查看: 8763|回復: 6
為什么51單片機中斷后一直卡死在中斷,不會繼續往下執行,也不會返回主程序
ID:524819 發表于 2019-5-15 14:48 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include"2.h"
/***************紅外解碼***********************/
unsigned char IR_DAT[4];
sbit IR=P3^2;           //將IR位定義為P3.2引腳
unsigned int LowTime,HighTime; //儲存高、低電平的寬度
unsigned char bz;
函數功能:對4個字節的用戶碼和鍵數據碼進行解碼
說明:解碼正確,返回1,否則返回0
出口參數:dat
/*****************先知科技******************************
              led顯示驅動程序
                           V1.0-20190512
#include<reg52.h>
sbit SI=P2^0;//定義數據輸入口
sbit SCK=P2^1;//上升沿時數據寄存器的數據移位,a>h
sbit RCK=P2^2;//上升沿時移位寄存器數據進入數據存儲器
        函數功能:延時1ms
void delay1ms()
                   unsigned char i,j;
                 for(i=0;i<10;i++)
                  for(j=0;j<33;j++)
函數功能:延時若干毫秒
入口參數:n
void delay(unsigned int n)
           unsigned int i;
        for(i=0;i<n;i++)
        delay1ms();
void Ser_IN(unsigned char DataH,unsigned char DataL)
unsigned char i;
for(i=0;i<8;i++)
  SCK=0;//現將移位寄存器時鐘置低
  SI=DataH&0x80;//取數據最高位
  DataH<<=1;
  SCK=1;
for(i=0;i<8;i++)
  SCK=0;//現將移位寄存器時鐘置低
  SI= DataL&0x80;//取數據最高位
   DataL<<=1;
  SCK=1;
//并行數據輸出
void Par_OUT(void)
RCK=0;
RCK=1;
void dispay_reset1(void)
Ser_IN(0x00,0x00);         //全部開啟
Par_OUT();
delay(100);
Ser_IN(0xff,0xff);         //全部關閉
Par_OUT();
delay(100);Ser_IN(0x00,0x00);         //全部開啟
Par_OUT();
delay(100);
Par_OUT();
Par_OUT();
delay(100);
Par_OUT();
Par_OUT();
delay(100);
Par_OUT();
Par_OUT();
delay(100);
Par_OUT();
Par_OUT();
delay(100);
Par_OUT();
Par_OUT();
delay(100);
Par_OUT();
Par_OUT();
delay(100);
Par_OUT();
Par_OUT();
delay(100);
Par_OUT();
Par_OUT();
delay(100);
Par_OUT();
Par_OUT();
delay(100);
Par_OUT();
Par_OUT();
delay(100);
Par_OUT();
delay(100);
void dispay_reset(void)
流水燈檢測壞點
Ser_IN(0x7f,0xff);//1
Par_OUT();
delay(100);
Ser_IN(0xbf,0xff);//2
Par_OUT();
delay(100);
Ser_IN(0xdf,0xff);//3
Par_OUT();
delay(100);
Ser_IN(0xef,0xff);//4
Par_OUT();
delay(100);
Ser_IN(0xf7,0xff);//5
Par_OUT();
delay(100);
Ser_IN(0xfb,0xff);//6
Par_OUT();
delay(100);
Ser_IN(0xfd,0xff);//7
Par_OUT();
delay(100);
Ser_IN(0xfe,0xff);//8
Par_OUT();
delay(100);
Ser_IN(0xff,0x7f);//9
Par_OUT();
delay(100);
Ser_IN(0xff,0xbf);//10
Par_OUT();
delay(100);
Ser_IN(0xff,0xdf);//11
Par_OUT();
delay(100);
Ser_IN(0xff,0xef);//12
Par_OUT();
delay(100);
Ser_IN(0xff,0xf7);//13
Par_OUT();
delay(100);
Ser_IN(0xff,0xfb);//14
Par_OUT();
delay(100);
