直流簡易電子負(fù)載
2019-6-7 05:34 上傳
ADC+負(fù)載+按鍵 +485+串口_最終版程序
單片機(jī)源程序如下:
- #include "config.h"
- #include "adc.h"
- #include "delay.h"
- #include "soft_uart.h"
- #include "lcd.h"
- #include "PWM.h"
- #include "intrins.h"
- #include "usart.h"
- /************* 按鍵******************************************************/
- sbit k1=P3^6; //定義P3.3口是k1
- sbit k2=P3^5; //定義P3.3口是k1
- sbit k3=P3^4; //定義P3.3口是k1
- sbit k4=P3^3; //定義P3.3口是k1
- sbit fan=P3^2; //定義P3.3口是k1
- int results=0;
- int DUTY,ierr=0,resulti=0;
- int num=0;
- int resultv=0;
- int cusor=0;
- int send_mode=0,receive_mode=0;
- void modbushandle1(void);
- void modbushandle2(void);
- void modbushandle3(void);
- void modbushandle4(void);
- void modbushandle5(void);
- void modbushandle6(void);
- void Uart3s(void);
- extern u8 ch;
- extern int modflag;
- extern u8 mtx[100],mrx[100];
- extern u16 send_I_V_P[50]; //4 發(fā)送電流電壓功率值
- extern u16 bitsend[50]; //2 讀過壓保護(hù)狀態(tài)
- extern u16 bitworkflag[50]; //1 5 啟停標(biāo)志位
- extern u16 set_current[50]; //3 6設(shè)定電流值
- unsigned int set_dis[4]={0,0,0,0};
- unsigned int a[9];//={0,0}
- unsigned int i;//,resultsvol,resultscur, u2summean,i2summean,u2sum,i2sum,u2num;
- extern unsigned char receiver_buf;
- void display(); //顯示程序聲明
- void keyscan();
- void voltage_test()
- if(resultv>5500)
- bitworkflag[0]=0;
- DUTY=0;
- bitsend[0]=1;
- void main()
- P2M1=0X00;
- P2M0=0XFF;
- P0M1=0X00;
- P0M0=0XFF;
- P3M1=0X00;
- P3M0=0XFF;
- P4M1=0X00;
- P4M0=0XFF;
- P5M1=0X00;
- P5M0=0XFF;
- P6M1=0X00;
- P6M0=0XFF;
- P7M1=0X00;
- P7M0=0XFF;
- P0M0=0xfe;
- PWMInit();
- LcdInit();
- delay_ms(5);
- ADC_config();
- fan=0;//風(fēng)扇
- DUTY=0;
- UartInit();
- ch=1;
- send_I_V_P[0]=7; //4
- send_I_V_P[1]=15;
- send_I_V_P[2]=200;
- bitworkflag[0]=0; // 1 5
- set_current[0]=1000;// 3 6
- bitsend[0]=0;
- while(1)
- display();
- keyscan();
- voltage_test();
- if(crcok==1)
- // DisplayOneChar(0,0,bitworkflag[0]+0x30);
- crcok = 0;
- if(mrx[0]==6)
- switch (mrx[1])
- case 1:modbushandle1(); //讀取啟停標(biāo)志
- break;
- case 2:modbushandle2(); //讀取過流保護(hù)的標(biāo)志位
- break;
- case 3:modbushandle3(); //讀取設(shè)定電流值
- break;
- case 4:modbushandle4(); //讀電流電壓功率
- break;
- case 5:modbushandle5(); //啟動
- break;
- case 6:modbushandle6(); //設(shè)定電流值
- break;
- switch (bitworkflag[0])
- case 0:
- PWM2output(0);
- fan=0;
- DisplayListChar(14,0,"OF");
- break;
- case 1:
- fan=1;
- PWM2output(DUTY);
- DisplayListChar(14,0,"ON");
- break;
- for(i=0;i<2;i++)
- results = Get_ADC10bitResult(i); //參數(shù)0~7,查詢方式做一次ADC, 返回值就是結(jié)果, == 1024 為錯誤
- if(i==1)
- results=results*9.77;//9.98 放大2倍
- resulti=results;
- send_I_V_P[0]= resulti;
- else
- if(resulti>1050&resulti<1970)
- results=results*9.96;//9.98 放大2倍
- else if(resulti>=1970&resulti<2450)
- results=results*9.98;//9.98 放大2倍
- else if(resulti>=2450&resulti<3200)
- results=results*10.14;//9.98 放大2倍
- else
- results=results*9.68;//9.705 放大2倍
- resultv=results;
- send_I_V_P[1]=resultv;
- a[0+i*4]=results/1000 + '0';
- a[1+i*4]=results%1000/100 + '0';
- a[2+i*4]=results%100/10 + '0';
- a[3+i*4]=results%10 + '0';
- DisplayOneChar(0+i*7,1,a[0+i*4]);
- DisplayListChar(1+i*7,1,".");
- DisplayOneChar(2+i*7,1,a[1+i*4]);
- DisplayOneChar(3+i*7,1,a[2+i*4]);
- DisplayOneChar(4+i*7,1,a[3+i*4]);
- delay_ms(250);
- ierr = set_current[0]-resulti;
- if(ierr>300)ierr=300;
- if(ierr<-300)ierr=-300;
- DUTY+=(ierr)/30;
- void display()
- DisplayListChar(5,1,"v");
- DisplayListChar(13,1,"A");
- /***********顯示設(shè)定電流值**********/
- set_dis[0]=set_current[0]/1000 + '0';
- set_dis[1]=set_current[0]%1000/100 + '0';
- set_dis[2]=set_current[0]%100/10 + '0';
- set_dis[3]=set_current[0]%10 + '0';
- DisplayOneChar(2,0,set_dis[0]);
- DisplayListChar(3,0,".");
- DisplayOneChar(4,0,set_dis[1]);
- DisplayListChar(5,0,"A");
- /***********顯示光標(biāo)**********/
- if(cusor==1)
- DisplayListChar(2,0," ");
- delay_ms(100);
- delay_ms(100);
- else if(cusor==2)
- DisplayListChar(4,0," ");
- delay_ms(100);
- delay_ms(100);
- void keyscan()
- //*******************************k1普通顯示******************************************//
- if(k1==0) //檢測按鍵K1是否按下
- delay_ms(2); //消除抖動 一般大約10ms
- if(k1==0) //再次判斷按鍵是否按下
- if(cusor==1)
- set_current[0]+=1000;
- if(set_current[0]>=4000)
- set_current[0]=0;
- else if(cusor==2)
- set_current[0]+=100;
- set_current[0]=10;
- while(!k1); //檢測按鍵是否松開
- //******************************k2**寫*****************************************//
- if(k2==0)
- delay_ms(2); //消抖處理
- if(k2==0)
- if(cusor==1)
- set_current[0]-=1000;
- if(set_current[0]<=0)
- set_current[0]=4000;
- else if(cusor==2)
- set_current[0]-=100;
- while(!k2);
- //***************************k3*讀**********************************************//
- if(k3==0)
- if(k3==0)
- cusor++;
- if(cusor>=3)
- cusor=0;
- while(!k3);
- //***************************k4*啟動**********************************************//
- if(k4==0)
- if(k4==0)
- bitworkflag[0]++;
- if(bitworkflag[0]>=2)
- bitworkflag[0]=0;
- while(!k4);
電子負(fù)載固件以及上位機(jī).rar
(1.42 MB, 下載次數(shù): 48)
2019-6-4 14:30 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
