請(qǐng)問(wèn)在超聲波測(cè)距電路中加入藍(lán)牙傳輸模塊,在原本測(cè)距程序的基礎(chǔ)上修改程序后不能正常測(cè)距,這是什么原因,應(yīng)該如何修改,謝謝各位大佬
下有測(cè)距原理圖
附上
未加藍(lán)牙部分的原理圖
2019-5-16 16:45 上傳
修改的程序:
#include "reg52.H"//器件配置文件
#include "intrins.h"
#include "eeprom52.h"
#include "uart.h"
#include "stdio.h"
//傳感器接口
sbit RX = P2^3;
sbit TX = P2^2;
//按鍵聲明
sbit S1 = P1^4;
sbit S2 = P1^5;
sbit S3 = P1^6;
//小數(shù)點(diǎn)
sbit DIAN = P0^5;
//蜂鳴器
sbit Feng = P2^0;
sbit W0 = P2^4;
sbit W1 = P2^5;
sbit W2 = P2^6;
sbit W3 = P2^7;
//變量聲明
unsigned int time = 0;
unsigned int timer = 0;
unsigned char posit = 0;
unsigned long S = 0;
unsigned long BJS;//報(bào)警距離
char num = 0;
uchar count = 0;
//模式 0正常模式 1調(diào)整
char Mode = 0;
bit flag = 0;
unsigned char const discode[] = {0x5F,0x44,0x9D,0xD5,0xC6,0xD3,0xDB,0x47,0xDF,0xD7,0x80}; //數(shù)碼管顯示碼0123456789-和不顯示
unsigned char disbuff[4] = {0,0,0,0}; //數(shù)組用于存放距離信息
unsigned char disbuff_BJ[4] = {0,0,0,0};//報(bào)警信息
//藍(lán)牙發(fā)送
uchar Tx_Buff[40]={0};
uint send_time = 0; //發(fā)送時(shí)間間隔控制變量
void HR04_sendstring(); //串口發(fā)送
/******************把數(shù)據(jù)保存到單片機(jī)內(nèi)部eeprom中******************/
void write_eeprom()
SectorErase(0x2000);
byte_write(0x2000, BJS);
byte_write(0x2060, a_a);
/******************把數(shù)據(jù)從單片機(jī)內(nèi)部eeprom中讀出來(lái)*****************/
void read_eeprom()
BJS = byte_read(0x2000);
a_a = byte_read(0x2060);
/**************開(kāi)機(jī)自檢eeprom初始化*****************/
void init_eeprom()
read_eeprom(); //先讀
if(a_a != 1) //新的單片機(jī)初始單片機(jī)內(nèi)問(wèn)eeprom
BJS = 25;
a_a = 1;
write_eeprom(); //保存數(shù)據(jù)
//延時(shí)100ms(不精確)
void delay(void)
unsigned char a,b,c;
for(c=10;c>0;c--)
for(b=38;b>0;b--)
for(a=130;a>0;a--);
//按鍵掃描
void Key_()
if(S1==0&&Mode==1)
delay(); //延時(shí)去抖
while(S1==0)
P1=P1|0x0f;
BJS++; //報(bào)警值加
if(BJS>=151) //最大151
BJS=0;
if(S2==0&&Mode==1)
delay();
while(S2==0)
P1=P1|0x0f;
BJS--; //報(bào)警值減
if(BJS<=1) //最小1
BJS=150;
//功能
if(S3==0) //設(shè)置鍵
delay();
while(S3==0)
P1=P1|0x0f;
Mode++; //模式加
num=0;
if(Mode>=2) //加到2時(shí)清零
Mode=0;
//掃描數(shù)碼管
void Display(void)
//正常顯示
if(Mode==0)
num++;
if(num==1)
W3=1;
W0=1;
P0=~discode[disbuff[0]];
DIAN=0;
W1=0;
else if(num==2)
W1=1;
P0=~discode[disbuff[1]];
W2=0;
else if(num>=3)
W2=1;
P0=~discode[disbuff[2]];
W3=0;
num=0;
//報(bào)警顯示
num++;