Ser_IN(0xff,0xfd);//15
Par_OUT();
delay(100);
Ser_IN(0xff,0xfe);//16
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
Par_OUT();
delay(100);
main()
{        EA=1;        //開啟總中斷
   EX0=1;       //開外中斷0
ET0=0;       //定時器T1中斷允許
   IT0=1;       //外中斷的下降沿觸發
    TMOD=0x11;   //使用定時器T1的模式1
        TR0=0;       //定時器T0關閉
dispay_reset();
if(0x0a==bz)
Ser_IN(bz,bz);
Par_OUT();
dispay_reset1();
函數功能:紅外線觸發的外中斷處理函數
void Int0(void) interrupt 0
  unsigned char i,j;
   unsigned char IR_temp;    //儲存解碼出的數據
   EX0=0;//關閉外中斷0,不在接收二次紅外信號中斷,只解碼當前的紅外
   TH0=0;//定時器高八位清零
   TL0=0;//定時器T0低八位清0
   TR0=1;//定時器開啟
   while(IR==0);//等待低電平變為高電平計算低電平的時間
   TR0=0;//關閉定時器T0
   LowTime=TH0*256+TL0;//保存低電平的時間
   TH0=0;
   TL0=0;
   TR0=1;//定時器清空之后,重新計算高電平的時間
   while(IR==1);
   TR0=0;//關閉定時器
   HighTime=TH0*256+TL0;
    if((LowTime>7800)&&(LowTime<8800)&&(HighTime>3600)&&(HighTime<4700)) //如果是引導碼,就開始解碼,否則放棄,引導碼的低電平計時
          for(i=0;i<4;i++)
           for(j=0;j<8;j++)
           while(IR==0);//低電平不執行程序,濾掉低電平,只檢測高電平
           TH0=0;
           TL0=0;        //檢測到高電平開始計算高電平持續時間
           TR0=1;
           while(IR==1);//等待高電平結束
           TR0=0;//高電平結束停止計時
           HighTime=TH0*256+TL0; //計算高電平的時間
           IR_temp=IR_temp>>1;
           if((HighTime>420)&&(HighTime<620))   //如果高電平時間在560微秒左右,即計數560/1.085=516次
                                   IR_temp=IR_temp&0x7f;       //(520-100=420, 520+100=620),則該位是0
           if((HighTime>1300)&&(HighTime<1800)) //如果高電平時間在1680微秒左右,即計數1680/1.085=1548次
                                  IR_temp=IR_temp|0x80;
                  IR_DAT[i]=IR_temp;//將得到的數據保存在數組中
                dispay_reset1();
if(IR_DAT[2]!=~IR_DAT[3])
  bz=0xff;
  EX0=1;
        Ser_IN(0xff,0x00);
  Par_OUT();
return;
           bz=IR_DAT[2];
        Ser_IN(bz,bz);
    Par_OUT();
            EX0=1;
dispay_reset();
return;
  // else
//         EX0=0;//關閉外中斷0,不在接收二次紅外信號中斷,只解碼當前的紅外
           //dispay_reset1();
        EX0=1;
//restart:
ID:632653 發表于 2019-11-8 20:08 | 顯示全部樓層
中斷服務函數里面好像是不能執行太多東西的。
ID:394817 發表于 2019-11-24 10:07 | 顯示全部樓層
我是遇到網上拿來的紅外中斷出問題了,回不去主程序,中斷一直沒問題,后來把中斷名改正常了  好像也就好了
void exint0() interrupt 0
ID:606366 發表于 2019-11-26 12:23 | 顯示全部樓層
為什么我在程序中并沒有看到定時器設初值這條?
ID:649922 發表于 2019-11-26 14:42 | 顯示全部樓層
中斷執行完如果有需求需要加個return;中斷不要執行時間太長;不然很容易出現預想不到的問題。
ID:638447 發表于 2019-11-26 17:18 | 顯示全部樓層
中斷里面內容過多
ID:649818 發表于 2019-11-26 17:36 | 顯示全部樓層
