查看: 1876|回復: 3
寫入的溫控程序為什么單片機讀不了ds18b20數據顯示000.0采用STC89C52RC單片機12M晶振
#include<reg52.h>
#include<intrins.h>
#include<wendu.h>
sbit key1=P3^4;
sbit key2=P3^5;
sbit key3=P3^6;
sbit led=P3^3;
sbit shenwen=P1^5;
sbit jiangwen=P1^6;
uchar code tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x40,0x00,0x40,0x38,0x76};
uchar code tab3[]={0xBF,0x86,0xDB,0xCF,0xE6,0xED,0xFD,0x87,0xFF,0xEF,0xC0,0x00};
uchar yi,er,san,si,san1;
uint shangxian=30,xiaxian=0,flag=0;
void delay(int ma);
void display1(uchar yi,uchar er,uchar san,uchar si);
void display2(uchar yi,uchar er,uchar san1,uchar si);
void keyscan();
          float wendu=0;
          int wenduzhen=0;
          yi=11;er=11;san=11;si=11;
          jiangwen=shenwen=1;//繼電器
                  keyscan();
                  if(flag==0)//溫度測試界面
                          wendu=temget();
                          if(wendu<xiaxian)   //升溫
                                          shenwen=0;
                                        jiangwen=1;
                          else if((wendu>=xiaxian) && (wendu<=shangxian) )        //實際溫度處于保溫范圍
                                          shenwen=1;           //繼電器初始化
                                        delay(5);
                                        jiangwen=1;
                                        delay(5);
                          else if(wendu>=shangxian)    //降溫開啟,燒水功能關閉
                                          shenwen=1;
                                        jiangwen=0;
                          wenduzhen=wendu*10;
                      yi=wenduzhen/1000;
                          er=wenduzhen%1000/100;
                          san=wenduzhen%100/10;
                          si=wenduzhen%10;
                          display1(yi,er,san,si);
                  else         if(flag==2)//溫度下限設置界面
                           yi=13;er=12;
                          xiaxian=shangxian-2;
                      san1=xiaxian%100/10;
                      si=xiaxian%10;
                          display2(yi,er,san1,si);
                  else         if(flag==1)//溫度上限設置界面
                           yi=14;er=12;
                      san1=shangxian%100/10;
                      si=shangxian%10;
//                  if(xiaxian>=shangxian)led=0;//下限超過上限led亮
//                  else led=1;
void keyscan()
        if(key1==0)//設置界面
                delay(5);
                if(key1==0)
                  flag++;
                  if(flag>2)flag=0;
                while(!key1);
          if(key2==0)//加數值
                delay(5);
                if(key2==0)
                          if(flag==1)
                                shangxian++;
                                if(shangxian>90)shangxian=0;
                        else if(flag==2)
                                xiaxian++;
                                if(xiaxian>89)shangxian=0;
                while(!key2);
        if(key3==0)//減數值
                delay(5);
                if(key3==0)
                          if(flag==1)
                                shangxian--;
                                if(shangxian<1)xiaxian=1;
                        else if(flag==2)
                                xiaxian--;
                                if(shangxian<0)xiaxian=0;
                while(!key3);
                P2=0XBF;
                P0=tab[yi];
                delay(1);
                P2=0XF7;
                P0=tab[er];
                delay(1);
                P2=0XEF;
                P0=tab3[san];
                delay(1);
                P2=0XDF;
                P0=tab[si];
                delay(1);
                P2=0XBF;
                P0=tab[yi];
                delay(1);
                P2=0XF7;
                P0=tab[er];
                delay(1);
                P2=0XEF;
                P0=tab[san1];
                delay(1);
                P2=0XDF;
                P0=tab[si];
                delay(1);
void delay(int ms)
                int i,a;
                for(i=ms;i>0;i--)
                  for(a=125;a>0;a--);
#include<reg52.h>
#include<intrins.h>
#include<wendu.h>
uchar temget()
    uchar low,high;
    int temp;
        float temperature;
        dsinit();
        write(0xcc);
        write(0x44);
        Delay_us(100);
        dsinit();
        write(0xcc);
        write(0xbe);
        Delay_us(100);
    low=read();
        high=read();
        temp=((high<<8)|low);
        temperature=temp*0.0625;//分辨率是0.0625
//        temp=high<<4;
//        temp|=(low>>4);        //顯示整數
    return temperature;
uchar read()
        uchar i;
        uchar dat;
        for(i=0;i<8;i++)
                DQ=0;
                _nop_();_nop_();_nop_();_nop_();_nop_();
                dat>>=1;
                DQ=1;
                if(DQ==1)
                                dat|=0x80;
                Delay_us(100);
        return dat;
void write(uchar dat)
                uchar i;
                for(i=0;i<8;i++)
                                DQ=0;
                                DQ=dat&0x01;
                                Delay_us(70);
                                DQ=1;
                                dat>>=1;
void dsinit()
                DQ=0;
                Delay_us(80);
                DQ=1;
                Delay_us(80);
void Delay_us(uchar us)
        while(us--);
#include<reg52.h>
sbit DQ=P1^7;
uchar temget();
void write(uchar dat);
uchar read();
void dsinit();
void Delay_us(uchar us);
ID:445575 發表于 2019-6-11 23:58 | 只看該作者
仿真軟件能讀取溫度且顯示,在硬件電路就出問題了,其他功能都正常
ID:514901 發表于 2019-6-12 21:20 | 只看該作者
既然仿真沒問題,那程序就應該沒有多大問題,大概是電路問題,我猜是與DS18B20的IO口沒接上拉電阻
ID:520590 發表于 2019-6-12 22:13 | 只看該作者
可能硬件問題,有接上拉電阻嗎
