查看: 1189|回復(fù): 1
點陣靜止顯示
ID:539093 發(fā)表于 2019-5-18 20:52 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include <intrins.h>
sbit LEDARRAY_LAT = P3^6;
sbit LEDARRAY_CLK = P3^5;
sbit LEDARRAY_DI = P3^4;
//函數(shù)或者變量聲明
extern void Delay_ms(unsigned int n);
extern void Send_Byte( unsigned char dat);
//定義變量
unsigned char temp = 0xfe;
unsigned char KEY_NUM = 0;
unsigned char Display_word[4][4] = {
0x00,0x48,0x2A,0x8E,0xFB,0x0E,0x2A,0x48, //親
0x0C,0x1E,0x3E,0x7C,0x7C,0x3E,0x1E,0x0C, //心
//主函數(shù)
    unsigned int i;
    unsigned char j,k;
        for(i = 0 ; i < 1000 ; i++)
            temp = 0x7f;
            for(j = 0 ; j < 2 ; j++)        //顯示前兩個字母
                for(k = 0 ; k < 4 ; k++)        //一個字母4BYTE
                    Send_Byte(temp);            //列選擇
                    Send_Byte(Display_word[j][k]);          //行數(shù)據(jù)
                    LEDARRAY_LAT = 1;                   //鎖存數(shù)據(jù)
                    _nop_();
                    LEDARRAY_LAT = 0;
                    _nop_();
                    temp = (temp>>1)|0x80;
            temp = 0x7f;
            for(j = 2 ; j < 4 ; j++)        //顯示前兩個字母
                    _nop_();
                    LEDARRAY_LAT = 0;
                    _nop_();
//發(fā)送一個字節(jié)數(shù)據(jù)
    unsigned char i;
    LEDARRAY_CLK = 0;
    _nop_();
    LEDARRAY_LAT = 0;
    _nop_();
    for( i = 0 ; i < 8 ; i++ )
        if( dat&0x01 )
            LEDARRAY_DI = 1;
            LEDARRAY_DI = 0;
        LEDARRAY_CLK = 1;               //上升沿發(fā)送數(shù)據(jù)
        //              _nop_();
        LEDARRAY_CLK = 0;
        //              _nop_();
        dat >>= 1;
ID:1 發(fā)表于 2019-5-19 19:29 | 顯示全部樓層
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
