查看: 2017|回復: 1
用AT89C51來制作簡單電子琴
ID:548138 發表于 2019-5-29 12:46 | 顯示全部樓層 |閱讀模式
#include <REGX51.H>
sbit key1=P0^0;
sbit key2=P0^1;
sbit key3=P0^2;
sbit key4=P0^3;
sbit key5=P0^4;
sbit key6=P0^5;
sbit key7=P0^6;
sbit key8=P0^7;
sbit beep=P2^7;
bit mode;
unsigned char TH,TL;
code unsigned int music[]={3816,3401,3030,2857,2551,2272,2024,        958,852,759,714,638,568,506};
void delay_ms(unsigned char ms)
        unsigned char i;
        while(ms--)
        for(i=0;i<123;i++);
unsigned char key_scan()
        unsigned char key_no=14;
        if(key1==0)
        delay_ms(10);
        if(key1==0)
        mode=!mode;
        while(!key1);
        if(mode==0)
         if(key2==0) key_no=0;
        if(key3==0) key_no=1;
        if(key4==0) key_no=2;
        if(key5==0) key_no=3;
        if(key6==0) key_no=4;
        if(key7==0) key_no=5;
        if(key8==0) key_no=6;
        }else
        if(key2==0) key_no=7;
        if(key3==0) key_no=8;
        if(key4==0) key_no=9;
        if(key5==0) key_no=10;
        if(key6==0) key_no=11;
        if(key7==0) key_no=12;
        if(key8==0) key_no=13;
        return key_no;
        unsigned char key_no;
        TMOD=0x00;
        ET0=1;
        TR0=0;
        EA=1;
        key_no=key_scan();
         if(key_no!=14)
         TR0=1;
         TH=65536-music[key_no]/256;
         TL=65536-music[key_no]%256;
         }else
         TR0=0;
void time0() interrupt 2
        TH0=TH;
        TL0=TL;
        beep=!beep;
ID:1 發表于 2019-5-29 18:22 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
