查看: 7114|回復: 7
DS18B20溫度傳感器不能讀溫度,讀出來恒定一個數,應該是延時的問題
5黑幣
#include<reg51.h>
#include<intrins.h>
#include <ctype.h>
#include <stdlib.h>
#define LCD_DATA P0
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
unsigned char dispBuff0[16]={'S','E','T',':',' ','.',' ','V',' ',' ',' ','s',' ',' ',' ',};
unsigned char dispBuff1[16]={'T','E','M','P',':',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',};
unsigned char dispBuff2[4]={' ',' ',' ',' ',};
unsigned char dispBuff3[16]={' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',};
unsigned char dispBuff4[16]={'I','N','P','U','T',' ','4','W','E','I',' ','M','I','M','A',};
unsigned char dispBuff5[16]={' ',' ',' ','M','I','M','A',' ','E','R','R','O','R',' ',' ',};
sbit DQ=P2^3;
unsigned int temperature=0;
unsigned int fuhao=0;
sbit LED1=P1^1;
#define off  1
#define on 0
sbit speaker=P1^0;
void Delay20ms() ;
void LCD_WriteDat(unsigned char lcd_dat);
void LCD_WriteCmd(unsigned char lcd_cmd);
unsigned char LCD_ReadStatus(void);
void LCD_Goto(unsigned char x,unsigned char y);
void LCD_Display(unsigned char row,unsigned char *str);
void delay(unsigned int x)
        unsigned char j;
        while(x--)
            for(j=0;j<125;j++);
void delay1(unsigned int x)
           while(--x);
char keyscan()
        char skey;
        P3 = 0xfe;
        while((P3 & 0xf0) != 0xf0)
                delay(10);
                        switch(P3)
                                case 0xee: skey = '7'; break;
                                case 0xde: skey = '8'; break;
                                case 0xbe: skey = '9'; break;
                                case 0x7e: skey = '+'; break;
                        while((P3 & 0xf0) != 0xf0);
        P3 = 0xfd;
                delay(10);
                        switch(P3)
                                case 0xed: skey = '4'; break;
                                case 0xdd: skey = '5'; break;
                                case 0xbd: skey = '6'; break;
                                case 0x7d: skey = '-'; break;
        P3 = 0xfb;
                delay(10);
                        switch(P3)
                                case 0xeb: skey = '1'; break;
                                case 0xdb: skey = '2'; break;
                                case 0xbb: skey = '3'; break;
                                case 0x7b: skey = '.'; break;
        P3 = 0xf7;
                delay(10);
                        switch(P3)
                                case 0xe7: skey = '&'; break;
                                case 0xd7: skey = '0'; break;
                                case 0xb7: skey = '*'; break;
                                case 0x77: skey = '#'; break;
        return skey;
void Delay20ms()
        unsigned int tmp = 50000;
        while(tmp--);
void LCD_Init(void)
        Delay20ms();
        LCD_WriteCmd(0x38);
        LCD_WriteCmd(0x0c);
        LCD_WriteCmd(0x01);
        LCD_WriteCmd(0x06);
        LCD_Goto(0,0);
        unsigned char tmp;
        tmp = LCD_ReadStatus();
        while((tmp & 0x80))
        LCD_RS = 1;
        LCD_RW = 0;
        LCD_DATA = lcd_dat;
        _nop_();
        LCD_EN = 0;
        _nop_();
        _nop_();
        LCD_EN = 1;
        unsigned char tmp;
        while((tmp & 0x80))
        LCD_RS = 0;
        LCD_RW = 0;
        LCD_DATA = lcd_cmd;
        _nop_();
        LCD_EN = 0;
        _nop_();
        _nop_();
        LCD_EN = 1;
        unsigned char tmp;
        #if 0
        LCD_RS = 0;
        LCD_RW = 1;
        LCD_EN = 1;
        tmp = LCD_DATA;
        LCD_EN = 0;
        #endif
        LCD_DATA = 0xff;
        LCD_RS = 0;
        LCD_RW = 1;
        LCD_EN = 0;
        _nop_();
        _nop_();
        LCD_EN = 1;
        tmp = LCD_DATA;
        return tmp;
        unsigned char tmp;
        if(y)
                tmp = 0xc0 + x;
                LCD_WriteCmd(tmp);
                tmp = 0x80 + x;
                LCD_WriteCmd(tmp);
        if(row)
                LCD_Goto(0,1);
                LCD_Goto(0,0);
        while(*str != '\0')
                LCD_WriteDat(*str++);
int Init_DS18B20()
        unsigned char x=0;
        DQ = 1;
        delay1(1);
        DQ = 0;
        delay1(30);
        DQ = 1;
        delay1(5);
        if(DQ==1)
                x=0;
                x=1;
        delay1(30);
        return x;
unsigned char ReadOneChar(void)
        unsigned char i=0;
        unsigned char dat = 0;
        for (i=8;i>0;i--)
            DQ=1;
                _nop_();
                _nop_();
                _nop_();
                DQ = 0;
            dat>>=1;
                delay(1);
            DQ = 1;
                delay(2);
            if(DQ)
                    dat|=0x80;
            delay(5);
   return(dat);
void WriteOneChar(unsigned char dat)
        unsigned char i=0;
        for (i=8; i>0; i--)
