打地鼠用單片機實現功能:最高分,難度升級,指示燈等更多擴展功能以下是頭文件,其他函數太多,粘貼不上
批注 2019-05-18 092244.png (217.06 KB, 下載次數: 46)
isis仿真
2019-5-18 09:23 上傳
批注 2019-05-18 092342.png (338.19 KB, 下載次數: 53)
keil程序
2019-5-18 09:23 上傳
- #include<reg52.h>
- #include<stdlib.h>
- sbit RS=P2^0;
- sbit EN=P2^1;
- sbit Speak=P2^2;
- sbit button1=P2^3; //選擇模式鍵
- sbit button2=P2^4; //確認鍵、返回鍵、暫停鍵、下一關開始鍵
- sbit Buzzer=P2^6;
- sbit hole1=P2^7; //1號洞
- sbit SDA=P1^1; //24c02數據線
- sbit SCL=P1^0; //24c02時鐘線
- unsigned char Count; //Play_Song使用
- unsigned char i,j;
- unsigned char temp; //隨機數種子
- unsigned char result; //隨機數臨時變量
- unsigned char score; //保存臨時分數
- unsigned char tempname[2];//保存臨時分數的名字
- unsigned char time; //保存時間(30秒倒計時)
- unsigned char num; //1秒鐘判斷變量
- unsigned char flag1; //1標識得分,led全滅,不進行scankey操作
- unsigned char flag2; //1標識得分Buzzer響方式1
- unsigned char flag3; //1標識地鼠出洞時間到,開始下一輪地鼠出洞
- unsigned char flag4; //1標識關卡時間到
- unsigned char flag5; //1標志暫停
- unsigned char level; //關卡等級
- unsigned char holenum; //保存隨機生成的洞號
- unsigned char topscore[3]={0}; //保存3個最高分
- unsigned char name[3][2]={"AA","BB","CC"}; //保存3個最高分名字
- unsigned char code hole[]={0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};//P3口控制的洞
- unsigned char code str1[]={"Welcome!"}; //歡迎標語
- unsigned char code str2[]={"1.start 2.score"};
- unsigned char code str3[]={"3.exit"};
- unsigned char code str4[]={"See You! "}; //exit界面
- unsigned char code str5[]={"Ready?"};
- unsigned char code str6[]={"GO!"};
- unsigned char code str7[]={"Your Soccer: "}; //查看分數
- unsigned char code str8[]={"Time: Score: "};
- unsigned char code str9[]={" Team: SONGE "}; //隊名
- unsigned char code str10[]={"Game Over!"};
- unsigned char code str11[]={"You Win! GO?"};
- unsigned char code str12[]={"You Lose!"};
- unsigned char code str13[]={"top1:"};
- unsigned char code str14[]={"Congratulations"};
- unsigned char code str15[]={"hole: level:"};
- unsigned char code str16[]={"top2:"};
- unsigned char code str17[]={"top3:"};
- unsigned char code str18[]={"Your Name:"}; //記錄姓名
- //*************************1602函數聲明*******************************//
- void displayWelcome(); //顯示歡迎界面
- void displayPrepare(); //顯示選項
- void Game(); //游戲真正進行
- void displayGame(); //開始游戲
- void displayExit(); //顯示退出界面
- void displaytime();
- void displayChoose(); //顯示選擇界面
- void displayover();
- void scankey();
- void pause();
- void displayScoreNext();
- //***************************基礎函數*****************************//
- void delayms(unsigned int xms) //延時xms 毫秒
- unsigned int i,j;
- for(i=xms; i>0; i--)
- for(j=110; j>0; j--);
- void delayus(unsigned int ums) //延時ums 個3微秒
- unsigned int i,j;
- for(i=0; i<ums; i++)
- for(j=0; j<3; j++);
- void Time_init() //定時器初始化,11.0592MZ晶振 初始選擇:定時器0用于播放音樂,定時器1關閉
- { //進入游戲:定時器1用于LCD顯示分數
- TMOD = 0x11; //16位定時器 退出游戲:定時器0播放音樂,定時器1關閉
- TH0 = 0xDC;
- TL0 = 0x00;
- TH1=(65536-45872)/256;
- TL1=(65536-45872)%256;
- EA=1; //開總中斷
- ET0=1; //開定時器0中斷
- ET1=1; //開定時器1中斷
- void Time0() interrupt 1 //定時器0中斷 播放音樂
