查看: 1647|回復: 0
用光敏轉換AD 讀出的數值沒有成功控制舵機。應該怎樣控制?
ID:515908 發表于 2019-6-1 17:40 | 顯示全部樓層 |閱讀模式
#include <STC12C5A60S2.h>
#include <intrins.h>
#define ADC_POWER   0x80
#define ADC_START   0x08
#define ADC_FLAG    0x10
#define ADC_SPEEDLL 0x00
unsigned char count,jd1,jd2,m1,m2;
uint   code smgduan[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uint disp[4];
uint temp1,temp2,result;
sbit pwm=P1^6;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
char jd;
void delay(unsigned int i)
        unsigned int j,k;
        for(j=i;j>0;j--)
                for(k=125;k>0;k--);
void Time0_init()
        TMOD=0x01;
        IE=0x82;
        TH0=0xff;
        TL0=0x19;
        TR0=1;
void Time0_int() interrupt 1
        TH0=0xff;
        TL0=0x19;
        if(count<jd)
         pwm=1;
        pwm=0;
        count++;
        count=count%40;
void keyscan()
        if(1015<temp1<1023)
                delay(50);
                if(1015<temp1<1023)
                        jd++;
                        count=0;
                        if(jd==50)
                              jd=6;
                              while(1015<temp1<1023);
        if(1009<temp1<1015)
                delay(10);
                if(1009<temp1<1015);
                        jd--;
                        count=0;
                        if(jd==0)
                              jd=1;
                        while(1009<temp1<1015);
void InitADC1()
        P1ASF=0x01;
        ADC_RES=0;
        ADC_RESL=0;
        ADC_CONTR=ADC_POWER|ADC_SPEEDLL;
        delay(1);
uint Read(uchar CHA)
        ADC_CONTR=ADC_POWER|ADC_SPEEDLL|CHA|ADC_START;
    _nop_();
    _nop_();
    _nop_();
    _nop_();
        while(!(ADC_CONTR & ADC_FLAG));
        ADC_CONTR &=~ADC_FLAG;
        return(ADC_RES*4+ADC_RESL);
void datapros()
        static uint i=0;
        if(++i>=1000)
                     i=0;
                                        temp1=Read(0);
            disp[3]=smgduan[temp1/1000%10];
                disp[2]=smgduan[temp1/100%10];
                disp[1]=smgduan[temp1/10%10];
                disp[0]=smgduan[temp1%10];
        P1M0 = 0x00;
        P1M1 = 0x01;
        jd=1;
        count=0;
                InitADC1();
                                 datapros();
                                        Time0_init();
                                        keyscan();
                                        delay(1);
