查看: 3481|回復: 0
SST及IR全新原裝現(xiàn)貨庫存
ID:44038 發(fā)表于 2012-8-20 15:09 | 顯示全部樓層 |閱讀模式
SST全新原裝現(xiàn)貨庫存
聯(lián)系人:劉先生
0755-83553805 QQ:1595215042/840201789   MOB:15818599126
柜臺地址:佳和華強大廈3樓3A333號
SST39VF1601-70-4C-EKE
SST39VF040-70-4C-WHE
SST39VF3201-70-4I-EKE
SST39VF3201B-70-4C-EKE
SST39VF1681-70-4C-EKE
SST12LP15A-QVCE
SST39VF800A-70-4C-EKE
SST39SF040-70-4C-WHE
SST39SF040-70-4I-NHE
SST39VF040-70-4C-NHE
SST49LF008A-33-4C-NHE
SST39VF010-70-4C-NHE
SST39VF6401B-70-4I-EKE
SST25VF080B-80-4C-S2AE
SST39VF1601-70-4I-EKE
SST89V516RD2-33-C-NJE
SST12LP14E-QX6E
SST39VF6401B-70-4C-EKE
SST25VF010A-33-4C-SAE
SST49LF008A-33-4C-NHE-T
SST25VF512A-33-4I-SAE
SST39VF1601-70-4C-B3KE
SST25VF040B-80-4I-S2AE
SST89E58RDA-40-C-PIE
SST25VF032B-80-4I-S2AF
SST25VF016B-75-4I-S2AF
SST39VF400A-70-4C-EKE
SST12LP14E-QX8E
SST12LP07A-QXBE
SST39VF800A-70-4I-EKE
IR全新原裝現(xiàn)貨庫存
聯(lián)系人:劉先生
柜臺地址:佳和華強大廈3樓3A333號
IR1150ISTRPBF IR SOIC-8
IR1166STRPBF IR S0-8
IR2010STRPBF IR SOIC-16
IR2011STRPBF IR SO-8
IR2101STRPBF IR SO-8
IR2103STRPBF IR SO-8
IR2104STRPBF IR SOIC-8
IR2109STRPBF IR 8LEAD
IR2110STRPBF IR SOIC-16
IR2111STRPBF IR SO-8
IR2113STRPBF IR SOIC-16
IR2130PBF IR 28-DIP
IR2153PBF IR DIP-8
IR2156STRPBF IR SOIC-14
IR2166S IR SOIC-16
IR2166STRPBF IR SOP-16
IR21844SPBF IR SOP-14
IR4104SPBF IR D2-PAK
IRF1010EPBF IR TO-220AB
IRF1404PBF IR TO-220AB
IRF1404ZPBF IR TO-220AB
IRF1405PBF IR TO-220AB
IRF1407PBF IR TO-220AB
IRF2804PBF IR TO-220AB
IRF2807PBF IR TO-220AB
IRF3205PBF IR TO-220AB
IRF3415PBF IR TO-220AB
IRF3415STRLPBF IR D2PAK
IRF3703PBF IR TO-220AB
IRF3709SPBF IR TO-263
IRF3710PBF IR TO-220AB
IRF3710STRLPBF IR D2-PAK
IRF3808PBF IR TO-220AB
IRF4104PBF IR TO-220AB
IRF4905PBF IR TO-220AB
IRF510PBF VISHAY TO-220AB
IRF5210PBF IR TO-220AB
IRF5210STRLPBF IR D2-PAK
IRF5305PBF IR TO-220AB
IRF530NPBF IR TO-220AB
IRF540NPBF IR TO-220AB
IRF540NSTRLPBF IR D2-PAK
IRF540NSTRRPBF IR D2-PAK
IRF540PBF VISHAY TO-220AB
IRF610PBF VISHAY TO-220
IRF6216TRPBF IR SO-8
IRF6217TRPBF IR S0-8
IRF630NPBF IR TO-220AB
IRF640A FAIRCHILD TO-220AB
IRF640NPBF IR TO-220AB
IRF640NS IR D2-PAK
IRF640NSTRLPBF IR D2PAK
IRF640PBF VISHAY TO-220
IRF644PBF VISHAY TO-220AB
IRF6604TR1 IR SURFACE MOUNT CAN - DIRECTFET