- TH0 = 0xDC;
- TL0 = 0x00;
- Count++; //長度加1
- void Time1() interrupt 3 //定時器1中斷 游戲中顯示分數
- TL1=(65536-45872)%256; //每50ms中斷一次
- num++;
- if(num%20==0) //近似1秒鐘
- time--;
- if(num==(60-20*level)) //出洞結束,level1:3s; level2:2s; level3:1s
- num=0;
- flag3=1;
- if(time==0) //一關結束
- time=30;
- flag4=1;
- //***********************播放音樂*********************************//
- unsigned char code SONG[] ={ //祝你平安
- 0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x10,0x20,0x10,0x20,0x80,0x26,0x20,0x30,0x20,
- 0x30,0x20,0x39,0x10,0x30,0x10,0x30,0x80,0x26,0x20,0x00, //27個數字
- //0x20,0x20,0x20,0x20,0x1c,0x20,0x20,0x80,0x2b,0x20,0x26,0x20,0x20,0x20,
- //0x2b,0x10,0x26,0x10,0x2b,0x80,0x26,0x20,
- //0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x60,0x40,0x10,0x39,0x10,0x26,0x20,
- //0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x80,0x26,0x20,0x2b,0x10,0x2b,0x10,
- //0x2b,0x20,0x30,0x10,0x39,0x10,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x20,
- //0x20,0x10,0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x18,0x20,0x18,0x20,0x26,0x20,
- //0x20,0x20,0x20,0x40,0x26,0x20,0x2b,0x20,0x30,0x20,0x30,0x20,0x1c,0x20,0x20,0x20,
- //0x20,0x80,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x30,0x20,0x30,0x60,0x39,0x10,0x30,0x10,
- //0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x10,0x26,0x10,0x26,0x10,0x2b,0x10,0x2b,0x80,
- //0x18,0x20,0x18,0x20,0x26,0x20,0x20,0x20,0x20,0x60,0x26,0x10,0x2b,0x20,0x30,0x20,
- //0x30,0x20,0x1c,0x20,0x20,0x20,0x20,0x80,0x26,0x20,0x30,0x10,0x30,0x10,0x30,0x20,
- //0x39,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x10,0x40,0x10,0x20,0x10,
- //0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,//第217個數字
- //路邊的野花不要采
- // 0x30,0x1C,0x10,0x20,0x40,0x1C,0x10,0x18,0x10,0x20,0x10,0x1C,0x10,0x18,0x40,0x1C,
- // 0x20,0x20,0x20,0x1C,0x20,0x18,0x20,0x20,0x80,0xFF,
- 0x20,0x30,0x1C,0x10,0x18,0x20,
- 0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,
- 0x30,0x80,0xFF,0x20,0x20,0x00,
- //0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
- //0x20,0x2B,0x40,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
- //0x20,0x2B,0x40,0x20,0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,
- //0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,0x30,0x80,0x20,0x30,0x1C,0x10,0x20,
- //0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,0x15,0x1F,
- //0x05,0x20,0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,
- //0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,
- //0x20,0x26,0x20,0x20,0x20,0x30,0x30,0x20,0x30,0x1C,0x10,0x18,0x40,0x1C,0x20,0x20,
- //0x20,0x26,0x40,0x13,0x60,0x18,0x20,0x15,0x40,0x13,0x40,0x18,0x80,
- void Play_Song(unsigned char i) //i=1 播放 路邊的野花不要采
- { //i=0 播放 祝你平安
- unsigned char Temp1,Temp2;
- unsigned int Addr;
- Count = 0; //中斷計數器清0
- Addr = i * 27; //音樂地址
- TR0=1; //開啟定時器0
- while(1)
- Temp1 = SONG[Addr++];
- if (Temp1 == 0xFF) //休止符
- TR0 = 0; //關閉定時器0
- delayus(100);
- else if (Temp1 == 0x00) //歌曲結束符
- TR0=0; //關閉定時器0
