更具lwip移植到stm32上實現(xiàn)以太網(wǎng)服務(wù)器
- #include "led.h"
- #include "lcd.h"
- #include "key.h"
- #include "stm32f4x7_eth.h"
- #include "stm32f4x7_eth_bsp.h"
- #include "netconf.h"
- #include "tcp.h"
- #include "udp.h"
- #include "string.h"
- #include "TCP_SERVER.h"
- #define SYSTEMTICK_PERIOD_MS 10
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- __IO uint32_t LocalTime = 0; /* this variable is used to create a time reference incremented by 10ms */
- uint32_t timingdelay;
- int main(void)
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級分組2
- delay_init(); //初始化延時函數(shù)
- LED_Init(); //初始化LED
- //LCD_Init(); //初始化LCD
- KEY_Init(); //初始化KEY
- // BRUSH_COLOR=RED;
- // LCD_DisplayString(10,10,24,"Illuminati STM32F4");
- // LCD_DisplayString(10,40,16,"Author:Clever");
- // LCD_DisplayString(20,70,24,"23 TCP_Server ");
- // BRUSH_COLOR=BLUE;
- // LCD_DisplayString(20,110,16,"IMT407G_IP:192.168.1.240"); //開發(fā)板作為服務(wù)器時的IP
- // LCD_DisplayString(20,130,16,"TCP_Server_PORT:2040 "); //開發(fā)板作為服務(wù)器時的端口號
- ETH_BSP_Config(); //DP83848相關(guān)IO初始化與ETH相關(guān)初始化
- LwIP_Init(); //LWIP初始化
- TCP_server_init(); //初始化開發(fā)板為服務(wù)器
- while (1)
- LwIP_Periodic_Handle(LocalTime); /* handle periodic timers for LwIP */
- * @brief Inserts a delay time.
- * @param nCount: number of 10ms periods to wait for.
- * @retval None
- void Delay(uint32_t nCount)
- /* Capture the current local time */
- timingdelay = LocalTime + nCount;
- /* wait until the desired delay finish */
- while(timingdelay > LocalTime)
- * @brief Updates the system local time
- * @param None
- * @retval None
- void Time_Update(void)
- LocalTime += SYSTEMTICK_PERIOD_MS;
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
TCP服務(wù)器數(shù)據(jù)收發(fā)實驗.7z
(613.2 KB, 下載次數(shù): 44)
2019-7-2 16:19 上傳