                DQ = 1;
                _nop_();
                _nop_();
                _nop_();
                DQ = 0;
            DQ = dat&0x01;
            delay(2);
            dat>>=1;
void ReadTemperature(void)
{        unsigned char readdata[2]={0,0};
        fuhao=0;
        temperature=0;
        delay(40);
        if(Init_DS18B20()==1)
                WriteOneChar(0xCC);
                WriteOneChar(0x44);
        delay1(30);
                WriteOneChar(0xCC);
                WriteOneChar(0xBE);
        delay1(30);
        readdata[0]=ReadOneChar();
        readdata[1]=ReadOneChar();
        readdata[1]<<=8;
        if (readdata[1]>127)
                readdata[0]^=0xff;
                readdata[1]^=0xff;
                fuhao=1;
        temperature =readdata[1]*256+readdata[0] ;
        temperature =temperature*0.625+0.5;
void set()
        int i;
        char ckey;
        ckey=keyscan();
        if(ckey=='#')
                delay(10);
                i=1;
                {        ckey=keyscan();
                        if(isdigit(ckey)&&i==1)
                                 dispBuff2[0]=ckey;
                                i=0;
                                dispBuff0[4]=dispBuff2[0];
                                LCD_Display(0,dispBuff0);
                        else if(isdigit(ckey)&&i==0)
                                dispBuff2[1]=ckey;
                                dispBuff0[6]=dispBuff2[1];
                                break;
                        delay(800);
        if(ckey=='*')
                delay(10);
                i=1;
                {        ckey=keyscan();
                                 dispBuff2[2]=ckey;
                                i=0;
                                dispBuff0[9]=dispBuff2[2];
                                dispBuff2[3]=ckey;
                                dispBuff0[10]=dispBuff2[3];
                                break;
                        delay(800);
int mima()
        int i,a;
        char ckey;
        LCD_Display(0,dispBuff4);
        ckey=keyscan();
        if(ckey=='&')
                delay(10);
                i=0;
                        ckey=keyscan();
                                 dispBuff2[0]=ckey;
                                i=1;
                                dispBuff3[6]=dispBuff2[0];
                                LCD_Display(1,dispBuff3);
                        else if(isdigit(ckey)&&i==1)
                                dispBuff2[1]=ckey;
                                i=2;
                                dispBuff3[7]=dispBuff2[1];
                        else if(isdigit(ckey)&&i==2)
                                dispBuff2[2]=ckey;
                                i=3;
                                dispBuff3[8]=dispBuff2[2];
                        else if(isdigit(ckey)&&i==3)
                                dispBuff2[3]=ckey;
                                i=4;
                                dispBuff3[9]=dispBuff2[3];
                                break;
                        delay(800);
        a=(dispBuff2[0]-'0')*1000+(dispBuff2[1]-'0')*100+(dispBuff2[2]-'0')*10+(dispBuff2[3]-'0');
        return a;
void timer0() interrupt 1
{        TH0=254;
        TL0=200;
        speaker=!speaker;
        int a,b,d;
        float c;
        LCD_Init();
        TMOD=0x11;
        TH0=254;
        TL0=200;
        ET0=1;
        EA=1;
        speaker=1;
        m:d=mima();
        if(d==1234)
        {        while(1)
                        delay(10);
                        set();
                        ReadTemperature();
                        if (fuhao)
                                dispBuff1[5]='-';
                                dispBuff1[5]='+';
                        dispBuff1[6]=(temperature/1000)%10+'0';
                        dispBuff1[7]=(temperature/100)%10+'0';
                        dispBuff1[8]=(temperature/10)%10+'0';
                         dispBuff1[9]='.';
                        dispBuff1[10]=(temperature)%10+'0';
                        LCD_Display(1,dispBuff1);
                        a=dispBuff0[4]-'0';
                        b=dispBuff0[6]-'0';
                        c=a+b*0.1;
                        delay(20);
                        if (temperature>=c*510 && !fuhao)
                                LED1=on;
                                LED1=off;
                                TR0=1;
                                TR0=0;
                LCD_Display(1,dispBuff5);
                goto m;
最佳答案
查看完整內容
我這個例程是使用過的,沒有問題。 有程序main.c: /******************************************************************************* * 實驗名 :溫度顯示實驗 * 使用的IO : * 實驗效果 :1602顯示溫度 * 注意 : *******************************************************************************/ #include #include"temp.h" //數碼管IO #define DIG P0 sbit LSA=P2^2; sbit LSB=P2^3 ...
