仿真時(shí)候,報(bào)警器和蜂鳴器正常響,但是LCD不顯示溫度。
代碼如下:#include <reg52.h>//頭文件,52單片機(jī)改為52
#include <intrins.h>
#define LCD_DATA P0
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
unsigned char dispBuff0[16]={'T','E','M',
'P',':',' ',' ',' ',' ',' ',' ','C',' ',' ',' ',};//LCD第一行顯示
sbit DQ=P2^3; //DS18B20數(shù)據(jù)端
unsigned int temperature=0;//溫度
unsigned char fuhao=0;//溫度的正負(fù)符號(hào)
//LED報(bào)警指示的IO口以及變量定義
sbit LED1=P2^4;//溫度報(bào)警指示
#define off 1 //高電平時(shí)燈為關(guān)閉狀態(tài)
#define on 0 //低電平時(shí)燈為開(kāi)啟狀態(tài)
sbit speaker=P3^1;//蜂鳴器
void Delay20ms() ;
void LCD_WriteDat(unsigned char lcd_dat);
void LCD_WriteCmd(unsigned char lcd_cmd);
unsigned char LCD_ReadStatus(void);
void LCD_Goto(unsigned char x,unsigned char y);
void LCD_Display(unsigned char row,unsigned char *str);
void delay(unsigned int x)//延時(shí)公用程序
unsigned char j;
while(x--)
for(j=0;j<125;j++);
/*1、LCD模塊子函數(shù)*/
void LCD_Init(void)
Delay20ms();
LCD_WriteCmd(0x38); //8位機(jī)接口、雙行顯示、5×7字符點(diǎn)陣;
LCD_WriteCmd(0x0c); //顯示開(kāi)啟、光標(biāo)不顯示也不閃爍;
LCD_WriteCmd(0x01); //清屏;
LCD_WriteCmd(0x06); //光標(biāo)右移一位、整屏不移動(dòng);
LCD_Goto(0,0);
unsigned char tmp;
tmp = LCD_ReadStatus(); //讀狀態(tài);
while((tmp & 0x80)) //是否忙 ?
LCD_RS = 1;
LCD_RW = 0;
LCD_DATA = lcd_dat;
_nop_();
LCD_EN = 0;
_nop_();
_nop_();
LCD_EN = 1;
unsigned char tmp;
while((tmp & 0x80))
LCD_RS = 0;
LCD_RW = 0;
LCD_DATA = lcd_cmd;
_nop_();
LCD_EN = 0;
_nop_();
_nop_();
LCD_EN = 1;
unsigned char tmp;
#if 0
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
tmp = LCD_DATA;
LCD_EN = 0;
#endif
LCD_DATA = 0xff;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 0;
_nop_();
_nop_();
LCD_EN = 1;
tmp = LCD_DATA;
return tmp;
unsigned char tmp;
if(y) //若是第二行;
tmp = 0xc0 + x;
LCD_WriteCmd(tmp);
tmp = 0x80 + x;
LCD_WriteCmd(tmp);
if(row)
LCD_Goto(0,1);
LCD_Goto(0,0);
while(*str != '\0')
LCD_WriteDat(*str++);
void Delay20ms() //粗略延時(shí);
unsigned int tmp = 50000;
while(tmp--);
/*2、DS18B2模塊*/
void delay_18B20(unsigned int i)
while(i--);
/**********ds18b20初始化函數(shù)**********************/
void Init_DS18B20(void)
unsigned char x=0;
DQ = 1; //DQ復(fù)位
delay_18B20(2); //稍做延時(shí)
DQ = 0; //單片機(jī)將DQ拉低
delay_18B20(60); //精確延時(shí) 大于 480us
DQ = 1; //拉高總線(xiàn)
delay_18B20(2);
x=DQ; //稍做延時(shí)后 如果x=0則初始化成功 x=1則初始化失敗
delay_18B20(15);
/***********ds18b20讀一個(gè)字節(jié)**************/
unsigned char ReadOneChar(void)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
DQ = 0; // 給脈沖信號(hào)
dat>>=1;
DQ = 1; // 給脈沖信號(hào)
if(DQ)
dat |=0x80;
delay_18B20(4);
return(dat);
/*************ds18b20寫(xiě)一個(gè)字節(jié)****************/
void WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
delay_18B20(2);
DQ = 1;
dat>>=1;
void ReadTemperature(void)
{unsigned char readdata[2]={0,0};
fuhao=0;
temperature=0;
delay_18B20(40); // this message is very important
Init_DS18B20();
WriteOneChar(0xCC); // 跳過(guò)讀序號(hào)列號(hào)的操作
WriteOneChar(0x44); // 啟動(dòng)溫度轉(zhuǎn)換
delay_18B20(40); // this message is wery important
Init_DS18B20();
WriteOneChar(0xCC); //跳過(guò)讀序號(hào)列號(hào)的操作
WriteOneChar(0xBE); //讀取溫度寄存器等(共可讀9個(gè)寄存器) 前兩個(gè)就是溫度
delay_18B20(40);
readdata[0]=ReadOneChar(); //讀取溫度值低位
readdata[1]=ReadOneChar(); //讀取溫度值高位
if (readdata[1]>127)
{readdata[0]^=0xff;//求補(bǔ)碼
readdata[1]^=0xff;
fuhao=1;//符號(hào)為“-”
temperature =readdata[1]*256+readdata[0] ;
temperature =temperature*0.625+0.5 ;//放大了10倍
void timer0() interrupt 1 //這里輸出蜂鳴器信號(hào)
{TH0=254;//頻率為1600hz時(shí)計(jì)時(shí)器初值
TL0=200;
speaker=!speaker;
{unsigned char DEN=0;
LCD_Init();//初始化LCD
/*計(jì)時(shí)器0設(shè)置*/
TMOD=0x11;//定時(shí)器1、2工作于方式1
TL0=200;
ET0=1;
EA=1;
speaker=1;
/*LCD第一行顯示溫度*/
ReadTemperature();//讀取溫度值
if (fuhao)
{dispBuff0[5]='-';}
{dispBuff0[5]='+';}
dispBuff0[6]=(temperature/1000)%10+'0';//溫度值百位
dispBuff0[7]=(temperature/100)%10+'0';//溫度值十位
dispBuff0[8]=(temperature/10)%10+'0';//溫度值個(gè)位
dispBuff0[9]='.';
dispBuff0[10]=(temperature)%10+'0';//溫度值小數(shù)點(diǎn)后一位;
/*報(bào)警程序*/
if (temperature>=330 && !fuhao)//溫度大于40攝氏度
{LED1=on;}
{LED1=off;}
if (temperature>=330 && !fuhao)//響蜂鳴器
{TR0=1;}
{TR0=0;}
}//while
}//main