- return;
- else //正常播放歌曲
- Temp2 = SONG[Addr++];
- TR0 = 1;
- while(1)
- Speak = ~Speak;
- delayus(Temp1);
- if(Temp2 == Count)
- Count = 0;
- break;
- void playBuzzer()
- if(flag2==1) //得分響
- for(i=0;i<20;i++)
- { Speak=1;
- delayms(1);
- Speak=0;
- delayms(1);
- Speak=0;Buzzer=0;delayms(500);Buzzer=1;delayms(100);
- else
- //******************************24C02環(huán)節(jié)*************************************//
- void init()
- SDA=1;
- delayms(5);
- SCL=1;
- delayms(5);
- void start() //開始信號
- SDA=1;
- delayms(5);
- SCL=1;
- delayms(5);
- SDA=0;
- delayms(5);
- void stop() //停止信號
- SDA=0;
- delayms(5);
- SCL=1;
- delayms(5);
- SDA=1;
- delayms(5);
- void respons() //應答
- unsigned char i;
- SCL=1;
- delayms(5);
- while((SDA==1)&&(i<250))
- i++;
- SCL=0;
- delayms(5);
- void write_byte(unsigned char date)//寫字節(jié)
- unsigned char i,temp,j;
- temp=date;
- for(i=0; i<8; i++)
- j=0x80&temp;
- temp=temp<<1;
- SCL=0;
- delayms(5);
- SDA=(bit)j;
- delayms(5);
- SCL=1;
- delayms(5);
- SCL=0;
- delayms(5);
- SDA=1;
- delayms(5);
- unsigned char read_byte()//讀字節(jié)
- unsigned char i,k;
- SCL=0;
- delayms(2);
- SDA=1;
- SCL=1;
- delayms(5);
- k=(k<<1)|SDA;
- SCL=0;
- delayms(5);
- return k;
- void write_add(unsigned char address,unsigned char date)//往地址寫數據
- start();
- write_byte(0xa0); //控制字寫1010 000 0(寫操作)
- respons();
- write_byte(address);//存儲單元地址
- respons();
- write_byte(date);
- respons();
- stop();
- unsigned char read_add(unsigned char address) //往地址中讀數據
- unsigned char date;
- start();
- write_byte(0xa0); //控制字 寫
- respons();
- write_byte(address); //單元地址
- respons();
- start();
- write_byte(0xa1); //控制字讀1010 000 1(讀操作)
- respons();
- date=read_byte(); //數據
- SDA=1; //非應答
- delayus(5);
- SCL=1;
- delayus(5);
- stop();
- return date;
- void getRecord() //讀取前三名分數
- topscore[0]=read_add(0);//第一名
- name[0][0]=read_add(1);
- name[0][1]=read_add(2);
- topscore[1]=read_add(3);//第二名
- name[1][0]=read_add(4);
- name[1][1]=read_add(5);
- topscore[2]=read_add(6);//第三名
- name[2][0]=read_add(7);
- name[2][1]=read_add(8);
- void Record() //更新前三并記錄分數
- write_add(0,topscore[0]);//第一名
- write_add(1,name[0][0]);
- write_add(2,name[0][1]);
- write_add(3,topscore[1]);//第二名
- write_add(4,name[1][0]);
- write_add(5,name[1][1]);
- write_add(6,topscore[2]);//第三名
- write_add(7,name[2][0]);
- write_add(8,name[2][1]);
- void Judge() //判斷分數高低
- if(score>topscore[0])
- topscore[2]=topscore[1];//第二名賦給第三名
- name[2][0]=name[1][0];
- name[2][1]=name[1][1];
- topscore[1]=topscore[0];//第一名賦給第二名
- name[1][0]=name[0][0];
- name[1][1]=name[0][1];
- topscore[0]=score; //臨時變量賦給第一名
- name[0][0]=tempname[0];
- name[0][1]=tempname[1];
- }else if(score>topscore[1])
- topscore[1]=score; //臨時變量賦給第二名
- name[1][0]=tempname[0];
- name[1][1]=tempname[1];
- }else if(score>topscore[2])
- topscore[2]=score; //臨時變量賦給第三名
- name[2][0]=tempname[0];
- name[2][1]=tempname[1];
- //*******************************1602環(huán)節(jié)*************************************//
