只需一步,快速開(kāi)始
查看: 3289|回復(fù): 2
STM32壓力計(jì)程序與C#上位機(jī)代碼
stm32上位機(jī)壓力計(jì)上位機(jī)源程序
C#源程序:
  1. using System;
  2. using System.Collections.Generic;
  3. using System.ComponentModel;
  4. using System.Data;
  5. using System.Drawing;
  6. using System.Linq;
  7. using System.Text;
  8. using System.Windows.Forms;
  9. using System.Diagnostics;
  10. using Microsoft.Win32;
  11. using System.Text.RegularExpressions;
  12. using System.Data.SqlClient;
  13. using System.Threading;
  14. using System.Data.OleDb;
  15. using System.Windows.Forms.DataVisualization.Charting;
  16. using System.IO.Ports;//
  17. namespace coursedesign
  18. {
  19.     public partial class Form1 : Form
  20.     {
  21.         const float high =1700;
  22.         const float low =1400;
  23.         double[] data = new double[50];
  24.         Series ss = new Series("壓力");
  25.         public SerialPort port1 = new SerialPort("COM5", 9600, Parity.None, 8, StopBits.One);
  26.         public Form1()
  27.         {
  28.             InitializeComponent();
  29.         }
  30.
  31.         private void Form1_Load(object sender, EventArgs e)
  32.         {
  33.             chart1.Series.Clear();
  34.             ss.ChartType = SeriesChartType.Spline;   //設(shè)置Y軸為折線
  35.             chart1.ChartAreas[0].AxisX.MajorGrid.Enabled = false;
  36.         }
  37.         private void button3_Click(object sender, EventArgs e)
  38.         {
  39.             if (textBox2.Text == "")
  40.             {
  41.                 MessageBox.Show("請(qǐng)輸入壓力值");
  42.                 return;
  43.             }
  44.             try
  45.             {
  46.                 float num1 = float.Parse(textBox2.Text);
  47.                 update(num1);
  48.             }
  49.             catch (Exception ee)
  50.             {
  51.                 MessageBox.Show("上傳失敗\n" + ee.ToString());
  52.                 Debug.Write(ee.ToString());
  53.             }
  54.         }
  55.         //打來(lái)畫(huà)圖定時(shí)器
  56.         private void button4_Click(object sender, EventArgs e)
  57.         {
  58.             timer1.Start();
  59.         }
  60.         //畫(huà)圖
  61.         private void timer1_Tick(object sender, EventArgs e)
  62.         {
  63.             //從數(shù)據(jù)庫(kù)讀取數(shù)據(jù)
  64.             GetRecord();
  65.             //更新曲線
  66.             chart1.Series.Clear();
  67.             ss.Points.DataBindY(data);
  68.             chart1.Series.Add(ss);
  69.         }
  70.         //打開(kāi)串口
  71.         private void button1_Click(object sender, EventArgs e)
  72.         {
  73.             try
  74.             {
  75.                 port1.Open();
  76.             }
  77.             catch (Exception ee)
  78.             {
  79.                 MessageBox.Show("串口打開(kāi)失敗\n" + ee.ToString());
  80.             }
  81.             Thread.Sleep(500);
  82.             timer2.Start();
  83.         }
  84.         //定時(shí)器定時(shí)讀取串口緩沖區(qū)數(shù)據(jù)
  85.         private void timer2_Tick(object sender, EventArgs e)
  86.         {
  87.             if (port1.IsOpen)
  88.             {
  89.                 byte[] data = new byte[0];
  90.                 int iByteLen = port1.BytesToRead;
  91.                 Debug.WriteLine(iByteLen.ToString());
  92.                 try
  93.                 {
  94.                     if (iByteLen > 0)
  95.                     {
  96.                         data = new byte[iByteLen];
  97.                         port1.Read(data, 0, iByteLen);
  98.                     }
  99.                     String received = Encoding.ASCII.GetString(data);
  100.                     Debug.WriteLine(received);
  101.                     textBox1.AppendText(DateTime.Now.ToString("yyyy-MM-dd HH:mm:ss") + "  " + Encoding.ASCII.GetString(data) + "\n");
  102.                     byte[] command = { 0x02, 0x33, 0x3c, 0x0d, 0x0a };
  103.                     string[] sa = received.Split(':');
  104.                     string[] svalue = sa[1].Split(' ');
  105.                     float value = float.Parse(svalue[0]);
  106.                     //上傳到數(shù)據(jù)庫(kù)
  107.                     update(value);
  108.                     Image l1 = Image.FromFile("level1.jpg");
  109.                     Image l2 = Image.FromFile("level2.jpg");
  110.                     Image l3 = Image.FromFile("level3.jpg");
  111.                     if (value > high)
  112.                     {
  113.                         pictureBox2.Image = l1;
  114.                         command[0] = 0x01;
  115.                     }
  116.                     else if (value > low)
  117.                     {
  118.                         pictureBox2.Image = l2;
  119.                     }
  120.                     else
  121.                     {
  122.                         pictureBox2.Image = l3;
  123.                         command[0] = 0x01;
  124.                     }
  125.                     //向下位機(jī)發(fā)送控制命令
