查看: 4637|回復: 4
單片機紅外控制燈光亮度的程序
電路原理圖如下:
  1. #include <reg51.h>
  2. #include <intrins.h>
  4. #define uint  unsigned int
  5. #define out P0
  6. #define out_led P1
  7. uchar temp=0;
  8. uint time=0;
  9. uint time_control=20;
  10. //紅外控制
  11. sbit        IR    = P3^2;
  12. unsigned char        N[4];//識別碼,操作碼存放
  13. unsigned char   X1,X2,X3,X4;
  14. sbit led1=P2^0;
  15. sbit led2=P2^1;
  16. sbit led3=P2^2;
  17. sbit led4=P2^3;
  18. sbit led5=P2^4;
  19. sbit DAC_cs=P2^6;
  20. sbit DAC_wr=P2^7;
  21. /********************** 外部中斷函數************************/
  22. void exint0() interrupt 0
  23. {
  24.    unsigned int cnt;
  25.    unsigned char i;
  26.    EX0 = 0;
  27.    cnt = 0;
  28.
  29.    while(!IR) cnt++;                               //記錄引導碼時間
  30.    if(cnt < 1000){EX0=1;return;}                   //9ms的計數值(12MHz:1000< cnt <1500)
  31.
  32.    cnt = 0;
  33.    while(IR) if(cnt++ > 400){EX0=1;return;}        //防卡死,超時保護(12MHz: > 300)
  34.    if(cnt < 200){EX0=1;return;}                    //(12MHz不分頻: <260)
  35.    for(i=0; i<32; i++)                             //讀取32位位碼
  36.        {
  37.          cnt = 0;
  38.          while(!IR);
  39.          while(IR) if(cnt++ > 200){EX0=1;return;}  //超時保護(12MHz:>=200)
  40.          N[i/8] >>= 1;
  41.          if(cnt>60) N[i/8] |= 0x80;                //0和1的計數界線(12MHz:< 109)
  42.        }
  43.         if(N[0] == ~N[1] && N[2] == ~N[3])            //校驗識別碼,操作碼
  44.         {
  45.                    X1 = N[0]/16;
  46.                 X2 = N[0]%16;
  47.                 X3 = N[2]/16;
  48.                 X4 = N[2]%16;
  49.                 switch(X4){
  50.                         case 0x01:
  51.                                    led1=~led1;
  52.                                 break;
  53.                         case 0x02:
  54.                                 led2=~led2;
  55.                                 break;
  56.                         case 0x03:
  57.                                 led3=~led3;
  58.                                 break;
  59.                         case 0x04:
  60.                                 led4=~led4;
  61.                                 break;
  62.                         case 0x05:
  63.                                 if(temp<0xff){
  64.                                         temp=temp+0x11;
  65.                                         if(time_control>50)
  66.                                         {time_control=time_control+5;}
  67.                                 }
  68.                                 break;
  69.                         case 0x06:
  70.                                 if(temp>0x44){
  71.                                         temp=temp-0x11;
  72.                                         if(time_control>5)
  73.                                         {time_control=time_control-5;}
  74.                                 }
  75.                                 break;
  76.                 }
  77.
  78.         }
  79.         EX0 = 1;
  80. }
  81. void delay(uchar n){
  82.         do{
  83.                 _nop_();
  84.                 _nop_();
  85.                 _nop_();
  86.                 n--;
  87.         }while(n);
  88. }
  89. void timer0() interrupt 3
  90. {
  91.         time++;
  92.         if(time>time_control){
  93.            led5=~led5;
  94.            time=0;
  95.         }
  96.
  97.         TH1=(65536-50000)/256;
  98.         TL1=(65536-50000)%256;
  99. }
  100. void main(){
  101.
  102.         TMOD=0x10;
  103.         TH1=(65536-5000)/256;
  104.         TL1=(65536-5000)%256;
  105.         ET1=1;
  106.         TR1=1;
  107.         IT0 = 1;
  108.         EX0 = 1;
  109.         EA  = 1;
  110.         X1=X2=X3=X4 = 0;
  111.         temp=0x44;
  112.         out_led=0xff;
  113.         while(1){
  114.                 DAC_cs=0;
  115.                 DAC_wr=0;
  116.                 DAC_cs=1;
  117.                 DAC_wr=1;
  118.
