查看: 4002|回復: 2
單片機驅動2004液晶測試程序,4線 8線 控制器HD44780
兩個C51單片機的測試程序,一個是連接八條數據線的,另一個是連接四條數據線的。附件里有原程序和proteus仿真文件。
  1. /*=========================================================
  2. LCD2004模擬口線接線方式 連接線圖:                                                  =
  3. ----------------------------------------------------          =
  4. | LCM-----51   | LCM-----51     | LCM------51  |   |          =
  5. ---------------------------------------------------|          =
  6. |              | RS -------P3.5 |                                   |          =
  7. |              | RW------- GND  |                                   |          =
  8. |              | E --------P3.4 |                                   |          =
  9. |              |                                |                                   |          =
  10. | DB4-----P0.4 |                                 |                                   |          =
  11. | DB5-----P0.5 |                                 |                                   |          =
  12. | DB6-----P0.6 |                                 |                                   |          =
  13. | DB7-----P0.7 |                                 |                                   |          =
  14. ----------------------------------------------------          =
  15. [注:AT89S51 使用 11.0592M 晶體震蕩器]                                          =
  16. =========================================================*/
  17. #include <reg51.h>
  18. #define uchar unsigned char
  19. #define uint unsigned int
  20. sbit LCM_RS=P3^5; //定義引腳
  21. sbit LCM_E =P3^4;
  22. sbit LED   =P2^5;//LED 的輸出鎖存端
  23. sbit dula  =P2^6;//數碼管的段鎖存端        74HC573
  24. sbit wela  =P2^7;//數碼管的位鎖存端
  25. #define LCM_Data  P0
  26. #define Busy 0x80 //用于檢測 LCM 狀態字中的 Busy 標識
  27. uchar num;
  28. uchar code table0[]="ABCDEFGHIJKLMNOPQRST";
  29. uchar code table1[]="01234567890123456789";
  30. uchar code table2[]="UVWXYZ!@#%&?+<[>]*-;";
  31. uchar code table3[]="abcdefghijklmnopqrst";
  32. void delay(uint z)//延時函數
  33. {
  34.         uint x,y;
  35.         for(x=z;x>0;x--)
  36.                 for(y=110;y>0;y--);
  37. }
  38. //寫數據 RS=H,RW=L,D0~D7=數據,E=高脈沖
  39. void WriteDataLCM(uchar Data)
  40. {
  41.         LCM_RS = 1;
  42.         LCM_E  = 0;
  43.         LCM_Data =(Data & 0xF0);
  44.         LCM_E  = 1;
  45.         delay(5);
  46.         LCM_E  = 0;
  47.         LCM_Data =(Data & 0x0F)<<4;
  48.         LCM_E  = 1;
  49.         delay(5);
  50.         LCM_E  = 0;
  51. }
  52. //寫指令 RS=L,RW=L,D0~D7=指令碼,E=高脈沖
  53. void WriteCommandLCM(uchar Command)
  54. {
  55.         delay(5);       //短暫延時,代替檢測忙狀態
  56.         LCM_RS = 0;
  57.         LCM_E  = 0;
  58.         LCM_Data =( Command & 0xF0);
  59.         LCM_E  = 1;
  60.         delay(5);
  61.         LCM_E  = 0;
  62.         LCM_Data =( Command & 0x0F )<<4;
  63.         LCM_E  = 1;
  64.         delay(5);
  65.         LCM_E  = 0;
  66. }
  67. //讀數據 RS=H,RW=H,E=H
  68. //讀狀態 RS=L,RW=H,E=H
  69. //由于不要檢測忙,所以讀數據和讀狀態兩個函數省略
  70. void LCMInit(void)     //LCM 初始化
  71. {
  72.         WriteCommandLCM(0x03);
  73.         delay(5);
  74.         WriteCommandLCM(0x02);
  75.         delay(5);
  76.         WriteCommandLCM(0x28); //顯示模式設置,開始要求每次檢測忙信號
  77.         WriteCommandLCM(0x0C);
  78.         WriteCommandLCM(0x06); // 顯示光標移動設置
  79.         WriteCommandLCM(0x01);
  80.         delay(5);
  81. }
  82. void main(void)
  83. {
  84.         LED=0; //將LED的鎖存端關閉
  85.         dula=0;//將數碼管的段鎖存端關閉
  86.         wela=0;//將數碼管的位鎖存端關閉
  87.     LCMInit();         //LCM 初始化
  88.         //第一行顯示
  89.         WriteCommandLCM(0x80+0x00);
  90.         for(num=0;num<20;num++)
  91.         {
  92.                 WriteDataLCM(table0[num]);
  93.                 delay(250);
  94.         }
  95.         //第二行顯示
  96.         WriteCommandLCM(0x80+0x40);
  97.         for(num=0;num<20;num++)
  98.         {
  99.                 WriteDataLCM(table1[num]);
  100.                 delay(250);
  101.         }
  102.         //第三行顯示
  103.         WriteCommandLCM(0x80+0x14);
  104.         for(num=0;num<20;num++)
  105.         {
  106.                 WriteDataLCM(table2[num]);
  107.                 delay(250);
  108.         }
  109.         //第四行顯示
  110.         WriteCommandLCM(0x80+0x54);
  111.         for(num=0;num<20;num++)
  112.         -----限于篇幅余下內容下載附件----------
2004液晶測試程序.rar (79.32 KB, 下載次數: 49)
收藏收藏2 分享淘帖 頂 踩
ID:526871 發表于 2019-6-27 18:26 | 只看該作者
仿真原理圖要自己連嗎,里面沒有仿真圖。。。
ID:573709 發表于 2019-6-27 20:41 來自觸屏版 | 只看該作者
學習來了
