void SendByte(u8 Dbyte)
u16 i;
for(i=0;i<8;i++)
LCD_SCLK_1;
if((Dbyte<<i)&0x80)
LCD_SID_1;
LCD_SID_0;
Delay5Ms();
LCD_SCLK_0;
Delay5Ms();
u8 ReadDataLCD(void)
u8 i,temp1=0,temp2=0;
LCD_CS_1;
Delay5Ms();
for(i=0;i<8;i++)
temp1=temp1<<1;
LCD_SCLK_0;
Delay5Ms();
Delay5Ms();
Delay5Ms();
LCD_SCLK_1;
Delay5Ms();
Delay5Ms();
Delay5Ms();
LCD_SCLK_0;
Delay5Ms();
Delay5Ms();
Delay5Ms();
if(GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_8))
temp1++;
for(i=0;i<8;i++)
temp2=temp2<<1;
LCD_SCLK_0;
Delay5Ms();
Delay5Ms();
Delay5Ms();
LCD_SCLK_1;
Delay5Ms();
Delay5Ms();
Delay5Ms();
LCD_SCLK_0;
Delay5Ms();
Delay5Ms();
Delay5Ms();
temp2++;
LCD_CS_0;
return ((0xf0&temp1)+(0x0f&temp2));//
void CheckBusy( void ) //
do
LCD_CS_1;//RS = 1;
Delay5Ms();
SendByte(0xfc); //
while((ReadDataLCD()&0x80)==0x80);
LCD_CS_0;//RS = 1;
Delay5Ms();
void WriteCommandLCD(u8 Cbyte ,u8 BuysC)
if(BuysC)
CheckBusy();
LCD_CS_1;//RS = 1;
Delay5Ms();
SendByte(0xf8); //11111,RW(0),RS(0),0;
SendByte(0xf0&Cbyte); //DDDD0000
SendByte((0xf0&Cbyte)<<4); //0000DDDD
LCD_CS_0;//RS = 0;
Delay5Ms();
void WriteDataLCD(u8 Dbyte )
CheckBusy();
LCD_CS_1;//RS = 1;
Delay5Ms();
SendByte(0xfa); //11111,RW(0),RS(1),0;
SendByte(0xf0&Dbyte); //
SendByte((0xf0&Dbyte)<<4);
LCD_CS_0;//RS = 0;
Delay5Ms();
void LCDInit(void)
WriteCommandLCD(0x30,1);
WriteCommandLCD(0x01,1);
WriteCommandLCD(0x06,1);
WriteCommandLCD(0x0C,1);
WriteCommandLCD(0x02,1);
WriteCommandLCD(0x80,1);
void LCDClear(void)
u8 i;
WriteCommandLCD(0x34,1);
for(i=0;i<64;i++)
WriteCommandLCD(0x20,1);
void LCDFlash(void)
WriteCommandLCD(0x08,1);
Delay400Ms();
WriteCommandLCD(0x0c,1);
Delay400Ms();
Delay400Ms();
Delay400Ms();
Delay400Ms();
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
if(Y<1)
Y=1;
if(Y>4)
Y=4;
X &= 0x0F;
switch(Y)
case 1:X|=0X80;break;
case 2:X|=0X90;break;
case 3:X|=0X88;break;
case 4:X|=0X98;break;
WriteCommandLCD(X, 0);
WriteDataLCD(DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char *DData)
unsigned char ListLength;
DisplayOneChar( X, Y, *DData);
for(ListLength=0;DData[ListLength]!='\0';ListLength++)
WriteDataLCD(DData[ListLength] );
void DisplayImage (const u8 *DData)
unsigned char x,y,i;
unsigned int tmp=0;
for(i=0;i<9;)
for(x=0;x<32;x++)
{ //32DD
WriteCommandLCD((0x80+x),1);
WriteCommandLCD((0x80+i),1);
for(y=0;y<16;y++)
WriteDataLCD(DData[tmp+y]);
tmp+=16;
i+=8;
WriteCommandLCD(0x36,1);
void Delay5Ms(void)
unsigned int TempCyc = 50;
while(TempCyc--);
//400ms
void Delay400Ms(void)
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