if(num==1)
W3=1;
P0=~0xCE; //11001110
W0=0;
else if(num==2)
W0=1;
P0=~discode[disbuff_BJ[0]];
DIAN=0;
W1=0;
else if(num==3)
W1=1;
P0=~discode[disbuff_BJ[1]];
W2=0;
else if(num>=4)
W2=1;
P0=~discode[disbuff_BJ[2]];
W3=0;
num=0;
//計(jì)算
void Conut(void)
time=TH0*256+TL0; //讀出T0的計(jì)時(shí)數(shù)值
TH0=0;
TL0=0; //清空計(jì)時(shí)器
S=(time*1.7)/100; //算出來(lái)是CM
//聲音的速度是340m/s,時(shí)間的單位是us,計(jì)算到秒需要將時(shí)間數(shù)據(jù)/1000000,
//長(zhǎng)度=速度*時(shí)間,340*time/1000000,長(zhǎng)度數(shù)據(jù)單位是m轉(zhuǎn)換成cm需要乘以100得到340*time/10000,
//小數(shù)點(diǎn)都向左移兩位得到3.4*time/100,因?yàn)槌暡ㄊ峭盗耍栽俪?,得到距離數(shù)據(jù)(time*1.7)/100
if(Mode==0) //非設(shè)置狀態(tài)時(shí)
if((S>=700)||flag==1) //超出測(cè)量范圍顯示“-”
Feng=0; //蜂鳴器報(bào)警
flag=0;
disbuff[0]=10; //“-”
disbuff[1]=10; //“-”
disbuff[2]=10; //“-”
//距離小于報(bào)警距
if(S<=BJS)
Feng=0; //報(bào)警
else //大于
Feng=1; //關(guān)閉報(bào)警
disbuff[0]=S%1000/100; //將距離數(shù)據(jù)拆成單個(gè)位賦值
disbuff[1]=S%1000%100/10;
disbuff[2]=S%1000%10 %10;
Feng=1;
disbuff_BJ[0]=BJS%1000/100;
disbuff_BJ[1]=BJS%1000%100/10;
disbuff_BJ[2]=BJS%1000%10 %10;
//定時(shí)器0
void zd0() interrupt 1 //T0中斷用來(lái)計(jì)數(shù)器溢出,超過(guò)測(cè)距范圍
flag=1; //中斷溢出標(biāo)志
//定時(shí)器1
void zd3() interrupt 3 //T1中斷用來(lái)掃描數(shù)碼管和計(jì)800MS啟動(dòng)模塊
TH1=0xf8;
TL1=0x30; //定時(shí)2ms
Key_(); //掃描按鍵
Display(); //掃描顯示
timer++; //變量加
if(timer>=400) //400次就是800ms
timer=0;
TX=1; //800MS 啟動(dòng)一次模塊
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
TX=0;
//主函數(shù)
void main(void)
TMOD=0x11; //設(shè)T0為方式1,GATE=1;
TH0=0;
TL0=0;
TH1=0xf8; //2MS定時(shí)
TL1=0x30;
ET0=1; //允許T0中斷
ET1=1; //允許T1中斷
TR1=1; //開(kāi)啟定時(shí)器
EA=1; //開(kāi)啟總中斷
init_eeprom(); //開(kāi)始初始化保存的數(shù)據(jù)
while(!RX); //當(dāng)RX為零時(shí)等待
TR0=1; //開(kāi)啟計(jì)數(shù)
while(RX); //當(dāng)RX為1計(jì)數(shù)并等待
TR0=0; //關(guān)閉計(jì)數(shù)
Conut(); //計(jì)算
void T_0()interrupt 1
TF0 = 0;
TL0 = 0x66;
TH0 = 0xfc;
count++;
if(count==18) //18ms時(shí)清零
TR0 =0;
TL0 = 0x66;
TH0 = 0xfc;
count = 0;
void T_1()interrupt 3
uchar num;
TH1=(65536-45872)/256; //計(jì)數(shù)器裝裝數(shù)值
TL1=(65536-45872)%256;
num++;
if(num==10)
num=0;
Key_(); //按鍵掃描函數(shù)
void HR04_sendstring() //串口發(fā)送
if(send_time%20==0)
EA=0;
sprintf((char*)Tx_Buff,"Distance:%.1fcm\r\n",S/10.0);
UART1_SendString(Tx_Buff);
EA=1;
send_time++;
