查看: 3382|回復: 5
關于單片機執行兩個中斷的問題
ID:561156 發表于 2019-6-13 09:40 | 顯示全部樓層 |閱讀模式
我做了一個da的中斷,一個ad的中斷,現在我想通過外接按鍵控單片機執行其中某一個中斷,但是仿真只執行其中da的中斷,我是初學者,請大神指導。我同學說可以用中斷嵌套,但是我不會這個。
下面是程序清單:
#include<reg51.h>
#include<math.h>
#define DAC_PORT P2
sbit DAC_CS_WR=P3^0;
sbit K1=P1^5;
sbit K2=P1^6;
sbit K3=P1^7;
sbit K4=P3^3;
sbit K5=P3^2;
sbit P10=P1^0;
sbit P11=P1^1;
sbit P12=P1^2;
#include<intrins.h>
#include<tlc0832.c>
#define nop  _nop_()
sbit CS = P3^0;
sbit CLK = P3^1;
sbit DIDO = P3^7;
code uchar seven_seg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar cp1,cp2,dat_ad;
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
u8 mode;
u8 time;
u8 AM;
void Timer0Int(void);
void scanKey(void);
void sys_int(void);
void squ_wave(u8 location);
void tri_wave(u8 location);
void tra_wave(u8 location);
void saw_wave(u8 location);
//Ä£êy×a»»
void tlc0832_init(void)
        CS = 1;nop;
        CLK = 1;
        CS = 0;
uchar tlc0832_ch0(void)
        uchar dat1,i;
        tlc0832_init();
        DIDO = 1;CLK = 0;nop;CLK = 1;nop;
        DIDO = 0;CLK = 0;nop;CLK = 1;nop;
        DIDO = 1;
        for(i = 0;i<=8;i++)
dat1 = dat1<<1;
                CLK = 0;nop;
                if(DIDO)dat1 = dat1|0x01;
                CLK = 1;nop;
        return(dat1);
        CS = 1;
void timer0_init()        {
        TMOD = 0x01;
        TL1 = 0x78;
        TH1 = 0xec;
        EA = 1;
        TR1 = 1;
        ET1 = 1;
void timer0_isr()interrupt 0
        TL1 = 0x78;
        TH1 = 0xec;
        cp1++;
        if(cp1>100)                                                //0.5s
                cp1 = 0;
                dat_ad=tlc0832_ch0();
        P0 = 0xff;
        cp2++;
        if(cp2>=3)
        cp2 = 0;
        switch(cp2)
                case 0:P0 = seven_seg[dat_ad%10];P10=1,P11=0,P12=0;break;
            case 1:P0 = seven_seg[dat_ad%100/10];P10=0,P11=1,P12=0;break;
                case 2:P0 = seven_seg[dat_ad/100];P10=0,P11=0,P12=1;break;
//êyÄ£×a»»
        TMOD &= 0xF0;
        TMOD |= 0x02;
        TL0 = 0x9C;
        TH0 = 0x9C;
        TF0 = 0;
        TR0 = 1;
        EA = 1;
        ET0 = 1;
void scanKey(void)
        if(K1==0)
                mode=1;
        if(K2==0)
                mode=2;
        if(K3==0)
                mode=3;
void sys_int(void)
        time=0;
        DAC_CS_WR=0;
        DAC_PORT=0;
        mode=0;
        AM=255;
        if(location<50)
                DAC_PORT=AM;
                DAC_PORT=0x00;
        u8 y;
        if(location<50)
                y=(50-location)*AM/50;
                y=(location-50)*AM/50;
        DAC_PORT=y;
        DAC_PORT=location*AM/100;
void Timer0Work() interrupt 2
        switch(mode)
            case 1:squ_wave((u8) time);break;
                case 2:tri_wave((u8) time);break;
                case 3:saw_wave((u8) time);break;
        time++;
        if(time>=100)
                time=0;
void IntConfiguration()
        IT0=1;
        EX0=1;
        PX0=0;
        IT1=1;
        EX1=1;
        PX1=1;
        EA=1;
int main(void)
        IntConfiguration();
                if(K4==0){
        sys_int();
        Timer0Int();
           scanKey();
if(K5==0){
                tlc0832_init();
        timer0_init();
仿真圖:
ID:332444 發表于 2019-6-13 16:15 | 顯示全部樓層
主函數加:bit k;然后判斷K4按下K=1,K5按下K=0,然后判斷K去執行不同的模塊,你那樣寫肯定是不行的,除非你按鍵一直按下不動。
  1. int main(void)
  2. {
  3. bit k;
  4. IntConfiguration();
  5.
  6. if(K4==0)k=1;
  7. if(K5==0)k=0;
  8.          while(1)
  9.          {
  10.             scanKey();
  11.                          if(k){         sys_int();         Timer0Int();}
  12. else{                 tlc0832_init();         timer0_init();}
  13.                                  }
  14.
  15.
  16.
  17.
  18.                          }
ID:158375 發表于 2019-6-13 16:39 | 顯示全部樓層
說說你想要做什么?
ID:561156 發表于 2019-6-13 21:35 | 顯示全部樓層
笨笨兔 發表于 2019-6-13 16:39
說說你想要做什么?
我的單片機外部中斷接了兩個按鍵,我想通過按下上面的按鍵執行ad轉換的中斷,按下下面的按鍵執行da轉換的中斷
ID:158375 發表于 2019-6-14 12:56 | 顯示全部樓層
你設3個標志位:KEY_FLAG,AD_FLAG.DA_FLAG,有標志是執行,無標志時不執行。
按鍵確認后,根據鍵值來規定設定AD_FLAG = 1 或 0,DA_FLAG相同處理。你可以中段允許、禁止或者用程序來控制
沒看你程序,只是給你個思路。
ID:561156 發表于 2019-6-14 22:22 | 顯示全部樓層
笨笨兔 發表于 2019-6-14 12:56
按鍵確認后,根據鍵值來規定設 ...
好的,謝謝。我去試試
