Android下MTK平臺驅(qū)動(FT6X36_MTK6571 沃特沃德已調(diào)試通過),僅供參考。
2019-7-1 17:04 上傳
源程序如下:
- #include <linux/slab.h>
- #include <linux/i2c.h>
- #include <linux/types.h>
- #include <linux/sched.h>
- #include <linux/kthread.h>
- #include <linux/kernel.h>
- #include <linux/semaphore.h>
- #include <linux/proc_fs.h>
- #include <asm/uaccess.h>
- #include <linux/delay.h>
- #include <linux/module.h>
- #include <linux/init.h>
- #include <linux/fs.h>
- #include <linux/cdev.h>
- #include <linux/device.h>
- #include "tpd_custom_fts.h"
- #include "focaltech_ctl.h"
- #include "focaltech_ex_fun.h"
- #include <linux/netdevice.h>
- extern u8 *I2CDMABuf_va ;
- extern volatile u32 I2CDMABuf_pa;
- static int ft_rw_iic_drv_major = FT_RW_IIC_DRV_MAJOR;
- struct ft_rw_i2c_dev
- struct cdev cdev;
- struct semaphore ft_rw_i2c_sem;
- struct i2c_client *client;
- struct ft_rw_i2c_dev *ft_rw_i2c_dev_tt;
- static struct class *fts_class;
- static int ft_rw_iic_drv_myread(struct i2c_client *client, u8 *buf, int length)
- int ret = 0;
- ret = fts_i2c_Read(client, NULL, 0, buf, length);
- if(ret<0)
- dev_err(&client->dev, "%s:IIC Read failed\n",
- __func__);
- return ret;
- static int ft_rw_iic_drv_mywrite(struct i2c_client *client, u8 *buf, int length)
- int ret = 0;
- ret = fts_i2c_Write(client, buf, length);
- if(ret<0)
- dev_err(&client->dev, "%s:IIC Write failed\n",
- __func__);
- return ret;
- static int ft_rw_iic_drv_RDWR(struct i2c_client *client, unsigned long arg)
- struct ft_rw_i2c_queue i2c_rw_queue;
- u8 __user **data_ptrs;
- struct ft_rw_i2c * i2c_rw_msg;
- int ret = 0;
- int i;
- if (!access_ok(VERIFY_READ, (struct ft_rw_i2c_queue *)arg, sizeof(struct ft_rw_i2c_queue)))
- return -EFAULT;
- if (copy_from_user(&i2c_rw_queue,
- (struct ft_rw_i2c_queue *)arg,
- sizeof(struct ft_rw_i2c_queue)))
- return -EFAULT;
- if (i2c_rw_queue.queuenum > FT_I2C_RDWR_MAX_QUEUE)
- return -EINVAL;
- i2c_rw_msg = (struct ft_rw_i2c*)
- kmalloc(i2c_rw_queue.queuenum *sizeof(struct ft_rw_i2c),
- GFP_KERNEL);
- if (!i2c_rw_msg)
- return -ENOMEM;
- if (copy_from_user(i2c_rw_msg, i2c_rw_queue.i2c_queue,
- i2c_rw_queue.queuenum*sizeof(struct ft_rw_i2c))) {
- kfree(i2c_rw_msg);
- return -EFAULT;
- data_ptrs = kmalloc(i2c_rw_queue.queuenum * sizeof(u8 __user *), GFP_KERNEL);
- if (data_ptrs == NULL) {
- return -ENOMEM;
- ret = 0;
- for (i=0; i< i2c_rw_queue.queuenum; i++) {
- if ((i2c_rw_msg[i].length > 8192)||
- (i2c_rw_msg[i].flag & I2C_M_RECV_LEN)) {
- ret = -EINVAL;
- break;
- data_ptrs[i] = (u8 __user *)i2c_rw_msg[i].buf;
- i2c_rw_msg[i].buf = kmalloc(i2c_rw_msg[i].length, GFP_KERNEL);
- if (i2c_rw_msg[i].buf == NULL) {
- ret = -ENOMEM;
- break;
- if (copy_from_user(i2c_rw_msg[i].buf, data_ptrs[i], i2c_rw_msg[i].length)) {
- ++i;
- ret = -EFAULT;
- break;
- //printk("ft_rw_iic_drv_RDWR 6 %d %x %x\n",ret,data_ptrs,i2c_rw_msg);
- if (ret < 0) {
- int j;
- for (j=0; j<i; ++j)
- kfree(i2c_rw_msg[j].buf);
- kfree(data_ptrs);
- return ret;
- //printk("ft_rw_iic_drv_RDWR 7\n");
- //printk("ft_rw_iic_drv_RDWR 8 %d %x %x %d\n",i2c_rw_msg[i].flag,i2c_rw_msg[i].buf,data_ptrs[i],i2c_rw_msg[i].length);
- if (i2c_rw_msg[i].flag) {
- ret = ft_rw_iic_drv_myread(client,
- i2c_rw_msg[i].buf, i2c_rw_msg[i].length);
- if (ret>=0)
- ret = copy_to_user(data_ptrs[i], i2c_rw_msg[i].buf, i2c_rw_msg[i].length);
- else
- ret = ft_rw_iic_drv_mywrite(client,
- //printk("ft_rw_iic_drv_RDWR 10\n");
- return ret;
- *char device open function interface
- static int ft_rw_iic_drv_open(struct inode *inode, struct file *filp)
- filp->private_data = ft_rw_i2c_dev_tt;
- return 0;
- *char device close function interface