IRF6609TRPBF IR DIRECTFET
IRF6646TRPBF IR DIRECTFET
IRF6648TRPBF IR DIRECTFET
IRF6715MTRPBF IR SOT-263
IRF6716MTRPBF IR DIRECTFET
IRF730PBF VISHAY TO-220AB
IRF7343TRPBF IR SOIC-8
IRF7404TRPBF IR SOP-8
IRF740PBF VISHAY TO-220AB
IRF7424TRPBF IR SO-8
IRF7490TRPBF IR SO-8
IRF7493PBF IR SOIC-8
IRF7493TRPBF IR SO-8
IRF7821TRPBF IR SOP-8
IRF7831TRPBF IR SOP-8
IRF7832TRPBF IR SO-8
IRF7832ZTRPBF IR SOP-8
IRF7842TRPBF IR SO-8
IRF8010PBF IR TO-220AB
IRF830APBF VISHAY TO-220AB
IRF830PBF VISHAY TO-220AB
IRF830SPBF VISHAY TO-263
IRF840APBF VISHAY TO-220
IRF840ASTRLPBF VISHAY TO-263
IRF840PBF VISHAY TO-220AB
IRF8707GTRPBF IR SO-8
IRF8707TRPBF IR SOIC-8
IRF9530NPBF IR TO-220AB
IRF9530PBF VISHAY TO-220AB
IRF9530SPBF IR TO-263
IRF9540NPBF IR TO-220AB
IRF9540NSTRLPBF IR D2PAK
IRF9630PBF VISHAY TO-220
IRF9640PBF VISHAY TO-220AB
IRF9Z24NPBF IR TO-220AB
IRF9Z34NPBF IR TO-220AB
IRFB20N50KPBF VISHAY TO-220AB
IRFB23N15DPBF IR TO-220AB
IRFB260NPBF IR TO-220
IRFB3077PBF IR TO-220AB
IRFB31N20DPBF IR TO-220AB
IRFB3206GPBF IR TO-220
IRFB3207PBF IR TO-220AB
IRFB3306PBF IR TO-220
IRFB3607PBF IR TO-220AB
IRFB38N20DPBF IR TO-220AB
IRFB4110PBF IR TO-220AB
IRFB4115PBF IR TO-220AB
IRFB4227PBF IR TO-220AB
IRFB4229PBF IR TO-220
IRFB42N20DPBF IR TO-220AB
IRFB4310PBF IR TO-220AB
IRFB4310ZPBF IR TO-220AB
IRFB4410PBF IR TO-220AB
IRFB4410ZPBF IR TO-220AB
IRFB4710PBF IR TO-220AB
IRFB52N15DPBF IR TO-220AB
IRFBC20PBF VISHAY TO-220AB
IRFBE30PBF VISHAY TO-220AB
IRFBF30PBF VISHAY TO-220AB
IRFBG30PBF VISHAY TO-220AB
IRFD110PBF VISHAY DIP-4
IRFD9120PBF VISHAY HVMDIP
IRFH5015TRPBF IR PQFN
"IRFH5300TRPBF " IR PQFN
IRFH5301TRPBF IR PQFN
IRFH5302TRPBF IR PQFN
IRFI1010NPBF IR TO-220F
IRFL014NTRPBF IR SOT-223
IRFL110TRPBF VISHAY SOT-223
IRFL210TRPBF VISHAY SOT-223
IRFP054NPBF IR TO-247AC
IRFP064NPBF IR TO-247AC
IRFP140NPBF IR TO-247
IRFP150MPBF IR TO-247
IRFP150NPBF IR TO-247AC
IRFP22N50APBF VISHAY TO-247
IRFP240PBF VISHAY TO-247
IRFP250MPBF IR TO-247
IRFP250NPBF IR TO-247
IRFP260MPBF IR TO-247
IRFP260NPBF IR TO-247
IRFP264PBF VISHAY TO-247
IRFP27N60KPBF VISHAY TO-247AC
IRFP2907PBF IR TO-247
IRFP350PBF VISHAY TO-247
IRFP360PBF VISHAY TO-247
IRFP4110PBF IR TO-247
IRFP4227PBF IR TO-247