ID:164602 發表于 2019-6-26 10:26 | 只看該作者
我這個例程是使用過的,沒有問題。
有程序main.c:
* 實驗名                           :溫度顯示實驗
* 使用的IO             :
* 實驗效果       :1602顯示溫度
*        注意                                         :
#include<reg51.h>
#include"temp.h"
//數碼管IO
#define DIG        P0
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
unsigned char code DIG_CODE[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char Num=0;
unsigned int disp[8]={0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f};
void LcdDisplay(int);
void Timer0Configuration();
* 函數名         : main
* 函數功能                   : 主函數
* 輸入           : 無
* 輸出                  : 無
                LcdDisplay(Ds18b20ReadTemp());
* 函數名         : LcdDisplay()
* 函數功能                   : LCD顯示讀取到的溫度
* 輸入           : v
* 輸出                  : 無
void LcdDisplay(int temp)          //lcd顯示
          unsigned char datas[] = {0, 0, 0, 0, 0}; //定義數組
        float tp;
        if(temp< 0)                                //當溫度值為負數
        disp[2] = 0x40;
                //因為讀取的溫度是實際溫度的補碼,所以減1,再取反求出原碼
                temp=temp-1;
                temp=~temp;
                tp=temp;
                temp=tp*0.0625*100+0.5;
                //留兩個小數點就*100,+0.5是四舍五入,因為C語言浮點數轉換為整型的時候把小數點
                //后面的數自動去掉,不管是否大于0.5,而+0.5之后大于0.5的就是進1了,小于0.5的就
                //算加上.5,還是在小數點后面。
        disp[2] = 0;
                tp=temp;//因為數據處理有小數點所以將溫度賦給一個浮點型變量
                //如果溫度是正的那么,那么正數的原碼就是補碼它本身
                //算加上0.5,還是在小數點后面。
//    disp[0] = 0;
//    disp[1] = 0;
//    disp[3] = DIG_CODE[temp / 10000];
        disp[4] = DIG_CODE[temp % 10000 / 1000];
        disp[5] = DIG_CODE[temp % 1000 / 100] | 0x80;
        disp[6] = DIG_CODE[temp % 100 / 10];
        disp[7] = DIG_CODE[temp % 10];
* 函數名         : Timer0Configuration()
* 函數功能                   : 設置計時器
* 輸入           : 無
* 輸出                  : 無
        TMOD=0X02;//選擇為定時器模式,工作方式2,僅用TRX打開啟動。
        TH0=0X9C;        //給定時器賦初值,定時100us
        TL0=0X9C;
        ET0=1;//打開定時器0中斷允許
        EA=1;//打開總中斷
        TR0=1;//打開定時器
* 函數名         : DigDisplay() interrupt 1
* 函數功能                   : 中斷數碼管顯示
* 輸入           : 無
* 輸出                  : 無
void DigDisplay() interrupt 1
//定時器在工作方式二會自動重裝初,所以不用在賦值。
//        TH0=0X9c;//給定時器賦初值,定時1ms
//        TL0=0X00;
        DIG=0; //消隱
        switch(Num)         //位選,選擇點亮的數碼管,
                case(7):
                        LSA=0;LSB=0;LSC=0; break;
                case(6):
                        LSA=1;LSB=0;LSC=0; break;
                case(5):
                        LSA=0;LSB=1;LSC=0; break;
                case(4):
                        LSA=1;LSB=1;LSC=0; break;
//                case(3):
//                        LSA=0;LSB=0;LSC=1; break;
//                case(2):
//                        LSA=1;LSB=0;LSC=1; break;
//                case(1):
//                        LSA=0;LSB=1;LSC=1; break;
//                case(0):
//                        LSA=1;LSB=1;LSC=1; break;
        DIG=disp[Num]; //段選,選擇顯示的數字。
        Num++;
        if(Num>7)
                Num=4;
溫度讀取程序temp.c:
#include"temp.h"
* 函數名         : Delay1ms
* 函數功能                   : 延時函數
* 輸入           : 無
* 輸出                  : 無
void Delay1ms(unsigned int y)
        unsigned int x;
        for(y;y>0;y--)
                for(x=110;x>0;x--);
* 函數名         : Ds18b20Init
* 函數功能                   : 初始化
* 輸入           : 無
* 輸出                  : 初始化成功返回1,失敗返回0
unsigned char Ds18b20Init()