  126.                     port1.Write(command, 0, command.Length);
  127.                 }
  128.                 catch (Exception ee)
  129.                 {
  130.                     Debug.WriteLine(ee.ToString());
  131.                 }
  132.             }
  133.         }
  134.         //上傳數(shù)據(jù)庫(kù)
  135.         private void update(double newv)
  136.         {
  137.             try
  138.             {
  139.                 string reportPath = "temp.accdb";
  140.                 string ConStr = "Provider=Microsoft.ACE.OLEDB.12.0;" + @"Data Source=" + reportPath;
  141.                 OleDbConnection con = new OleDbConnection(ConStr); //創(chuàng)建OleDbConnection對(duì)象,連接
  142.                 con.Open();
  143.                 string strSql = "Insert Into temp(yali) Values('" + newv.ToString() + "')";
  144.                 OleDbCommand oleDbCommand = new OleDbCommand(strSql, con);
  145.                 oleDbCommand.ExecuteNonQuery();
  146.                 con.Close();//關(guān)閉連接
  147.             }
  148.             catch (Exception ee)
  149.             {
  150.                 Debug.WriteLine(ee.ToString());
  151.             }
  152.         }
  153.         //從數(shù)據(jù)庫(kù)獲取最新的數(shù)據(jù)
  154.         public void GetRecord()
  155.         {
  156.             try
  157.             {
  158.                 string reportPath = "temp.accdb";
  159.                 string ConStr = "Provider=Microsoft.ACE.OLEDB.12.0;" + @"Data Source=" + reportPath;
  160.                 OleDbConnection con = new OleDbConnection(ConStr); //創(chuàng)建OleDbConnection對(duì)象,連接
  161.                 con.Open();
  162.                 string sql = "select top 50 * from temp order by ID desc ";
  163.                 OleDbDataAdapter dbDataAdapter = new OleDbDataAdapter(sql, con); //創(chuàng)建適配對(duì)象
  164.                 DataTable dt = new DataTable();
  165.                 dbDataAdapter.Fill(dt);
  166.                 int i = 49;
  167.                 foreach (DataRow item in dt.Rows)
  168.                 {
  169.                     data[i] = double.Parse(item[1].ToString());
  170.                     i--;
  171.                 }
  172.             }
  173.             catch (Exception ee)
  174.             {
  175.                 Debug.WriteLine(ee.ToString());
  176.             }
  177.         }
  178.     }
  179. }
單片機(jī)源程序如下:
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "sys.h"
  4. #include "usart.h"
  5. #include "lcd.h"
  6. #include "timer.h"
  7. #include "HX711.h"
  8. /********電路連接*****/
  9. //PC1   <---->   Buzzer
  10. //PC4   <---->   SCK
  11. //PC5   <---->   DOUT
  12. int main(void)
  13. {
  14.         u8 dis[30];
  15.   u8 len;
  16.
  17.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);         //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
  18.         delay_init();                     //延時(shí)函數(shù)初始化
  19.         uart_init(9600);                 //串口初始化為9600
  20.         LED_Init();                                  //初始化與LED連接的硬件接口
  21.         LCD_Init();
  22.         POINT_COLOR=RED;
  23.   LCD_Clear(WHITE);
  24.         BUZZER_ON();
  25.         delay_ms(2000);
  26.          BUZZER_OFF();
  27.   printf("SUCCESS\n");
  28.
  29.         Init_HX711pin();
  30.         Get_Maopi();                                //稱(chēng)毛皮重量
  31.         delay_ms(1000);
  32.         delay_ms(1000);
  33.         Get_Maopi();                                //重新獲取毛皮重量
  34.
  35.         POINT_COLOR=RED;
  36.         LCD_ShowString(30,40,200,24,24,"C# & STM32");
  37.         LCD_ShowString(30,70,200,24,24,"Pressure Gauge");
  38.         POINT_COLOR=BLACK;
  39.         LCD_ShowString(30,110,200,16,16,"Weight(g):");                //
  40.
  41.         while(1)
  42.         {
  43.
  44.                 Get_Weight();
  45.
  46.                 LCD_ShowxNum(90,140,Weight_Shiwu,4, 16, 0);
  47.                 printf("Weight:%d g\r\n",Weight_Shiwu); //打印
  48.
  49.                 delay_ms(700);
  50.
  51.                 //接收指令處理
  52.                 if(USART_RX_STA&0x8000)
  53.                 {
  54.                         len=USART_RX_STA&0x3fff;//得到此次接收到的數(shù)據(jù)長(zhǎng)度
  55.                         if(USART_RX_BUF[0] == 0x01)
  56.                         {
  57.                                 BUZZER_ON();
  58.                                 LED_ON();
  59.                         }
  60.                         else
  61.                         {
  62.                                 BUZZER_OFF();
  63.                                 LED_OFF();
  64.                         }
  65.
  66.                         USART_RX_STA=0;
  67.                 }
  68.         }
  69. }
下位機(jī)-壓力計(jì).7z (226.99 KB, 下載次數(shù): 26)
coursedesign_1012.zip (206.44 KB, 下載次數(shù): 31)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
ID:561245 發(fā)表于 2019-6-24 19:45 | 只看該作者
學(xué)習(xí)學(xué)習(xí)~~~~~~~~~~~~~~~~~~~~
ID:558459 發(fā)表于 2019-7-13 13:31 | 只看該作者
