查看: 1581|回復: 1
簡易直流電壓表程序
ID:539093 發表于 2019-5-15 19:32 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
uchar LCD[6];   //電壓數據轉換成LCD1602液晶字符顯示
uint Volt;
sbit DO  = P1^0;        //時鐘
sbit CS  = P1^1;        //片選
sbit CLK = P1^2;        //數據輸出
sbit RS = P2^0;                        //1602液晶數據/命令選擇端
sbit RW = P2^1;                        //1602液晶讀寫端
sbit E  = P2^2;                        //1602液晶使能端
// Function Prototypes
void check_busy(void);
void write_command(uchar com);
void write_date(uchar date);
void LCD_init(void);
void string(uchar ad ,uchar *s);
//void lcd_test(void);
void delay(uint);
void Volt_To_LCD1602(void);
void delay_ms(uint xms);
void Data_Conversion(void);
uchar TLC549_ADC(void);
    LCD1602 Driver mapped as IO peripheral
// Delay
// Delay
void delay(uint j)
        uchar i = 60;
  for(; j>0; j--)
                while(--i);
    i = 59;
    while(--i);
    i = 60;
// Test the Busy bit
        do
                P0 = 0xff;
    E = 0;
    RS = 0;
    RW = 1;
    E = 1;
    _nop_();
  } while(P0 & 0x80);
  E = 0;
// Write a command
        check_busy();
  E = 0;
  RS = 0;
  RW = 0;
  P0 = com;
  E = 1;
  _nop_();
  E = 0;
  delay(1);
// Write Data
        check_busy();
  E = 0;
  RS = 1;
  RW = 0;
  P0 = date;
  E = 1;
  _nop_();
  E = 0;
  delay(1);
// Initialize LCD controller
void LCD_init(void)
        write_command(0x38); // 8-bits, 2 lines, 7x5 dots
  write_command(0x0C); // no cursor, no blink, enable display
  write_command(0x06); // auto-increment on
  write_command(0x01); // clear screen
  delay(1);
// Display a string
void string(uchar ad, uchar *s)
        write_command(ad);
  while(*s>0)
                 write_date(*s++);
     delay(100);
//函數名:delay_ms(uint xms)
//函數功能:ms級延時函數
        uint x,y;
        for(x=xms;x>0;x--)
                for(y=110;y>0;y--);
//函數名稱:TLC549_ADC()
//函數功能:讀取上一次A/D轉換的數據,啟動下一次A/D轉換
        uchar n, tmp;
        CS  = 1;                     //CS置高,片選無效
        CLK = 0;
        CS  = 0;                     //CS置低,片選有效,同時DO輸出高位
        _nop_();
        _nop_();                     //適當延遲時間1.4us Setup Time
        for(n = 0; n < 8; n++) //串行數據移位輸入
                tmp <<= 1;
                tmp |=  DO;
                CLK = 1;        //0.4us
                _nop_();          //CLK transition time Max 0.1us
                CLK = 0;        //0.4us
        CS = 1;            //CS置高,片選無效
        for(n = 17; n != 0; n--) _nop_();  //Next Coversion需要延遲17us
        return (tmp);
//函數名稱ata_Conversion()
//函數功能:電壓換算
        uchar AD_Data;
        AD_Data = TLC549_ADC();
        delay_ms(1000);
        Volt = 5.0 / 256 * AD_Data*1000;
        Data_Conversion();                     //電壓換算并放大1000倍
        LCD[0] = Volt/1000;         //千位
        LCD[1] = '.';                                //小數點
        LCD[2] = Volt/100%10;  //百位
        LCD[3] = Volt/10%10;    //十位
        LCD[4] = Volt%10;           //個位
        LCD[5] = 'V';                              //字符V
        write_command(0x80+8);
        write_date(0x30+LCD[0]);
        write_date(LCD[1]);
        write_date(0x30+LCD[2]);
        write_date(0x30+LCD[3]);
        write_date(0x30+LCD[4]);
        write_date(LCD[5]);
int main()
        //uint m;
        LCD_init();
  delay(100);
        write_command(0x80);
        string(0x80,"Voltage:");
        delay_ms(2000);
                Volt_To_LCD1602();
ID:1 發表于 2019-5-15 23:09 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
