查看: 2004|回復: 0
單片機+光感GY30 BH1750FVI程序Bug問題求解
ID:418269 發表于 2019-6-25 10:52 | 顯示全部樓層 |閱讀模式
使用lcd1602能讀取出數據,且光照強度有變化,但是跳變的、并不能線性變化。比如遠近光照強度是幾百的變化。
各人認為是Main 主程序& Bh1750子程序 的問題,請大神們能幫忙指正。
********************Main.c*****************************
#include <reg52.h>
extern void lcd1602init();
extern void lcd1602showStr(unsigned char x,unsigned char y,unsigned char *str);
extern unsigned int BH1750_Read(unsigned char addr);
extern void BH1750_Write(unsigned char addr,unsigned char cmd);
sbit         Bh1750_Addr=P2^4;
void Delay_1mS(unsigned char ms);
        Bh1750_Addr=0;
        unsigned int tmp;
        unsigned char val[8];
        lcd1602init();
        lcd1602showStr(0,0,"light:");
                BH1750_Write((0x23<<1),0x01);//send slaveaddr,power on
                BH1750_Write((0x23<<1),0x10);// Continuously H-resolution mode
                Delay_1mS(200);
                tmp=BH1750_Read((0x23<<1)|0x01);
                val[0]=tmp/10000 +'0';
                val[1]=tmp/1000%10 +'0';
                val[2]=tmp/100%10 +'0';
                val[3]=tmp/10%10 +'0';
                val[4]=tmp%10 +'0';
                val[5]=' ';
                val[6]='l';
                val[7]='x';
                lcd1602showStr(7,0,val);
        unsigned int i,j;
        for(i=0;i<ms;i++)
                        for(j=0;j<121;j++)
**********************BH1750.c***********************
#include <reg52.h>
extern void i2c_Star();
extern bit i2c_Write(unsigned char dat);
extern unsigned char i2c_ReadAck();
extern unsigned char i2c_ReadNack();
extern void i2c_Stop();
        i2c_Star();
        i2c_Write(addr);
        i2c_Write(cmd);
        i2c_Stop();
        unsigned int tmp;
        unsigned char MSB,LSB;
        i2c_Star();
        i2c_Write(addr);
        MSB=i2c_ReadAck();
        LSB=i2c_ReadNack();
        i2c_Stop();
        tmp=(int)MSB<<8+LSB;
        return tmp;
********************i2c.c*****************************
#include <reg52.h>
#include <intrins.h>
#define i2cDelay() {_nop_();_nop_();_nop_();_nop_();}
sbit i2c_SDA=P2^0;
sbit i2c_SCL=P2^1;
void i2c_Star()
        i2c_SDA=1;
        i2c_SCL=1;
        i2cDelay();
        i2c_SDA=0;
        i2cDelay();
        i2c_SCL=0;
        i2cDelay();
void i2c_Stop()
        i2c_SDA=0;
        i2c_SCL=0;
        i2cDelay();
        i2c_SCL=1;
        i2cDelay();
        i2c_SDA=1;
        i2cDelay();
        bit ack;
        unsigned char mask;
        for(mask=0x80;mask!=0;mask>>=1)
                if(0==(mask&dat))
                        i2c_SDA=0;
                        i2c_SDA=1;
                i2cDelay();
                i2c_SCL=1;
                i2cDelay();
                i2c_SCL=0;
                i2c_SDA=1;
                i2cDelay();
                i2c_SCL=1;
                i2cDelay();
                ack=i2c_SDA;
                i2c_SCL=0;
        return ack;
        unsigned char mask,dat=0;
                if(0==i2c_SDA)
                        dat&=~mask;// 0b0000 0000 & 0b0111 1111
                        dat|=mask;//  0b0000 0000 & 0b1000 0000
                i2cDelay();
                i2c_SCL=1;
                i2cDelay();
                i2c_SCL=0;
        i2c_SDA=0; //send ACK
        i2cDelay();
        i2c_SCL=1;        //over
        i2cDelay();
        i2c_SCL=0;
        return dat;
                if(0==i2c_SDA)
                i2cDelay();
                i2c_SCL=1;
                i2cDelay();
                i2c_SCL=0;
        i2c_SDA=1; //send NACK
        i2cDelay();
        i2c_SCL=1;        //over
        i2cDelay();
        i2c_SCL=0;
        return dat;
********************lcd1602.c*************************
#include <reg52.h>
#define lcd1602_Databus P0
sbit lcd1602_RS=P1^0;
sbit lcd1602_RW=P1^1;
sbit lcd1602_E=P2^5;
sbit Digitaltube_Dula=P2^6;
void lcd1602_ReadState()
        unsigned char state;
        Digitaltube_Dula=0xff;
        lcd1602_RS=0;
  lcd1602_RW=1;
        do{
                        lcd1602_E=1;
                  state=lcd1602_Databus;
                        lcd1602_E=0;
     }while(state&0x80);
void lcd1602WriteCommand(unsigned char cmd)
        lcd1602_ReadState();
  lcd1602_RS=0;
  lcd1602_RW=0;
  lcd1602_Databus=cmd;
  lcd1602_E=1;
  lcd1602_E=0;
void lcd1602WriteData(unsigned char dat)
  lcd1602_RS=1;
  lcd1602_RW=0;
  lcd1602_Databus = dat;
  lcd1602_E=1;
  lcd1602_E=0;
void lcd1602init()
  lcd1602_Databus=0;
  Digitaltube_Dula=0;
  lcd1602WriteCommand(0x38);
  lcd1602WriteCommand(0x0C);
  lcd1602WriteCommand(0x06);
  lcd1602WriteCommand(0x01);
void lcd1602setCursor(unsigned char x,unsigned char y)
        unsigned char addr;
  if(0==y)
                addr=0x00+x;
                addr=0x40+x;
        lcd1602WriteCommand(addr|0x80);
        lcd1602setCursor(x,y);
        while(*str!='\0')
                lcd1602WriteData(*str);
                str++;