        unsigned int i;
    EA = 0;
        DSPORT=0;                         //將總線拉低480us~960us
        i=70;
        while(i--);//延時642us
        DSPORT=1;                        //然后拉高總線,如果DS18B20做出反應會將在15us~60us后總線拉低
        i=0;
    EA = 1;
        while(DSPORT)        //等待DS18B20拉低總線
                i++;
                if(i>5000)//等待>5MS
                        return 0;//初始化失敗
        return 1;//初始化成功
* 函數名         : Ds18b20WriteByte
* 函數功能                   : 向18B20寫入一個字節
* 輸入           : com
* 輸出                  : 無
void Ds18b20WriteByte(unsigned char dat)
        unsigned int i,j;
    EA = 0;
        for(j=0;j<8;j++)
                DSPORT=0;                        //每寫入一位數據之前先把總線拉低1us
                i++;
                DSPORT=dat&0x01; //然后寫入一個數據,從最低位開始
                i=6;
                while(i--); //延時68us,持續時間最少60us
                DSPORT=1;        //然后釋放總線,至少1us給總線恢復時間才能接著寫入第二個數值
                dat>>=1;
    EA = 1;
* 函數名         : Ds18b20ReadByte
* 函數功能                   : 讀取一個字節
* 輸入           : com
* 輸出                  : 無
unsigned char Ds18b20ReadByte()
        unsigned char byte,bi;
        unsigned int i,j;
    EA = 0;
        for(j=8;j>0;j--)
                DSPORT=0;//先將總線拉低1us
                i++;
                DSPORT=1;//然后釋放總線
                i++;
                i++;//延時6us等待數據穩定
                bi=DSPORT;         //讀取數據,從最低位開始讀取
                /*將byte左移一位,然后與上右移7位后的bi,注意移動之后移掉那位補0。*/
                byte=(byte>>1)|(bi<<7);
//                i=4;                //讀取完之后等待48us再接著讀取下一個數
//                while(i--);
    EA = 1;
        return byte;
* 函數名         : Ds18b20ChangTemp
* 函數功能                   : 讓18b20開始轉換溫度
* 輸入           : com
* 輸出                  : 無
void  Ds18b20ChangTemp()
        Ds18b20Init();
        Delay1ms(1);
        Ds18b20WriteByte(0xcc);                //跳過ROM操作命令
        Ds18b20WriteByte(0x44);            //溫度轉換命令
//        Delay1ms(100);        //等待轉換成功,而如果你是一直刷著的話,就不用這個延時了
* 函數名         : Ds18b20ReadTempCom
* 函數功能                   : 發送讀取溫度命令
* 輸入           : com
* 輸出                  : 無
void  Ds18b20ReadTempCom()
        Ds18b20Init();
        Delay1ms(1);
        Ds18b20WriteByte(0xbe);         //發送讀取溫度命令
* 函數功能                   : 讀取溫度
* 輸入           : com
* 輸出                  : 無
int Ds18b20ReadTemp()
        int temp=0;
        unsigned char tmh,tml;
        Ds18b20ChangTemp();                                 //先寫入轉換命令
        Ds18b20ReadTempCom();                        //然后等待轉換完后發送讀取溫度命令
        tml=Ds18b20ReadByte();                //讀取溫度值共16位,先讀低字節
        tmh=Ds18b20ReadByte();                //再讀高字節
        temp=tmh;
        temp<<=8;
        temp|=tml;
        return temp;
溫度讀取頭文件temo.h:
#ifndef __TEMP_H_
#define __TEMP_H_
#include<reg51.h>
sbit DSPORT=P3^7;
void Delay1ms(unsigned int );
unsigned char Ds18b20Init();
void Ds18b20WriteByte(unsigned char com);
unsigned char Ds18b20ReadByte();
void  Ds18b20ChangTemp();
void  Ds18b20ReadTempCom();
int Ds18b20ReadTemp();
#endif
適用電路:
ID:564898 發表于 2019-6-26 14:32 來自觸屏版 | 只看該作者
如果你用的是12M的晶振就把復位里的低電平延時30改成70以上
ID:427818 發表于 2019-6-26 23:41 | 只看該作者
先占個位置學習
ID:207421 發表于 2019-6-27 13:48 | 只看該作者
DS18B20 讀時序要求特別高,用實際硬件來調調吧,否則都用定時器
ID:503048 發表于 2019-6-27 17:44 | 只看該作者
青青梓衿 發表于 2019-6-26 14:32
仿真可以讀出來溫度,但是一燒到單片機上就不行了,單片機是STC89C52
ID:503048 發表于 2019-6-27 17:46 | 只看該作者
現在仿真可以了,但是同樣代碼在硬件上不行
ID:401564 發表于 2019-6-28 17:03 | 只看該作者
仿真是以AT8051的12T指令運行的
STC89C52是6T指令
所有用到延時的延時時間要*2,定時器可以不用改
