查看: 1308|回復: 1
AVR多級菜單調試通過
ID:526301 發表于 2019-6-2 23:18 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <iom8515v.h>
#include <LCD1602.h>
#include <timer.h>
#include <key.h>
volatile unsigned int time_10ms_ok = 0;
void LED1ON(void)
  PORTD |=  BIT(0);
void NullSubs(void)                                            //空函數
struct MenuItem  MainMenu[6] =             //結構體主菜單
                {6,"1.fingerprint",&LED1ON,fingerprint,&Null},
                {6,"2.password set",&NullSubs,password,&Null},
                {6,"3.IC card set",&NullSubs,fingerprint,&Null},
                {6,"4.telecontrol",&NullSubs,fingerprint,&Null},
                {6,"5.system set",&NullSubs,fingerprint,&Null},
                {6,"6.rec inquire",&NullSubs,fingerprint,&Null},
struct MenuItem fingerprint[4] =                  //子菜單
                {4,"1.add fp",&NullSubs,&Null,MainMenu},
                {4,"2.del fp",&NullSubs,&Null,MainMenu},
struct MenuItem password[4] =                  //子菜單
                {4,"1.add password",&NullSubs,&Null,MainMenu},
                {4,"2.del password",&NullSubs,&Null,MainMenu},
struct MenuItem (*MenuPoint) = MainMenu;
void ShowMenu(void)
        unsigned char i = 0;
        MaxItems = MenuPoint[0].MenuCount;                //獲取當前菜單的條目數
        DisplayPoint = DisplayStart;                      //顯示菜單的編號
        if( MaxItems > LCD1602_Max_Display_Line ) //如果大于能顯示的菜單數做處理
               for ( i = 0;i < LCD1602_Max_Display_Line;i++ )
                   LCD_puts(1,i,MenuPoint[DisplayPoint].DisplayString);//2行分別顯示兩個菜單
               if ((DisplayPoint) == (UserChoose))
                   LCD_putc(0,0,0x7e);   //寫小箭頭
                   LCD_putc(0,i,' ');          //寫空格
               DisplayPoint += 1;   //字符串偏移量+1
                   if ((DisplayPoint) == (MaxItems))
               DisplayPoint = 0;
void ExcuteMenu(void)
        unsigned char GetKeyNum;
        if (time_10ms_ok)
        {                 //確定有功能按鍵被按下的情況下才執行其功能
           time_10ms_ok = 0;
           GetKeyNum = key_driver();
           if((GetKeyNum == 1)||(GetKeyNum == 2))
            switch (GetKeyNum)
            case S_key://短按鍵
             UserChoose++;
                 if (UserChoose == MaxItems)
                 UserChoose = 0;//當用戶的選擇數大于最大菜單數量,則選定的清零到第一個
             GetKeyNum=0;
                 break;
            case L_key:  //長按鍵
             if (MenuPoint[UserChoose].ChildrenMenus != &Null)
             MenuPoint=MenuPoint[UserChoose].ChildrenMenus;  //指向子菜單
                 SavePoint=UserChoose;  //顯示菜單的編號
                 UserChoose=0;
             DisplayStart=0;
             else if (MenuPoint[UserChoose].ParentMenus != &Null)
                 MenuPoint= MenuPoint[UserChoose].ParentMenus; //指向父菜單
                 UserChoose= 0;
                 DisplayStart= SavePoint-1;
                 UserChoose= SavePoint;        //恢復先前的菜單
        if ((MenuPoint[UserChoose].Subs)!= NullSubs)
                         (*MenuPoint[UserChoose].Subs)();
             GetKeyNum=0;
             break;
             default: break;
        //*菜單循環處理
        if ((UserChoose < DisplayStart) || (UserChoose >= (DisplayStart + 1 )))
        DisplayStart = UserChoose;
        write_com(0x01);
        delay_nms(3);
        ShowMenu();
void main(void)
DDRB=0xff;                     //B口為輸出
DDRD=0x7f;
PORTD=0x80;
TCNT1H=0xD8;
TCNT1L=0xF0;
TCCR1B=0x02;
TIMSK=0x80;                                   // 允許中斷
SEI();
init_LCD();
ShowMenu();
ExcuteMenu();
#pragma interrupt_handler timer1:7
void timer1(void)
   time_10ms_ok=1;
   TCNT1H=0xD8;
   TCNT1L=0xF0;
   TIMSK=0x80;
ID:1 發表于 2019-6-3 00:31 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
