          if(key1==1)
  475.          break;
  476.         }temp=qizige[i];}
  477.   if(count2==8)
  478.   {P1=shuzi8;
  479.      if(key1==0)
  480.       while(1)
  481.       {
  482.          fm=0;
  483.          if(key1==1)
  484.          break;
  485.         } temp=qnzl[i];}
  486.   if(temp==0xff)
  487.    break;
  488.
  489.   jp=temp/16; //取數的高4位
  490.          P0=yinyue[jp];
  491.   if(jp!=0)
  492.   {
  493.   timeh=cuzhi[jp*2];
  494.   timel=cuzhi[jp*2+1];
  495.   }
  496.   else
  497.   {
  498.   TR0=0;
  499.   fm=1;//關蜂鳴器
  500.   }
  501.   delay(temp%16); //取數的低4位
  502.   TR0=0;  //唱完一個音停10MS
  503.   fm=1;
  504.   delay1(10);
  505.   TR0=1;
  506.   i++;
  507. }
  508. TR0=0;
  509. fm=1;
  510. }
  511. void delay(uint z) //延時165MS,即十六分音符
  512. { uint x,y;
  513. for(x=z;x>0;x--)
  514.    for(y=19000;y>0;y--);
  515. }
  516. void delay1(uint z) //延時1MS
  517. { uint x,y;
  518. for(x=z;x>0;x--)
  519.    for(y=112;y>0;y--);
  520. }
  521. void beep() //蜂鳴器叫一聲
  522. { uchar i;
  523. for(i=0;i<50;i++)
  524. { fm=~fm;
  525.   delay1(1);
  526. }
  527. fm=1;
  528. }
全部資料51hei下載地址:
音樂盒帶數碼管.rar (32.91 KB, 下載次數: 160)
ID:649321 發表于 2019-11-25 20:59 | 顯示全部樓層
做的特別好
ID:650865 發表于 2019-11-27 23:01 | 顯示全部樓層
太牛了
ID:737021 發表于 2020-4-24 15:40 | 顯示全部樓層
為啥下載的那個打不開啊
ID:777696 發表于 2020-6-12 22:27 | 顯示全部樓層
想問一下能不能給一個dsn文件呀?
ID:271479 發表于 2020-6-22 19:29 | 顯示全部樓層
寫的很好,想借鑒借鑒
ID:114240 發表于 2020-7-8 15:48 | 顯示全部樓層
里面只有仿真圖,而且功能不對啊。
ID:915851 發表于 2021-5-5 18:52 | 顯示全部樓層
按鍵暫停的功能沒得實現