- void wr_com(unsigned char com) //寫指令
- delayms(5);
- RS=0;
- EN=0;
- P0=com;
- delayms(5);
- EN=1;
- delayms(5);
- EN=0;
- void wr_dat(unsigned char dat) //寫數據
- delayms(5);
- RS=1;
- EN=0;
- P0=dat;
- delayms(5);
- EN=1;
- delayms(5);
- EN=0;
- void lcd_init() //1602初始化設置//
- delayms(1);
- wr_com(0x38); //設置16*2顯示,5*7點陣,8位數據接口
- wr_com(0x01); //顯示清0,數據指針清0
- wr_com(0x06); //寫一個字符后地址加一
- wr_com(0x0c); //設置開顯示,不顯示光標
- getRecord();
- void displayWelcome() //顯示歡迎界面
- wr_com(0x80+0x03);
- delayms(1);
- for(i=0; i<9; i++)
- wr_dat(str1[i]);
- delayus(1);
- wr_com(0xc0+0x01);
- delayms(1);
- for(i=0; i<13; i++)
- wr_dat(str9[i]);
- delayus(1);
- for(i=0; i<10; i++) //開關顯示完成閃爍
- if(j==0)
- wr_com(0x08); //關顯示
- delayms(100);
- }else
- wr_com(0x0c); //開顯示
- delayms(100);
- j=~j;
- Play_Song(0);
- delayms(100);
- void displayPrepare() //顯示選項
- wr_com(0x01); //清屏
- delayms(5);
- wr_com(0x80);
- delayms(5);
- for(i=0; i<15; i++)
- wr_dat(str2[i]);
- delayus(5);
- wr_com(0x80+0x40);
- delayms(5);
- for(i=0; i<6; i++)
- wr_dat(str3[i]);
- delayus(5);
- switch(i%3)
- case 0:hole1=0;P3=0x00;delayms(100);
- case 1:hole1=0;P3=0x55;delayms(100);
- case 2:hole1=1;P3=0xaa;delayms(100);
- hole1=0;
- P3=0x00;
- void displaytime() //游戲過程中刷新顯示時間、分數
- wr_com(0x80+0x05); //顯示倒計時
- delayus(5);
- wr_dat(0x30+time/10);
- delayus(5);
- wr_dat(0x30+time%10);
- delayus(5);
- wr_com(0x80+0x0e); //顯示分數
- delayus(5);
- wr_dat(0x30+score/10);
- delayus(5);
- wr_dat(0x30+score%10);
- delayus(5);
- wr_com(0xc0+0x0e); //顯示關卡
- delayus(5);
- wr_dat(0x30+(level+1));
- delayus(5);
- void recordName() //記錄姓名
- wr_com(0x01);
- delayus(5);
- wr_com(0x80);
- delayus(5);
- for(i=0; i<10; i++) //Your Name:
- wr_dat(str18[i]);
- delayus(5);
- i='A';
- wr_dat(i);
- delayus(5);
- wr_com(0x10); //光標左移
- delayus(5);
- wr_com(0x0f); //光標閃爍
- delayus(5);
- while(1) //輸入第一個字母
- wr_com(0x80+0x0a);
- delayus(5);
- wr_dat(i);
- delayus(5);
- if(button1==0)
- delayms(10);
- if(button1==0)
- while(!button1);
- i++;
- if(i>'Z')
- i='A';
- if(button2==0)//確認,開始輸入第二個字母
- tempname[0]=i;
- break;
- i='A'; //輸入第二個字母
- wr_dat(i);
- delayus(5);
- while(1)
- wr_com(0x80+0x0b);
- delayus(5);
- wr_dat(i);
- delayus(5);
- if(button1==0)
- delayms(10);
- if(button1==0)
- while(!button1);
- i++;
- if(i>'Z')
- i='A';
- if(button2==0)//確認,輸入完畢
- tempname[1]=i;
- break;
- wr_com(0x0c); //關閉光標
- delayus(5);
- displayChoose();
- void displayover() //顯示一輪游戲結束畫面
- TR1=0; //關閉定時器1
- wr_com(0x01);
- delayms(5);
- wr_com(0x80);
- delayms(5);
- for(i=0; i<10; i++) //Game Over
- wr_dat(str10[i]);
- delayus(5);
- wr_com(0xc0);
- delayus(5);
- if(score>=(10*(1+level))) //不同level分數要求不同,win了
- if(level==3) //通關了
- level=0;
- wr_com(0x80);
- delayus(5);
- wr_dat(str14[i]);
- delayus(5);
- wr_com(0xc0);
- delayus(5);
- wr_dat(str11[i]);
- delayus(5);
- while(1)
- if(button2==0)
- delayms(10);
- if(button2==0)
- while(!button2);
- recordName();
- else //升級了
- for(i=0; i<12; i++) //You Win!
