- // Define SPI pins
- #include <reg51.h>
- #include <string.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define ulong unsigned long
- #define LCDIO P0 //1602數據口
- sbit rs=P2^6; //1602數據命令選擇引腳
- sbit rd=P2^5; //讀寫選擇
- sbit lcden=P2^7; //1602選通引腳
- sbit rs=P2^5; //1602數據命令選擇引腳
- sbit rd=P2^6; //讀寫選擇
- sbit key=P2^2;
- sbit beep=P2^4;
- uchar xiao,ge,shi,bai;
- float f_temp; //浮點型溫度值
- long int tvalue;//溫度值
- uchar tflag;
- uchar code table[]= {"T: TH:30 "}; //每行顯示16個字符
- uchar code table1[]= {"S: "};
- uchar data disdata[5];
- uchar a,b;
- #define TX_ADR_WIDTH 5 // 5???????/????
- #define TX_PLOAD_WIDTH 5 // ??????????
- sbit LED = P2^3;
- uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // ??????????
- uchar RX_BUF[TX_PLOAD_WIDTH];
- uchar TX_BUF[TX_PLOAD_WIDTH];
- uchar flag;
- uchar DATA = 0x01;
- uchar bdata sta;
- sbit RX_DR = sta^6;
- sbit TX_DS = sta^5;
- sbit MAX_RT = sta^4;
- sbit CE = P1^5;
- sbit CSN= P1^0;
- sbit SCK= P1^4;
- sbit MOSI= P1^1;
- sbit MISO= P1^3;
- sbit IRQ = P1^2;
- /*sbit CE = P3^3;
- sbit CSN= P2^4;
- sbit SCK= P2^0;
- sbit MOSI= P2^2;
- sbit MISO= P2^1;
- sbit IRQ = P2^3;*/
- // SPI(nRF24L01) commands
- #define READ_REG 0x00 // Define read command to register
- #define WRITE_REG 0x20 // Define write command to register
- #define RD_RX_PLOAD 0x61 // Define RX payload register address
- #define WR_TX_PLOAD 0xA0 // Define TX payload register address
- #define FLUSH_TX 0xE1 // Define flush TX register command
- #define FLUSH_RX 0xE2 // Define flush RX register command
- #define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
- #define NOP 0xFF // Define No Operation, might be used to read status register
- // SPI(nRF24L01) registers(addresses)
- #define CONFIG 0x00 // 'Config' register address
- #define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address
- #define EN_RXADDR 0x02 // 'Enabled RX addresses' register address
- #define SETUP_AW 0x03 // 'Setup address width' register address
- #define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address
- #define RF_CH 0x05 // 'RF channel' register address
- #define RF_SETUP 0x06 // 'RF setup' register address
- #define STATUS 0x07 // 'Status' register address
- #define OBSERVE_TX 0x08 // 'Observe TX' register address
- #define CD 0x09 // 'Carrier Detect' register address
- #define RX_ADDR_P0 0x0A // 'RX address pipe0' register address
- #define RX_ADDR_P1 0x0B // 'RX address pipe1' register address
- #define RX_ADDR_P2 0x0C // 'RX address pipe2' register address
- #define RX_ADDR_P3 0x0D // 'RX address pipe3' register address
- #define RX_ADDR_P4 0x0E // 'RX address pipe4' register address
- #define RX_ADDR_P5 0x0F // 'RX address pipe5' register address
- #define TX_ADDR 0x10 // 'TX address' register address
- #define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address
- #define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address
- #define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address
- #define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address
- #define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address
- #define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address
- #define FIFO_STATUS 0x17 // 'FIFO Status Register' register address
- //--??SPI???? IO--//
- /*sbit MOSIO = P3^4;
- sbit R_CLK = P3^5;
- sbit S_CLK = P3^6;*/
- void blink(char i);
- ??: init_io()
- ???IO
- void init_io(void)
- CE = 0; // ??
- CSN = 1; // SPI??
- SCK = 0; // SPI????
- IRQ = 1; // ????
- LED = 1; // ?????
- ??:delay_ms()
- ??x??
- void delay_ms(uchar x)
- uchar i, j;
- i = 0;
- for(i=0; i<x; i++)
- j = 250;
- while(--j);
- j = 250;
- while(--j);
- ??:SPI_RW()
- ??SPI??,???????nRF24L01,???nRF24L01
- uchar SPI_RW(uchar byte)
- uchar i;
- for(i=0; i<8; i++) // ??8?
- MOSI = (byte & 0x80); // byte??????MOSI
- byte <<= 1; // ?????????
