只需一步,快速開(kāi)始
查看: 1951|回復(fù): 0
求單片機(jī)按鍵的代碼翻譯
ID:540752 發(fā)表于 2019-5-29 13:15 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
哪位大佬幫忙翻譯下代碼關(guān)于按鍵的控制
最主要的是0xff這種的看不懂。。。
void key()
uchar fs=255;
key_scan();
if((key_n!=0xff&&C_Mode==0)||discern_flag)
  delay(1000);
  key_n=0xff;
  key_scan();
   key_scan();
   if((key_n!=0xff&&C_Mode==0))
    time=0;
    fs=key_n;
   else if(discern_flag)
    fs=yuyin_n;
    yuyin_n=0;
    time=0;
    delay(1000);
   key_n=0xff;
   key_scan();
   while((key_n!=0xff&&C_Mode==0))
    key_scan();
    if(time>39&&Again==0)
     Again=1;
    // time=40;
     switch(fs)
      case 0x7f:
       if(vol<30) vol=15;
       if(vox<30) vox++;
       send_6(0x7E,0x04,0x31,vox,0x22,0xEF);
      break;
      case 0xbf:
       if(vol>0) vol=15;
       if(vox>0) vox--;
      break;
      case 0xdf:
       if(set_s)
        if(ch_song<sum)
          ch_song++;
        times+=28;
        if(times>timer) times=timer;
        min=times/600;
        sec=times/10%60;
        send_5(0x7E,0x03,0x0A,0x09,0xEF);
      break;
      case 0xef:
       if(set_s)
        if(ch_song>1)
          ch_song--;
        if(times>27)times-=28;
        else times=0;
        min=times/600;
        sec=times/10%60;
        send_5(0x7E,0x03,0x0B,0x08,0xEF);
      break;
    show();
   // read_dat();
   switch(fs)
    case 0x7f:
     if(time<40)
      send_5(0x7E,0x03,0x04,0x07,0xEF);
      state=1;
      once=1;
      ACIS=6;
      discern_flag=0;
      fs=0;
    break;
    case 0xbf:
     if(time<40)
      send_5(0x7E,0x03,0x03,0x00,0xEF);
      state=1;
      once=1;
      ACIS=6;
      discern_flag=0;
      fs=0;
    break;
    case 0xdf:
     if(discern_flag)
      if(vol<30) vol=15;
      if(vox<30) vox++;
      discern_flag=0;
      fs=0;
      if(time<40)
       times+=27;
       min=times/600;
       sec=times/10%60;
    break;
    case 0xef:
     if(discern_flag)
      if(vol>0) vol=15;
      if(vox>0) vox--;
      discern_flag=0;
      fs=0;
      if(time<40)
       if(times>26)times-=27;
       else times=0;
       min=times/600;
       sec=times/10%60;
    break;
    case 0xf7:
     if(state==2|state==0)
      state=1;
      send_5(0x7E,0x03,0x01,0x02,0xEF);
      discern_flag=0;
      fs=0;
     }else
      state=2;
      send_5(0x7E,0x03,0x02,0x01,0xEF);
      discern_flag=0;
      fs=0;
    break;
    case 0xfb:
     state=0;
     send_5(0x7E,0x03,0x0E,0x0D,0xEF);
     discern_flag=0;
     fs=0;
    break;
    case 0xfd:
     EQ=(EQ+1)%6;
     send_6(0x7E,0x04,0x32,EQ,0x36,0xEF);
    break;
    case 0xfe:
     mode=(mode+1)%5;
     send_6(0x7E,0x04,0x33,mode,0x35,0xEF);
    break;
if(!key9)
  if(key_flag9)
   key_flag9=0;
   C_Mode=~C_Mode;
  key_flag9=1;