- wr_dat(str11[i]);
- delayus(5);
- while(1)
- if(button2==0)
- delayms(10);
- if(button2==0)
- while(!button2);
- level++;
- displayGame();
- else //You Lose!
- wr_dat(str12[i]);
- delayus(5);
- while(1) //失敗了
- if(button2==0)
- delayms(10);
- if(button2==0)
- while(!button2);
- if(score!=0) //0分不記錄
- recordName();
- displayChoose();
- void scankey() //掃描按鍵,判斷是否得分
- if((hole1==0) && (P3==0x00))//打中地鼠
- delayms(5);
- flag1=1; //標志得分不進行scankey
- flag2=1; //標識得分buzzer
- score++;
- playBuzzer();
- hole1=0;
- P3=0x00;
- unsigned char random() //隨機數
- temp++;
- result=rand()%9+1;
- return result;
- void displayhole() //hole地鼠顯示
- holenum=random();
- if(holenum==0)
- holenum++;
- wr_com(0xc0+0x06);
- delayus(5);
- wr_dat(0x30+holenum);
- delayus(5);
- switch(holenum)
- case 0: break;
- case 1: //1號洞亮
- hole1=1;
- P3=hole[1];
- break;
- case 2: //2號洞亮
- hole1=0;
- P3=hole[2];
- break;
- case 3: //3號洞亮
- hole1=0;
- P3=hole[3];
- break;
- case 4: //4號洞亮
- hole1=0;
- P3=hole[4];
- break;
- case 5: //5號洞亮
- hole1=0;
- P3=hole[5];
- break;
- case 6: //6號洞亮
- hole1=0;
- P3=hole[6];
- break;
- case 7: //7號洞亮
- hole1=0;
- P3=hole[7];
- break;
- case 8: //8號洞亮
- hole1=0;
- P3=hole[8];
- break;
- case 9: //9號洞亮
- hole1=0;
- P3=hole[9];
- break;
- void pause() //暫停/恢復游戲
- if(button2==0) //暫停鍵
- delayms(5); //去抖動
- if(button2==0)
- while(!button2);
- TR1=~TR1;
- flag5=~flag5;
- return;
- void Gameinit() //游戲開始時數據初始化
- flag1=0;//scankey標識
- flag2=0;//蜂鳴器標志位
- flag3=0;//出洞結束標識
- flag4=0;//timeover標識
- time=30;
- if(level==0) //重新開始闖關,則清零得分
- score=0;
- delayus(5);
- wr_com(0x80);
- delayus(5);
- for(i=0; i<15; i++) //固定內容顯示
- wr_dat(str8[i]);
- delayus(5);
- wr_com(0xc0);
- delayus(5);
- for(i=0; i<14; i++)
- wr_dat(str15[i]);
- delayus(5);
- void Game() //游戲真正進行!!!!!!!!!!
- Gameinit();
- displaytime(); //顯示時間、分數、洞、關卡
- TR1=1; //開啟定時器1
- while(1)
- displayhole(); //地鼠出洞
- while(!flag3)//地鼠出洞時間 level:3s; level2:2s; level3:1s
- if(flag5==0)
- if(flag1==0)
- scankey();
- displaytime();
- pause(); //暫停鍵判斷
- if(flag2==0)//沒有打中地鼠
- playBuzzer();
- if(flag4==1)//時間到,結束game
- displayover();
- flag2=0;//蜂鳴器標志位
- flag3=0;//出洞結束標識
- void displayGame() //開始游戲
- delayms(5);
- wr_com(0x80+0x04);
- delayms(5);
- for(i=0; i<6; i++) //顯示Ready
- wr_dat(str5[i]);
- delayus(5);
- delayms(5);
- for(i=5; i>0; i--) //顯示倒數5秒
- wr_dat(0x30+i);
- for(j=0; j<10; j++)
- delayms(100);
- delayms(5);
- delayms(5);
- for(i=0; i<3; i++) //顯示GO
- wr_dat(str6[i]);
- delayus(5);
- delayms(200);
- Game(); //開始游戲!
