給你改了,對(duì)比一下就知道哪里錯(cuò)了。
- #include <stc15.h>
- sbit S0 = P4^1;
- sbit S1 = P4^2;
- sbit S2 = P4^3;
- sbit S3 = P4^4;
- sbit leden = P2^7;
- unsigned char tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x6f}; //數(shù)組
- unsigned char wei[]={0,0,0,0}; //顯示的位
- unsigned char flag1s=0;
- unsigned char i=0;
- unsigned int j=0; // 、、??//計(jì)時(shí)次數(shù)
- void Timer0Init(void) //100微秒@11.0592MHz
- AUXR |= 0x80; //定時(shí)器時(shí)鐘1T模式
- TMOD &= 0xF0; //設(shè)置定時(shí)器模式
- TMOD |= 0x01; //設(shè)置定時(shí)器模式
- //TMOD &= 0x01; //設(shè)置定時(shí)器模式
- TL0 = 0x67; //設(shè)置定時(shí)初值
- TH0 = 0xFC; //設(shè)置定時(shí)初值
- TF0 = 0; //清除TF0標(biāo)志
- TR0 = 1; //定時(shí)器0開(kāi)始計(jì)時(shí)
- void main()
- unsigned long k=0;
- TMOD = 0X01;
- TH0 = 0XFC;
- TL0 = 0X67;
- TR0 = 1;
- EA = 1;
- ET0 = 1;
- leden = 0;
- while(1)
- if(flag1s==1) //定時(shí)器溢出復(fù)位
- { flag1s =0;
- k++;
- wei[3] = tab[k%10];
- wei[2] = tab[k/10%10];
- wei[1] = tab[k/100%10];
- wei[0] = tab[k/1000%10];
- void IntrruptTime0() interrupt 1
- TH0=0XFC;
- TL0=0X67;
- j++;
- if(j>=1000)
- j = 0;
- flag1s = 1;
- P0=0xFF;
- switch(i)
- case 0: S3=1;S2=0;S1=0;S0=0;i++;P0=wei[0];
- case 1: S3=0;S2=1;S1=0;S0=0;i++;P0=wei[1];
- case 2: S3=0;S2=0;S1=1;S0=0;i++;P0=wei[2];
- case 3: S3=0;S2=0;S1=0;S0=1;i++;P0=wei[3];
- default: break;
復(fù)制代碼 |
