查看: 1829|回復: 2
stm32 f1 超聲波程序
ID:555922 發表于 2019-6-5 19:46 | 顯示全部樓層 |閱讀模式
#include "delay.h"
#include "sys.h"
#include "usart.h"
#include "led.h"
#include "key.h"
硬件連接
串口1:RX PA10  TX PA9
超聲波:Trig PB11    ECHG PB10
備注:以下代碼非原創,只是經過修改適配成STM32F103C8T6
若侵權,請告知。
//超聲波硬件接口定義
#define HCSR04_PORT     GPIOB
#define HCSR04_CLK      RCC_APB2Periph_GPIOB
#define HCSR04_TRIG     GPIO_Pin_11
#define HCSR04_ECHO     GPIO_Pin_10
//超聲波計數
u16 msHcCount = 0;
//定時器4設置
void hcsr04_NVIC()
        NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
//IO口初始化 及其他初始化
void Hcsr04Init()
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    RCC_APB2PeriphClockCmd(HCSR04_CLK, ENABLE);
    GPIO_InitStructure.GPIO_Pin =HCSR04_TRIG;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
    GPIO_ResetBits(HCSR04_PORT,HCSR04_TRIG);
    GPIO_InitStructure.GPIO_Pin =   HCSR04_ECHO;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_ResetBits(HCSR04_PORT,HCSR04_ECHO);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
    TIM_DeInit(TIM2);
    TIM_TimeBaseStructure.TIM_Period = (1000-1);
    TIM_TimeBaseStructure.TIM_Prescaler =(72-1);
    TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
    TIM_ClearFlag(TIM4, TIM_FLAG_Update);
    TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);
    hcsr04_NVIC();
    TIM_Cmd(TIM4,DISABLE);
//打開定時器4
static void OpenTimerForHc()
   TIM_SetCounter(TIM4,0);
   msHcCount = 0;
   TIM_Cmd(TIM4, ENABLE);
//關閉定時器4
static void CloseTimerForHc()
   TIM_Cmd(TIM4, DISABLE);
//定時器4終中斷
void TIM4_IRQHandler(void)
   if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
       TIM_ClearITPendingBit(TIM4, TIM_IT_Update  );
       msHcCount++;
//獲取定時器4計數器值
u32 GetEchoTimer(void)
   u32 t = 0;
   t = msHcCount*1000;
   t += TIM_GetCounter(TIM4);
   TIM4->CNT = 0;
   delay_ms(50);
   return t;
//通過定時器4計數器值推算距離
float Hcsr04GetLength(void )
   u32 t = 0;
   int i = 0;
   float lengthTemp = 0;
   float sum = 0;
   while(i!=5)
      TRIG_Send = 1;
      delay_us(20);
      TRIG_Send = 0;
      while(ECHO_Reci == 0);
      OpenTimerForHc();
      i = i + 1;
      while(ECHO_Reci == 1);
      CloseTimerForHc();
      t = GetEchoTimer();
      lengthTemp = ((float)t/58.0);//cm
      sum = lengthTemp + sum ;
    lengthTemp = sum/5.0;
    return lengthTemp;
//測試主函數
int main(void)
         float length;
         delay_init();                     //延時函數初始化
         NVIC_Configuration();          //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
         uart_init(9600);                 //串口初始化為9600
         Hcsr04Init();
         printf("大海電子串口測試\r\n");
   Hcsr04Init();
   printf("超聲波初始化成功!\n");
     length = Hcsr04GetLength();
     printf("距離為:%.3fcm\n",length);
                 delay_ms(1000);
ID:496481 發表于 2019-6-14 21:51 | 顯示全部樓層
能問下你這些的主函數是不是少了一些 ,打開定時器和關閉定時器能不用外部中斷嗎,就IO口判斷行嗎?定時器4的終端是干什么用的
ID:588621 發表于 2019-8-2 18:50 來自觸屏版 | 顯示全部樓層
704597517 發表于 2019-6-14 21:51
能問下你這些的主函數是不是少了一些 ,打開定時器和關閉定時器能不用外部中斷嗎,就IO口判斷行嗎?定時器4 ...
你有好的實現方案程序嗎,可不可以參考下