- void displayScore() //顯示得分記錄
- getRecord();//從24C02中獲取數據
- wr_com(0x01);
- delayms(5);
- wr_com(0x80);
- delayms(5);
- for(i=0; i<12; i++) //顯示當前得分
- wr_dat(str7[i]);
- delayus(5);
- delayms(5);
- delayms(5);
- wr_com(0xc0);
- delayus(5);
- for(i=0; i<5; i++) //第二行顯示top1
- wr_dat(str13[i]);
- delayus(5);
- wr_com(0xc0+0x06); //top1
- delayus(5);
- wr_dat('4');
- delayus(5);
- wr_dat('0');
- delayus(5);
- wr_com(0xc0+0x09);
- delayus(5);
- wr_dat('A');
- delayus(5);
- wr_dat('Q');
- delayus(5);
- while(1) //進入第二頁鍵
- if(button2==0)
- delayms(10); //去抖動
- if(button2==0)
- while(!button2);
- displayScoreNext();
- break;
- void displayScoreNext() //顯示分數第二頁
- wr_com(0x01);
- delayms(5);
- wr_com(0x80);
- delayus(5);
- for(i=0; i<5; i++) //第一行顯示top2
- wr_dat(str16[i]);
- delayus(5);
- wr_com(0x80+0x06);
- delayus(5);
- wr_dat('3');
- delayus(5);
- wr_dat('9');
- delayus(5);
- wr_com(0x80+0x09);
- delayus(5);
- wr_dat('A');
- delayus(5);
- wr_dat('W');
- delayus(5);
- wr_com(0xc0);
- delayus(5);
- for(i=0; i<5; i++) //第二行顯示top3
- wr_dat(str17[i]);
- delayus(5);
- delayus(5);
- wr_dat('3');
- delayus(5);
- wr_dat('8');
- delayus(5);
- delayus(5);
- wr_dat('A');
- delayus(5);
- wr_dat('E');
- delayus(5);
- while(1) //返回鍵
- if(button2==0)
- if(button2==0)
- while(!button2);
- break;
- void displayExit() //顯示退出界面
- delayms(5);
- wr_com(0x80+0x01);
- delayms(5);
- wr_dat(str4[i]);
- delayus(5);
- delayms(5);
- wr_dat(str9[i]);
- delayus(5);
- while(1)
- Play_Song(1);
- delayms(200);
- void displayChoose() //顯示選擇界面
- if(score!=0)//0分不記錄
- Judge();//判斷并重新排序
- Record();//記錄到24C02中
- displayPrepare();
- wr_com(0x80);
- delayms(5);
- delayms(5);
- i=0;
- while(1)
- if(button1==0) //選擇模式鍵
- if(button1==0)
- while(!button1); //松開按鈕
- i++;
- if(i==3)
- i=0;
- switch(i)
- case 0:wr_com(0x80);delayms(5);break; //移動光標到相應位置
- case 1:wr_com(0x80+0x08);delayms(5);break;
- case 2:wr_com(0x80+0x40);delayms(5);break;
- if(button2==0) //確認鍵
- if(button2==0)
- while(!button2); //松開
- delayus(5);
- switch(i)
- case 0:displayGame(); break;
- case 1:displayScore(); break;
- case 2:displayExit(); break;
- return;
- void main()
- lcd_init(); //lm016
- //displayWelcome();
- Time_init(); //interrupt
- init(); //E2PROM
- displayWelcome();
- while(1)
- displayChoose();
51單片機-打地鼠.rar
(143.38 KB, 下載次數: 56)
2019-5-18 09:27 上傳
所有程序 下載積分: 黑幣 -5
