查看: 2582|回復: 1
基于at89c51單片機的波形發生器Proteus仿真
ID:573124 發表于 2019-7-1 11:50 | 顯示全部樓層 |閱讀模式
基于at89c51單片機的波形發生器
代碼如下:
  1. #include<reg51.h>
  2. sbit wr=P3^6;
  3. sbit rd=P3^2;
  4. sbit key0=P1^0;
  5. sbit key1=P1^1;
  6. sbit key2=P1^2;
  7. sbit key3=P1^3;
  8. sbit key4=P1^4;
  9. unsigned char flag;
  10. unsigned char const code
  11. SIN_code[256]={0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,
  12. 0xab,0xae,0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8,0xda,
  13. 0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf4,0xf6,0xf7,0xf8,
  14. 0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  15. 0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,
  16. 0xea,0xe8,0xe6,0xe4,0xe3,0xe1,0xde,0xdc,0xda,0xd8,0xd6,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,
  17. 0xbf,0xbc,0xb9,0xb6,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x92,0x8f,0x8c,
  18. 0x89,0x86,0x83,0x80,0x7d,0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x64,0x61,0x5e,0x5b,0x58,0x55,0x52,
  19. 0x4f,0x4c,0x49,0x46,0x43,0x41,0x3e,0x3b,0x39,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27,0x25,0x23,
  20. 0x21,0x1f,0x1d,0x1b,0x19,0x17,0x15,0x14,0x12,0x10,0xf,0xd,0xc,0xb,0x9,0x8,0x7,0x6,0x5,0x4,0x3,
  21. 0x3,0x2,0x1,0x1,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0x1,0x2,0x3,0x3,0x4,0x5,0x6,
  22. 0x7,0x8,0x9,0xa,0xc,0xd,0xe,0x10,0x12,0x13,0x15,0x17,0x18,0x1a,0x1c,0x1e,0x20,0x23,0x25,0x27,
  23. 0x29,0x2c,0x2e,0x30,0x33,0x35,0x38,0x3b,0x3d,0x40,0x43,0x46,0x48,0x4b,0x4e,0x51,0x54,0x57,
  24. 0x50,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x73,0x76,0x79,0x7c};
  25. unsigned char keyscan()
  26. {
  27. unsigned char keyscan_num,temp;
  28. P1=0xff;
  29. temp=P1;
  30. if(~(temp&0xff))
  31. {
  32.   if(key0==0)
  33.   {
  34.    keyscan_num=1;
  35.    }
  36.    else if(key1==0)
  37.    {
  38.    keyscan_num=2;
  39.    }
  40.    else if(key2==0)
  41.    {
  42.    keyscan_num=3;
  43.    }
  44.    else if(key3==0)
  45.    {
  46.    keyscan_num=4;
  47.    }
  48.    else if(key4==0)
  49.    {
  50.    keyscan_num=5;
  51.    }
  52.    else
  53.    {
  54.    keyscan_num=0;
  55.    }
  56.    return keyscan_num;
  57.    }
  58.    }
  59.    void init_DA0832()
  60.    {
  61.     rd=0;
  62.         wr=0;
  63.         }
  64.         void SIN()
  65.         {
  66.          unsigned int i;
  67.          do{
  68.          P2=SIN_code[i];
  69.          i=i+1;
  70.          }while(i<256);
  71.          }
  72.          void Square()
  73.          {
  74.           EA=1;
  75.           ET0=1;
  76.           TMOD=1;
  77.           TH0=0xff;
  78.           TL0=0x83;
  79.           TR0=1;
  80.           }
  81.           void Triangle()
  82.           {
  83.           P2=0x00;
  84.           do{
  85.           P2=P2+1;
  86.           }while(P2<0xff);
  87.           P2=0xff;
  88.           do{
  89.           P2=P2-1;
  90.           }while(P2>0x00);
  91.           P2=0x00;
  92.           }
  93.           void Sawtooth()
  94.           {
  95.           P2=0x00;
  96.           do{
  97.           P2=P2+1;
  98.           }while(P2<0xff);
  99.           }
  100.           void Trapezoidal()
  101.           {
  102.           unsigned char i;
  103.           P2=0x00;
  104.           do{
  105.           P2=P2+1;
  106.           }while(P2<0xff);
  107.           P2=0xff;
  108.           for(i=255;i>0;i--)
  109.           {
  110.           P2=0xff;
  111.           }
  112.           do{
  113.           P2=P2-1;
  114.           }while(P2>0x00);
  115.           P2=0x00;
  116.           }
  117.           void main()
  118.           {
  119.           init_DA0832();
  120.           do{
  121.           flag=keyscan();
  122.           }while(!flag);
  123.           while(1)
  124.           {
  125.           switch(flag)
  126.           {
  127.           case 1:
  128.           do{
  129.           flag=keyscan();
  130.           SIN();
  131.           }while(flag==1);
  132.           break;
  133.            case 2:
  134.            Square ();
  135.           do{
  136.           flag=keyscan();
  137.           }while(flag==2);
  138.           TR0=0;
  139.           break;
  140.            case 3:
  141.           do{
  142.           flag=keyscan();
  143.           Triangle ();
  144.           }while(flag==3);
  145.           break;
  146.            case 4:
  147.           do{
  148.           flag=keyscan();
  149.          Trapezoidal ();
  150.           }while(flag==5);
  151.           break;
  152.           default:
  153.           flag=keyscan();
  154.           break;
  155.           }
  156.           }
  157.           }
  158.           void timer0(void) interrupt 1
  159.           {
  160.           P2=~P2;
  161.           TH0=0xff;
  162.           TL0=0x83;
  163.           TR0=1;
  164.           }
全部資料51hei下載地址:
波形發生器.zip (66.95 KB, 下載次數: 54)
ID:576704 發表于 2019-7-2 23:36 | 顯示全部樓層
可是不能出仿真圖像呀
