查看: 1378|回復: 1
ATmega16計算器
ID:559256 發表于 2019-6-11 22:00 | 顯示全部樓層 |閱讀模式
#define No_key     255
#define K1_1    1
#define K1_2    2
#define K1_3    3
#define K1_4    4
#define K2_1    5
#define K2_2    6
#define K2_3    7
#define K2_4    8
#define K3_1    9
#define K3_2    0
#define K3_3    10
#define K3_4    11
#define K4_1    12
#define K4_2    13
#define K4_3    14
#define K4_4    15
#define Key_mask    0b00001111
unsigned char read_keyboard()
    static unsigned char key_state = 0, key_value, key_line;
    unsigned char key_return = No_key,i;
    switch (key_state)
        case 0:
            key_line = 0b00001000;
            for (i=1; i<=4; i++)                    // 掃描鍵盤
                PORTD = ~key_line;                    // 輸出行線電平
                PORTD = ~key_line;                    // 必須送2次!!!
                key_value = Key_mask & PIND;        // 讀列電平
                if (key_value == Key_mask)
                    key_line <<= 1;                // 沒有按鍵,繼續掃描
                    key_state++;                    // 有按鍵,停止掃描
                    break;                        // 轉消抖確認狀態
            break;
        case 1:
            if (key_value == (Key_mask & PIND))        // 再次讀列電平,
                switch (key_line | key_value)        // 與狀態0的相同,確認按鍵
                {                                // 鍵盤編碼,返回編碼值
                    case 0b00001110:
                        key_return = K1_1;
                        break;
                    case 0b00001101:
                        key_return = K1_2;
                        break;
                     case 0b00001011:
                        key_return = K1_3;
                        break;
                    case 0b00000111:
                        key_return = K1_4;
                        break;
                     case 0b00011110:
                        key_return = K2_1;
                        break;
                     case 0b00011101:
                        key_return = K2_2;
                        break;
                    case 0b00011011:
                        key_return = K2_3;
                        break;
                    case 0b00010111:
                        key_return = K2_4;
                        break;
                     case 0b00101110:
                        key_return = K3_1;
                        break;
                     case 0b00101101:
                        key_return = K3_2;
                        break;
                    case 0b00101011:
                        key_return = K3_3;
                        break;
                    case 0b00100111:
                        key_return = K3_4;
                        break;
                    case 0b01001110:
                        key_return = K4_1;
                        break;
                    case 0b01001101:
                        key_return = K4_2;
                        break;
                    case 0b01001011:
                        key_return = K4_3;
                        break;
                     case 0b01000111:
                        key_return = K4_4;
                        break;
                key_state++;                // 轉入等待按鍵釋放狀態
                key_state--;                // 兩次列電平不同返回狀態0,(消抖處理)
            break;
        case 2:                            // 等待按鍵釋放狀態
            PORTD = 0b00000111;            // 行線全部輸出低電平
            PORTD = 0b00000111;            // 重復送一次
            if ( (Key_mask & PIND) == Key_mask)
                key_state=0;                // 列線全部為高電平返回狀態0
            break;
    return key_return;
ID:1 發表于 2019-6-12 06:29 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