- SCK = 1; // ??SCK,nRF24L01?MOSI??1???,???MISO??1???
- byte |= MISO; // ?MISO?byte???
- SCK = 0; // SCK??
- return(byte); // ????????
- ??:SPI_RW_Reg()
- ???value?reg???
- uchar SPI_RW_Reg(uchar reg, uchar value)
- uchar status;
- CSN = 0; // CSN??,??????
- status = SPI_RW(reg); // ?????,???????
- SPI_RW(value); // ??????????
- CSN = 1; // CSN??,??????
- return(status); // ???????
- ??:SPI_Read()
- ?reg???????
- uchar SPI_Read(uchar reg)
- uchar reg_val;
- //blink(4);
- SPI_RW(reg); // ?????
- reg_val = SPI_RW(0); // ??????????
- //delay_ms(200);
- return(reg_val); // ???????
- ??:SPI_Read_Buf()
- ?reg?????bytes???,??????????
- uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
- uchar status, i;
- for(i=0; i<bytes; i++)
- pBuf[i] = SPI_RW(0); // ?????nRF24L01??
- ??:SPI_Write_Buf()
- ?pBuf?????????nRF24L01,???????
- uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
- uchar status, i;
- SPI_RW(pBuf[i]); // ??????nRF24L01
- ??:RX_Mode()
- ??????nRF24L01?????,????????????
- void RX_Mode(void)
- CE = 0;
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // ????????0??????????????
- SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // ??????0????
- SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // ??????0
- SPI_RW_Reg(WRITE_REG + RF_CH, 40); // ??????0x40
- SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // ????0???????????????
- SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // ?????1Mbps,????0dBm,????????
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // CRC??,16?CRC??,??,????
- delay_ms(150);
- CE = 1; // ??CE??????
- ??:TX_Mode()
- ??????nRF24L01?????,(CE=1????10us),
- 130us?????,???????,??????????
- void TX_Mode(uchar * BUF)
- CE = 0;
- SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // ??????
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // ????????,????0?????????
- SPI_Write_Buf(WR_TX_PLOAD, BUF, TX_PLOAD_WIDTH); // ?????TX FIFO
- SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x0a); // ????????250us+86us,????10?
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // CRC??,16?CRC??,??
- delay_ms(150);
- CE = 1;
- ??:Check_ACK()
- uchar Check_ACK(bit clear)
- while(IRQ);
- sta = SPI_RW(NOP); // ???????
- if(TX_DS)
- //blink(3);
- //blink(5);
- if(MAX_RT)
- if(clear) // ????TX FIFO,???????MAX_RT???????
- SPI_RW(FLUSH_TX);
- SPI_RW_Reg(WRITE_REG + STATUS, sta); // ??TX_DS?MAX_RT????
- IRQ = 1;
- if(TX_DS)
- return(0x00);
- else
- return(0xff);
- ??:CheckButtons()
- void CheckButtons()
- P3 |= 0x00;
- if(!(P3 & 0x01)) // ??P3^0??
- delay_ms(20);
- TX_BUF[0] = ~DATA; // ??????
- //TX_BUF[0] = 0xff; // ??????
- TX_Mode(TX_BUF); // ?nRF24L01????????????
- //LED = ~DATA; // ????LED??
- Check_ACK(0); // ??????,??TX FIFO
- LED = 1; // ??LED
- RX_Mode(); // ???????
