LM75A就很好,11bit精度,iic的協議,不到一塊錢的價格,采樣時間比18b20低很多————————————LM75A:高速I2C總線接口,有A2-A0地址線,一條總線上最多可同時使用8個LM75A;低功耗設計,工作電流典型值為250uA,掉電模式為3.5uA;測量的溫度最大范圍為-55℃~+125℃;寬工作電壓范圍:2.8V~5.5V;提供了良好的溫度精度(0.125℃);可編程溫度閾值和滯后設定點!賮硪粋13bit的DS1624也是IIC協議的,13bit,測量精度0.03125°C,大概三四塊的價格FEATURES Temperature measurements require no external components Measures temperatures from -55°C to +125°C in 0.03125°C increments. Fahrenheit equivalent is -67°F to +257°F in 0.05625°F increments Temperature is read as a 13-bit value (two byte transfer) Converts temperature to digital word in 1 second (max) 256 bytes of E2 memory on board for storing information such as frequency compensation coefficients Data is read from/written via a 2-wire serial interface (open drain I/O lines)
