查看: 2294|回復: 0
求大佬看看單片機雙機通信有沒有錯
ID:568764 發表于 2019-6-26 19:08 | 顯示全部樓層 |閱讀模式
20黑幣
下面注釋的是乙機,結果應該是:甲機按下中斷按鍵后,乙機聯排數碼管有顯示,但結果出不來按下按鍵沒反應,我懷疑是單片機壞了。。。
#include <AT89X51.H>
#define unit unsigned int
void delay(unsigned char delay_time)
       unsigned char i;
       while(delay_time--)
       for(i=0;i<125;i++)
       IT0=1;
       EX0=1;
       EA=1;
       SCON=0x51;
       TMOD=0x20;  TH0=0xf3;TL0=0xf3;
       TR1=1;
       EA=1;
       ES=1;
       while(1);
void jian() interrupt 0
               delay(10);
               if(P3^2!=1)
                       ACC=1;
                       SBUF=ACC;
void ser()interrupt 4
       if(RI==1)
               RI=0;
       else TI=0;
//#include<AT89X51.H>
//#define uchar unsigned char
//#define unit unsigned int
//bit receive_flag;
//unsigned int i;
//void mini_delay()
//  for(i=0;i<100;i++);
//void main(void)
//        unsigned char led[8]={0x1c,0xfc,0x7c,0x9e,0x1c,0xfc,0x7c,0x9e};
//        unsigned char wei[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
//        unsigned int a;
//        unsigned int b;
//        SCON=0x50;
//        TMOD=0x20;TH0=0xf3;TL0=0xf3;
//        ET1=1;
//        TR1=1;
//        EA=1;
//        ES=1;
//        receive_flag = 0;
//        while(1)
//                if(receive_flag)
//                        for(a=0;a<8;a++)
//                                for(b=0;b<=a;b++)
//                                        P1=wei[ b];
//                                        P0=led[ b];
//                                        mini_delay();
//void ser()interrupt 4
//        if(RI)
//                receive_flag=1;
//                RI=0;
//        else TI=0;
