查看: 2425|回復: 2
關于旋轉LED顯示屏的單片機程序問題
ID:526819 發表于 2019-5-23 09:44 | 顯示全部樓層 |閱讀模式
各位大佬,本人近期搞了一個旋轉LED顯示屏。寫好程序后進行運行。發現顯示的字是鏡像文字,比如說“老”,顯示的就是鏡像文字。然后我就想:即然是鏡像文字,那我就在取模軟件里取鏡像模,這樣顯示的就是正常字了。
結果實踐之后不得行,電機的正轉和反轉也對文字沒影響。跪求大佬指點一下怎么解決這個問題,采用16*16,程序如下,led低電平點亮
#include<reg52.h>
uint num;  //???????
sbit wai=P3^2; //??????
void delay(uint z) //???
uchar x,y;
for(x=z;x>0;x--)
for(y=10;y>0;y--);
uchar code shuzu2[]={
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",1*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",2*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",3*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",6*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",7*/
0xFD,0xEF,0xDD,0xEF,0xDD,0xDF,0xDD,0xDF,0xDD,0xBF,0xDD,0x83,0x01,0x6D,0xDC,0xED,
0xDC,0xDD,0xDD,0xDD,0xD9,0xBD,0xD5,0xBD,0x8D,0xFD,0xDD,0xF1,0xFD,0xFF,0xFF,0xFF,/*"老",8*/
0xFF,0xFD,0xC0,0x1B,0xFF,0xF7,0xFF,0x8F,0x00,0x7F,0xFF,0xFF,0xB0,0x0F,0xB7,0xFF,
0xB7,0xFF,0xB7,0xFF,0x80,0x00,0xB7,0xFF,0xB7,0xDF,0xB7,0xEF,0xB0,0x1F,0xFF,0xFF,/*"師",9*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xE5,0xFF,0xE3,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*",",10*/
0xFE,0xFF,0xFD,0xFB,0xF3,0xE3,0xC0,0x3F,0x3F,0xE3,0xF6,0xFD,0xE9,0xFD,0x9F,0x6D,
0xDF,0xB5,0xD0,0x7D,0xDF,0xFD,0xDB,0xF1,0xDD,0xFF,0xCE,0x6F,0xDF,0xF3,0xFF,0xFF,/*"您",11*/
0xFE,0xFF,0xDE,0xDF,0xDE,0xDF,0xD6,0xDF,0xDA,0xDF,0xDC,0xDF,0x5E,0xDF,0x9E,0x00,
0xDE,0xDF,0xDC,0xDF,0xDA,0xDF,0xD6,0xDF,0xDE,0xDF,0xDE,0xFF,0xFE,0xFF,0xFF,0xFF,/*"辛",12*/
0xFD,0xFF,0xDD,0xFF,0xDD,0xFF,0xDD,0x81,0xDD,0xBB,0x05,0xBB,0xDD,0xBB,0xD0,0x3B,
0xDD,0xBB,0xDD,0xBB,0x05,0xBB,0xDD,0x81,0xDD,0xFF,0xDD,0xFF,0xDD,0xFF,0xFF,0xFF,/*"苦",13*/
0xFF,0xFF,0xBF,0xFF,0xBF,0xFF,0xBF,0xFF,0xBF,0xFF,0xBF,0xFD,0xBF,0xFE,0xB0,0x01,
0xB7,0xFF,0xAF,0xFF,0xAF,0xFF,0x9F,0xFF,0x9F,0xFF,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"了",14*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x05,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"!",15*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",16*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",17*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",18*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",19*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",20*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",21*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",22*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",23*/
void display(uchar *dat,uint ci)
uint k=0;
uint i=0;
while(k<ci)
  if(wai==0) //當檢測紅外開始時
   for(i=0;i<128;i=i+2) //設置顯示寬度
    P0=dat[i+k]; //顯示高八位
    P1=dat[i+1+k]; //第八位
    delay(12); //???
   P1=0xff; //???
   P0=0xff;
   k+=2;  //字模地址加2,滾動顯示
display(shuzu2,384); //四個清屏加八個字,一共12*32=384個數據,一個字32個數據
ID:160500 發表于 2019-5-23 10:56 | 顯示全部樓層
顯示出現問題,肯定是你取數據錯了,仔細檢查顯示程序的取字模的公式和提取字模的方式是否一致
ID:342822 發表于 2019-5-23 21:01 | 顯示全部樓層
取模:逐列式,逐行式,行列式,列行式,逆向,順向都試一下。
