查看: 2523|回復: 1
Keil編譯顯示打不開頭文件,出現 before 'jump...
ID:567836 發表于 2019-6-30 13:43 | 顯示全部樓層 |閱讀模式
# include "bsp.h"
# define S        5.0f
uint8_t JumpTime = 0;                /* 外部中斷0邊沿跳變次數統計 */
uint8_t MeasureOK = 0;        /* 測量完成標志 */
uint32_t Time = 0;                        /* 用于計算兩次邊沿跳變的時間 */
uint8_t str[20] = {0};        /* LCD顯示緩存區 */
sbit key = P3^2;                                /* 外部中斷引腳 */
int main(void)
        bsp_Config();                /* 板級外設初始化 */
        EX0 = 1;                /* 開啟外部中斷0 */
        bsp_lcd_ShowString(1, 0, "Speed Measuring");
void EX0_IRQ(void) interrupt 0
        float speed = 0.0f;
        JumpTime++;                /* 統計中斷次數 */
        while(key == 0);                /* 等待按鍵被釋放 */
        if(JumpTime >= 2 && MeasureOK == 0)                /* 按鍵已經按了兩次,計算速度 */
                JumpTime = 0;                /* 清除跳變量 */
                MeasureOK = 1;        /* 已經完成測量了 */
                speed = (float)((S /Time) * 1000.0);
                Time = 0;
                sprintf(str,"%f m/s", speed);
                bsp_lcd_ShowString(0, 1, str);
#include "bsp.h"
void bsp_Config(void)
        bsp_lcd_Config();
        bsp_tim_Config();
void bsp_DelayMs(uint8_t ui_nMs)
        uint8_t a = 0, b = 0;
        for(; ui_nMs > 0; ui_nMs --)
                for(a = 199; a > 0; a --)
                        for(b = 1; b > 0; b --);
# include "bsp.h"
# include "app.h"
# define TIMS (65536 - FOSC/1000)
void bsp_tim_Config(void)
        TMOD = 0x01;
        TL0 = TIMS;
        TH0 = TIMS >> 8;
        TR0 = 1;
        ET0 = 1;
        EA = 1;
static count = 0;
extern uint8_t JumpTime;
extern uint32_t Time;
void timer0_IRQ(void)        interrupt 1 using 1
        TL0 = TIMS;                                /* 需要重裝初值 */
        TH0 = TIMS >> 8;
        if(JumpTime == 1)                /* 只有在第一次按下后才開始計數,直到第二次按下 */
                Time ++;
static void bsp_lcd_WriteCmd(uint8_t cmd)
        LCD_EN = 0;                        /*  使能LCD1602  */
        LCD_RD = 0;                        /*  選擇發送命令  */
        LCD_RW = 0;                        /*  選擇寫入  */
        LCD_DATA = cmd;                /* 寫入命令 */
        bsp_DelayMs(5);                /* 等待數據穩定延時5ms */
        LCD_EN = 1;                                /* 寫入時序 */
        bsp_DelayMs(10);
        LCD_EN = 0;
static void bsp_lcd_WriteData(uint8_t dat)
        LCD_EN = 0;
        LCD_RD = 1;
        LCD_RW = 0;
        LCD_DATA = dat;        //將數據放到LCD里
        bsp_DelayMs(1);
        LCD_EN = 1;
        bsp_DelayMs(5);
        LCD_EN = 0;
void bsp_lcd_Config(void)
        bsp_lcd_WriteCmd(0x38);                /* 開顯示 */
        bsp_lcd_WriteCmd(0x0c);                /* 不顯示光標 */
        bsp_lcd_WriteCmd(0x06);                /* 寫一個指針加1 */
        bsp_lcd_WriteCmd(0x01);                /* 清屏 */
        bsp_lcd_WriteCmd(0x80);                /* 指針復位 */
static void bsp_lcd_SetPos(uint8_t x, uint8_t y)
        /* 坐標超出范圍了 */
        if(x > 15) return ;
        if(y > 1) return ;
        if(y == 0)        bsp_lcd_WriteCmd(x + 0x80);
        else if(y == 1) bsp_lcd_WriteCmd(x + 0xc0);
void bsp_lcd_ShowNum(uint8_t x, uint8_t y, uint32_t num, uint8_t xbit)
        uint8_t temp = 0;
        while(xbit)
                temp = num % 10;                /*  取得要顯示的個位  */
                /*  從最后一位開始顯示  */
                bsp_lcd_SetPos(x + xbit - 1, y);
                bsp_lcd_WriteData(temp + 0x30);
                num/=10;                /* 已經顯示完個位了,把個位扔掉 */
                xbit --;                /* 由于是從后往前開始顯示,所以x坐標軸要減小 */
void bsp_lcd_ShowChar(uint8_t x, uint8_t y, uint8_t c)
        bsp_lcd_SetPos(x, y);
        bsp_lcd_WriteData(c);
void bsp_lcd_ShowString(uint8_t x, uint8_t y, uint8_t *string)
        uint8_t i = 0;
        while(*(string + i))                /* 在字符串沒有結束就一直顯示 */
                bsp_lcd_ShowChar(x + i, y, *(string + i));
                i++;
ID:577549 發表于 2019-7-8 15:48 來自觸屏版 | 顯示全部樓層
keil文件使用方法你可以查一下,貌似只能打開單片機應用的文件,希望對你有幫助
