查看: 1770|回復: 1
求一個51單片機矩陣加法方式,目前矩陣可以弄出來,但加減法不會
ID:541708 發表于 2019-5-18 21:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
1黑幣
#include<reg51.h>
#define anjian P1
unsigned int keyshu;
unsigned int a;
unsigned int shumaguan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(unsigned int i)
   while(i--);
void xianshi(unsigned int m)
unsigned int sw,gw;
sw=m/10;
gw=m%10;
P2=0X04;
P0=shumaguan[sw];
delay(1000);
P2=0X00;
P0=shumaguan[gw];
delay(1000);
void KEY()
P1=0X0F;
if(P1!=0x0f)
  delay(1000);
  if(P1!=0x0f)
   switch(anjian)
    case(0x07): keyshu=0;break;
    case(0x0b): keyshu=1;break;
    case(0x0d): keyshu=2;break;
    case(0x0e): keyshu=3;break;
   P1=0XF0;
   switch(anjian)
    case(0x70): keyshu=keyshu;break;
    case(0xB0): keyshu=keyshu+4;break;
    case(0xD0): keyshu=keyshu+8;break;
    case(0xE0): keyshu=keyshu+12;break;
   while(a<50&&anjian!=0x0f)
    delay(1000);
    a++;
{ while(1)
  KEY();
  xianshi(keyshu);
}#include<reg51.h>
#define anjian P1
unsigned int a;
   while(i--);
unsigned int sw,gw;
sw=m/10;
gw=m%10;
P2=0X04;
P0=shumaguan[sw];
delay(1000);
P2=0X00;
P0=shumaguan[gw];
delay(1000);
void KEY()
P1=0X0F;
if(P1!=0x0f)
  delay(1000);
  if(P1!=0x0f)
   switch(anjian)
   P1=0XF0;
   switch(anjian)
    delay(1000);
    a++;
{ while(1)
  KEY();
  xianshi(keyshu);
ID:541708 發表于 2019-5-18 21:53 | 只看該作者
矩陣可以弄出來,但加減法不會弄