- static int ft_rw_iic_drv_release(struct inode *inode, struct file *filp)
- return 0;
- static int ft_rw_iic_drv_ioctl(struct file *filp, unsigned
- int cmd, unsigned long arg)
- int ret = 0;
- struct ft_rw_i2c_dev *ftdev = filp->private_data;
- ftdev = filp->private_data;
- //printk("ft_rw_iic_drv_ioctl\n");
- // down(&ft_rw_i2c_dev_tt->ft_rw_i2c_sem);
- //printk("====ft_rw_iic_drv_ioctl: client = %x\n",ftdev->client);
- switch (cmd)
- case FT_I2C_RW:
- ret = ft_rw_iic_drv_RDWR(ftdev->client, arg);
- break;
- default:
- ret = -ENOTTY;
- break;
- // up(&ft_rw_i2c_dev_tt->ft_rw_i2c_sem);
- //printk("++++ft_rw_iic_drv_ioctl\n");
- return ret;
- *char device file operation which will be put to register the char device
- static const struct file_operations ft_rw_iic_drv_fops = {
- .owner = THIS_MODULE,
- .open = ft_rw_iic_drv_open,
- .release = ft_rw_iic_drv_release,
- .unlocked_ioctl = ft_rw_iic_drv_ioctl,
- static void ft_rw_iic_drv_setup_cdev(struct ft_rw_i2c_dev *dev, int index)
- int err, devno = MKDEV(ft_rw_iic_drv_major, index);
- cdev_init(&dev->cdev, &ft_rw_iic_drv_fops);
- dev->cdev.owner = THIS_MODULE;
- dev->cdev.ops = &ft_rw_iic_drv_fops;
- dev->client = ft_rw_i2c_dev_tt->client;
- printk("%s: 2.client=%x \n",__func__,dev->client);
- err = cdev_add(&dev->cdev, devno, 1);
- if (err)
- printk(KERN_NOTICE "Error %d adding LED%d", err, index);
- static int ft_rw_iic_drv_myinitdev(struct i2c_client *client)
- int err = 0;
- dev_t devno = MKDEV(ft_rw_iic_drv_major, 0);
- if (ft_rw_iic_drv_major)
- err = register_chrdev_region(devno, 1, FT_RW_IIC_DRV);
- else {
- err = alloc_chrdev_region(&devno, 0, 1, FT_RW_IIC_DRV);
- ft_rw_iic_drv_major = MAJOR(devno);
- if (err < 0) {
- dev_err(&client->dev, "%s:ft_rw_iic_drv failed error code=%d---\n",
- __func__, err);
- return err;
- ft_rw_i2c_dev_tt = kmalloc(sizeof(struct ft_rw_i2c_dev), GFP_KERNEL);
- if (!ft_rw_i2c_dev_tt){
- err = -ENOMEM;
- unregister_chrdev_region(devno, 1);
- dev_err(&client->dev, "%s:ft_rw_iic_drv failed\n",
- __func__);
- return err;
- ft_rw_i2c_dev_tt->client = client;
- printk("ft_rw_iic_drv_myinitdev: client=%x \n",ft_rw_i2c_dev_tt->client);
- mutex_init(&ft_rw_i2c_dev_tt->ft_rw_i2c_sem);
- cdev_init(&ft_rw_i2c_dev_tt->cdev, &ft_rw_iic_drv_fops);
- ft_rw_i2c_dev_tt->cdev.owner = THIS_MODULE;
- ft_rw_i2c_dev_tt->cdev.ops = &ft_rw_iic_drv_fops;
- printk("%s: 2.client=%x \n",__func__,ft_rw_i2c_dev_tt->client);
- err = cdev_add(&ft_rw_i2c_dev_tt->cdev, devno, 1);
- printk("%s: client=%x \n",__func__,ft_rw_i2c_dev_tt->client);
- if (err)
- printk(KERN_NOTICE "Error %d adding LED", err);
- //ft_rw_iic_drv_setup_cdev(ft_rw_i2c_dev_tt, 0);
- //printk("===ft_rw_iic_drv_myinitdev: client=%x \n",ft_rw_i2c_dev_tt->client);
- fts_class = class_create(THIS_MODULE, "fts_class");
- if (IS_ERR(fts_class)) {
- dev_dbg(&client->dev, "%s:failed in creating class.\n",
- __func__);
- return -1;
- /*create device node*/
- device_create(fts_class, NULL, MKDEV(ft_rw_iic_drv_major, 0),
- NULL, FT_RW_IIC_DRV);
- return 0;
- int ft_rw_iic_drv_init(struct i2c_client *client)
- dev_dbg(&client->dev, "[FTS]----ft_rw_iic_drv init ---\n");
- return ft_rw_iic_drv_myinitdev(client);
- void ft_rw_iic_drv_exit(void)
- device_destroy(fts_class, MKDEV(ft_rw_iic_drv_major, 0));
- /*delete class created by us*/
- class_destroy(fts_class);
- /*delet the cdev*/
- cdev_del(&ft_rw_i2c_dev_tt->cdev);
- kfree(ft_rw_i2c_dev_tt);
- unregister_chrdev_region(MKDEV(ft_rw_iic_drv_major, 0), 1);
復(fù)制代碼 全部資料51hei下載地址:
Android下MTK平臺驅(qū)動FT6336U(1).zip
(35.05 KB, 下載次數(shù): 37)
2019-7-1 15:25 上傳
下載積分: 黑幣 -5