IRFP4229PBF IR TO-247
IRFP4310ZPBF IR TO-247
IRFP4368PBF IR TO-247
IRFP4468PBF IR TO-247
IRFP450APBF VISHAY TO-247
IRFP450PBF VISHAY TO-247AC
IRFP4568PBF IR TO-247
IRFP460APBF VISHAY TO-247
IRFP460LCPBF VISHAY TO-247
IRFP460PBF VISHAY TO-247AC
IRFP4668PBF IR TO-247
IRFP4710PBF IR TO-247
IRFP4768PBF IR TO-247
IRFP90N20DPBF IR TO-247AC
IRFP9140NPBF IR TO-247
IRFP9240PBF VISHAY TO-247
IRFPE40PBF VISHAY TO-247AC
IRFPE50PBF VISHAY TO-247
IRFPG50PBF VISHAY TO-247
IRFR024NTRPBF IR D-PAK
IRFR120NTRPBF IR D-PAK
IRFR12N25DTRLP IR D-PAK
IRFR18N15DTRPBF IR DPAK
IRFR220NTRLPBF IR D-PAK
IRFR220NTRPBF IR D-PAK
IRFR2405TRPBF IR D-PAK
IRFR3504ZTRPBF IR D-PAK
IRFR3709ZTRPBF IR D-PAK
IRFR430APBF VISHAY D-PAK
IRFR430ATRPBF VISHAY DPAK
IRFR5305TRPBF IR D-PAK
IRFR9024NTRPBF IR D-PAK
IRFR9120NTRPBF IR D-PAK
IRFS31N20DPBF IR D2-PAK
IRFS41N15DPBF IR D2-PAK
IRFS4227TRLPBF IR D2PARK
IRFS4321TRLPBF IR D2-PAK
IRFU120NPBF IR TO-251
IRFU210PBF VISHAY TO-251
IRFU220NPBF IR TO-251
IRFU320PBF VISHAY I-PAK
IRFU3910PBF IR TO-251
IRFU9120NPBF IR TO-251
IRFZ24NPBF IR TO-220AB
IRFZ24NSPBF IR D2-PAK
IRFZ34NPBF IR TO-220AB
IRFZ44NPBF IR TO-220AB
IRFZ48NPBF IR TO-220AB
IRFZ48VPBF IR TO-220AB
IRG4BC20KDPBF IR TO-220
IRG4BC40UPBF IR TO-220
IRG4PC40U(有鉛) IR TO-247
IRG4PC40UDPBF IR TO-247
IRG4PC40WPBF IR TO-247
IRG4PC50UDPBF IR TO-247
IRG4PF50WDPBF IR TO-247AC
IRG4PF50WPBF IR TO-247AC
IRG4PH40UD2-EP IR TO-247
IRGP35B60PDPBF IR TO-247
IRGP4063DPBF IR TO-247
IRGPS40B120UDP IR SUPER-247
IRGPS40B120UPBF IR TO-247
IRL2203NPBF IR TO-220AB
IRL2505PBF IR TO-220AB
IRL3103PBF IR TO-220
IRL3803SPBF IR D2-PAK
IRL3803STRLPBF IR D2-PAK
IRL540NPBF IR TO-220AB
IRL7833PBF IR TO-220AB
IRLB4132PBF IR TO-220
IRLL2705TRPBF IR SOT-223
IRLML2402TRPBF IR SOT-23
IRLML2502TRPBF IR SOT-23
IRLML2803TRPBF IR SOT-23
IRLML5103TRPBF IR SOT-23
IRLML5203TRPBF IR SOT-23
IRLML6302TRPBF IR SOT-23
IRLML6401TRPBF IR SOT-23
IRLML6402TRPBF IR SOT-23
IRLR024NPBF IR TO-251
IRLR3103TRPBF IR TO-252
IRLR7843TRPBF IR TO-252
IRLU024NPBF IR TO-251
IRS20955STRPBF IR SOIC-16
IRS20957STRPBF IR SOIC-16
IRS2101STRPBF IR SOIC-8
IRS2103STRPBF IR SOIC-8
IRS2104STRPBF IR SOIC-8
IRS2153DPBF IR DIP-8
IRS2168DSTRPBF IR SO-16
