第一個問題:已經編了記時50ms和20次循環,可是間隔不是1s。第二個問題:因為位選所以要用P2.2和P2.3,由于編寫了P2=0xf7和P2=0xfb其他的P2口無法控制。
2019-5-30 15:24 上傳
這是程序:
#include<reg51.h>
sbit s=P1^3;
sbit b=P3^3;
sfr P2M0=0xf3;
sfr P2M1=0xff;
sbit a=P2^4;
sbit e=P2^5;
sbit d=P2^6;
unsigned char code Tab[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char code c[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char int_time;
unsigned char second;
void delay()
unsigned char i;
for(i=0;i<200;i++)
void DisplaySecond(unsigned char k)
P2=0xf7;
P0=Tab[k%10];
delay();
P2=0xfb;
P0=Tab[k/10];
delay();
P0=0xff;
P3=0x00;
TMOD=0x90;
TL1=(65536-50000)/256;
TH1=(65536-50000)%256;
EA=1;
ET1=1;
TR1=1;
EX1=1;
IT1=1;
int_time=0;
second=0;
TR1=0;
if(a==0)
P1=c[0];
if(e==0)
P1=c[1];
if(d==0)
P1=c[2];
DisplaySecond(second);
void time1()interrupt 3 using 1
int_time++;
if(int_time==20)
int_time=0;
if(second<30)
second++;
if(second==30)
b=0;
if(b==0)
second=0;
TR1=1;