- while(!(P3 & 0x01));
- DATA <<= 1;
- if(!DATA)
- DATA = 0x01;
- /*void blink(char i)
- while(i--)
- LED = 1;
- delay_ms(50);
- LED = 0;
- delay_ms(50);
- 1602
- void delay(uint z) //短延時
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void write_com(uchar com) //1602寫命令子程序
- rs=0; //RS是數據命令選擇短,高電平寫數據,低電平寫命令
- rd=0; //RD是讀寫選擇短,高電平讀,低電平寫
- lcden=0; //1602選通端,高電平選通,低電平禁止
- LCDIO=com;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void write_date(uchar date) //1602寫數據子程序
- rs=1; //RS是數據命令選擇短,高電平寫數據,低電平寫命令
- LCDIO=date;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void init() //1602初始化程序
- uchar num;
- lcden=0;
- write_com(0x38); //0011 1000B,功能模式設置,設置為8為數據口,兩行顯示,5*7點陣
- write_com(0x0c); //0000 1011B,顯示開及光標設置,關顯示,顯示光標,光標閃爍
- write_com(0x06); //0000 0110B,顯示光標移動設置,讀或寫一個字符,地址指針減一且光標減一,寫一個字符屏幕顯示不移動
- write_com(0x01); //0000 0001B,顯示清屏,數據指針和所有顯示清屏
- write_com(0x80); //1000 000B,關閉顯示
- delay(5);
- write_com(0x80); //1000 000B,設置為2行顯示,寫入第一行字符的地址,第一行地址是00-2F
- for(num=0;num<16;num++)
- write_date(table[num]); //寫入第一行數據
- delay(5);
- write_com(0x80+0x40); //1100 0000B,設置為2行顯示,寫入第二行字符的地址,第而行地址是40-67
- for(num=0;num<16;num++) //寫入第二行數據
- write_date(table1[num]);//寫入第二行數據
- delay(5);
- void ds1820disp()//溫度值顯示
- { uchar flagdat;
- disdata[0]=tvalue/1000+0x30;//百位數
- disdata[1]=tvalue%1000/100+0x30;//十位數
- disdata[2]=tvalue%100/10+0x30;//個位數
- disdata[3]=tvalue%10+0x30;//小數位
- if(tflag==0)
- flagdat=0x2b;//正溫度不顯示符號
- else
- flagdat=0x2d;//負溫度顯示負號:-
- if(disdata[0]==0x30)
- {disdata[0]=0x20;//如果百位為0,不顯示
- if(disdata[1]==0x30)
- {disdata[1]=0x20;//如果百位為0,十位為0也不顯示
- write_com(0x80+2); //1100 0000B,設置為2行顯示,寫入第二行字符的地址,第而行地址是40-67
- write_date(flagdat);//顯示符號位
- write_com(0x80+3);
- write_date(disdata[0]);//顯示百位
- write_com(0x80+4);
- write_date(disdata[1]);//顯示十位
- write_com(0x80+5);
- write_date(disdata[2]);//顯示個位
- write_com(0x80+6);
- write_date(0x2e);//顯示小數點
- write_com(0x80+7);
- write_date(disdata[3]);//顯示小數位
- write_com(0x80+8);
- write_date('C');
- void ADdisp()
- long int shidu;
- shidu=RX_BUF[3];
- xiao=((shidu)*50*20/255)%10+0x30;
- ge=((shidu)*50*20/255)%100/10+0x30;
- shi=((shidu)*50*20/255)%1000/100+0x30;
- bai=((shidu)*50*20/255)/1000+0x30;
- if(bai==0x30)
- {bai=0x20;//如果百位為0,不顯示
- if(shi==0x30)
- {shi=0x20;//如果百位為0,十位為0也不顯示
- write_com(0x80+0x45);
- write_com(0x80+0x46);
- write_date(xiao);//顯示小數位
- write_com(0x80+0x44);
- write_date(ge);//顯示個位
- write_com(0x80+0x43);
- write_date(shi);//顯示十位
- write_com(0x80+0x42);
- write_date(bai);//顯示百位
- write_com(0x80+0x47);
- write_date('%');
- read_temp()/*讀取溫度值并轉換*/
- a=RX_BUF[1];
- b=RX_BUF[2];
- tvalue=b;
- tvalue<<=8;
- tvalue=tvalue|a;
- if(tvalue<0x0fff)
- tflag=0;
- else
- {tvalue=~tvalue+1;
- tflag=1;
- f_temp=tvalue*(0.0625);// 溫度在寄存器中為12位,分辨率為0.0625
- tvalue=f_temp*10+0.5;//乘以10表示小數點后面只取1位,加0.5時四舍五入
- return(tvalue);
- ??:main()
- void baojing()
- if(tvalue>=280)
- beep=1;
- write_com(0x80+0x4e);
- write_date('!');
- write_com(0x80+0x4f);
- write_date('!');
- else
- beep=0;
- write_date(0x20);
- write_date(0x20);
- void main(void)
- LED=1;
- beep=0;
- init_io(); // ???IO
- init();
- while(1)
- sta = SPI_Read(STATUS); // ??????
- //delay_ms(200);
- if(RX_DR) // ?????????
- SPI_Read_Buf(RD_RX_PLOAD, RX_BUF, TX_PLOAD_WIDTH); // ?RX FIFO????
- flag = 1;
- SPI_RW_Reg(WRITE_REG + STATUS, sta); // ??RX_DS????
- if(flag) // ????
- if(RX_BUF[0] == 1)
- { beep=0;
- LED=~LED;
- read_temp();
- ds1820disp();//顯示
- baojing();
- if(key==0)
- ADdisp();
- flag = 0; // ???
NRF24L01測溫測濕.rar
(105.22 KB, 下載次數: 36)
2019-5-21 11:14 上傳
