查看: 9797|回復(fù): 1
warning C275: expression with possibly no effect單片機(jī)程序編譯錯(cuò)誤
ID:571461 發(fā)表于 2019-6-26 10:30 | 只看該作者 回帖獎勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
#define uint  unsigned int
sbit wei=P2^4;
sbit wei1=P2^5;
sbit beep=P2^0;
sbit sensor=P0^7;
sbit sensor1=P0^6;
uchar flag1;
uchar flag;
void chuankou(uchar temp)
   uchar table1[]={1,2};
   uchar m;
   PCON=0x00;
   SCON=0x50;
   TMOD=0x20;
   TH1=0xE6;
   TL1=0xE6;
   TR1=1;
   for(m=0;m<2;m++)
      SBUF=table1[temp];
          while(TI==0);
          TI=0;
void delay(uint t)
    while(t--);
void Test_Voltage(void)
   if(sensor==0&sensor1==1)
       delay(10000);
           if(sensor == 0)
               flag1 = 1;
             flag1 == 0;
             flag1 == 0;
   void action(void)
     if(flag1 == 1)
            wei=0xfe;
                P0 = 0x25;
                beep = 0;
                chuankou(1);
                delay(10000);
                beep = 1;
                delay(10000);
                wei=0xfd;
            wei=0;
                P0 = 0x03;
void Test_Voltage1(void)
    if(sensor1==0&sensor==1)
           delay(10000);
            if(sensor1==0)
               flag = 1;
             flag = 0;
             flag = 0;
void action1(void)
     if(flag == 1)
            wei=0xfe;
                P0 = 0x9f;
                beep = 0;
                chuankou(0);
                delay(10000);
                beep = 1;
                delay(10000);
                wei=0xfd;
            wei=0;
                P0 = 0x03;
void main(void)
      Test_Voltage();
          action();
          Test_Voltage1();
          action1();
紅外感應(yīng).C(44): warning C275: expression with possibly no effect
ID:828092 發(fā)表于 2021-4-9 21:46 | 只看該作者
倆flag1后面多打了一個(gè)等號