  119.                 out        =temp;
  120.                 delay(1000);
  121.         }
  122. }
  5. uint times=0;
  6. sbit led1=P1^0;
  7. sbit led2=P1^1;
  8. sbit led3=P1^2;
  9. sbit led4=P1^3;
  10. sbit ledup=P1^4;
  11. sbit leddown=P1^5;
  12. #define SBM   0x80                //識別碼
  13. #define m9    (65536-9000)               //約9mS
  14. #define m4_5  (65536-4500)               //約4.5mS
  15. #define m1_6  (65536-1630)               //約1.65mS
  16. #define m_65  (65536-580)               //約0.65mS
  17. #define m_56  (65536-560)               //約0.56mS
  18. #define m40   (65536-40000)       //約40mS
  19. #define m56   (65536-56000)       //56mS
  20. #define m2_25 (65536-2250)        //約2.25mS
  21. sbit IR  = P3^6;                                  //定義發射引腳(接PNP三極管基極)
  22. uchar KEY(void);
  23. void  SanZhuan(void);
  24. void  ZZ(uchar x);
  25. void  Z0(uchar temp);
  26. void  TT0(bit BT,uint x);
  27. void  YS(uchar time);
  28. void delay(unsigned char n){
  29.         do{
  30.                 _nop_();
  31.                 _nop_();
  32.                 _nop_();
  33.                 n--;
  34.         }while(n);
  35. }
  36. /*┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈
  37. 函數功能:主函數
  38. ┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈*/
  39. void main(void)
  40. {
  41.   TMOD = 0x01;         //T0 16位工作方式
  42.   IR=1;                                   //發射端口常態為高電平
  43.   while(1)
  44.   {
  45.    SanZhuan();
  46.   }
  47. }
  48. uchar KEY(void)
  49. {
  50.         P1 = 0xff;            //將鍵盤端口行值設為1,列值設為0
  51.          if(led1==0){
  52.                   return 1;
  53.          }else if(led2==0){
  54.                    return 2;
  55.          }else if(led3==0){
  56.                    return 3;
  57.          }else if(led4==0){
  58.                    return 4;
  59.          }else if(ledup==0){
  60.                    return 5;
  61.          }else if(leddown==0){
  62.                    return 6;
  63.          }
  64.   return 0;
  65. }
  66. /***************************************************************
  67. 函數功能:散轉程序
  68. 入口參數:v
  69. //
  70. //  13 14 15 16
  71. //  9  10 11 12
  72. //  5  6  7  8
  73. //  1  2  3  4
  74. ***************************************************************/
  75. void SanZhuan(void)
  76. {
  77. uchar v;
  78. v = KEY();
  79. switch(v)
  80. {
  81.   case 1:ZZ(0x01);v=0;break;                //"  "
  82.   case 2:ZZ(0x02);v=0;break;                //"  "
  83.   case 3:ZZ(0x03);v=0;break;                //"  "
  84.   case 4:ZZ(0x04);v=0;break;                //"  "
  85.   case 5:ZZ(0x05);v=0;break;                //"  "
  86.   case 6:ZZ(0x06);v=0;break;                //"  "
  87.   default:v=0;
  88. }
  89. }
  90. /*┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈
  91. 函數功能:發送主程序
  92. ┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈*/
  93. void ZZ(uchar x)
  94. {
  95.   TT0(1,m9);                   //高電平9mS
  96.   TT0(0,m4_5);               //低電平4.5mS
  97.   /*┈ 發送4幀數據 ┈*/
  98.         Z0(SBM);
  99.         Z0(~SBM);
  100.
  101.   Z0(x);
  102.   Z0(~x);
  103.   /*┈┈ 結束碼 ┈┈*/
  104.   TT0(1,m_65);
  105.   TT0(0,m40);
  106.   /*┈┈ 重復碼 ┈┈*/
  107.   while(KEY())
  108.    {
  109.         TT0(1,m9);
  110.         TT0(0,m2_25);
  111.         TT0(1,m_56);
  112.         TT0(0,m40);
  113.                 TT0(0,m56);
  114.
  115.     }
  116.
  117. }
  118. /*┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈
  119. 函數功能:單幀發送程序
  120. 入口參數:1幀數據
  121. ┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈*/
  122. void Z0(uchar temp)
  123. {
  124.   uchar v;
  125.   for (v=0;v<8;v++)                     //循環8次移位
  126.        {
  127.                  TT0(1,m_65);                        //高電平0.65mS
  128.                          if(temp&0x01) TT0(0,m1_6); //發送最低位
  129.                          else          TT0(0,m_56);
  130.                          temp >>= 1;                //右移一位
  131.         }
  132. }
  133. /*┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈
  134. 函數功能:38KHz脈沖發射 + 延時程序
  135. 入口參數:(是否發射脈沖,延時約 x (uS))
  136. ┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈┈*/
  137. void TT0(bit BT,uint x)
  138. {
  139.   TH0 = x>>8;                    //輸入T0初始值
  140.   TL0 = x;
  141.   TF0=0;                                //清0
  142.   TR0=1;                                //啟動定時器0
  143.   if(BT == 0) while(!TF0);        //BT=0時不發射38KHz脈沖只延時;BT=1發射38KHz脈沖且延時;
  144.   else while(1)                            //38KHz脈沖,占空比5:26
  145.          {
  146.                   IR = 0;
  147.                   if(TF0)break;
  148.                if(TF0)break;
  149.                   IR = 1;
  150.                 if(TF0)break;
  151.                  if(TF0)break;
  152.                  if(TF0)break;
  153.                   if(TF0)break;
  154.                  if(TF0)break;
  155.                  if(TF0)break;
  156.                  if(TF0)break;
  157.                  if(TF0)break;
  158.                  if(TF0)break;
  159.                   if(TF0)break;
  160.                  }
  161.   TR0=0;                                //關閉定時器0
  162.   TF0=0;                                //標志位溢出則清0
  163.   IR =1;                                //脈沖停止后,發射端口常態為高電平
  164. }
  165. /***************************************************************
  166. 函數功能:按鍵消抖    延時程序
  167. 入口參數:1ms×time       (晶振=12MHz)
  168. ***************************************************************/
  169. void YS(uchar time)
  170. {
  171.      uchar i,j;
  172.          for(i=0; i<time; i++)
  173.      for(j=0; j<247; j++)_nop_();
  174. }
收藏收藏3 分享淘帖 頂 踩
ID:328014 發表于 2019-6-17 00:38 | 只看該作者
好資料,求仿真工程啊
ID:547295 發表于 2019-6-17 09:37 | 只看該作者
忘了放程序了。。。。
ID:489376 發表于 2019-6-18 23:48 | 只看該作者
wongj 發表于 2019-6-17 09:37
忘了放程序了。。。。
放啊............
ID:27161 發表于 2021-5-14 11:42 | 只看該作者
這個發射程序為何在STC15F100系列無法正常工作啊,誰能說一下咋樣改才可以用?測試了stc89c52rc可以正常使用,紅外發射管也可以指定另外端口。
