查看: 2117|回復: 1
51單片機無法接受as608指紋模塊 求幫助
ID:354697 發表于 2019-5-14 17:34 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
附上自己做的握手程序
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. uchar receive_LY[6];
  5. uchar FPM10A_RECEICE_BUFFER[32];
  6. //code uchar FPM10A_Get_Device[10] ={0x01,0x00,0x07,0x13,0x00,0x00,0x00,0x00,0x00,0x1b};//驗證口令
  7. //code uchar FPM10A_Pack_Head[6] = {0xEF,0x01,0xFF,0xFF,0xFF,0xFF};  //包頭協議
  8. void delay(uint x)
  9. {
  10. uint i,j;
  11. while(--x)
  12. {
  13. for(i=0;i<110;i++)
  14.   for(j=0;j<110;j++);
  15.   }
  16. }
  17. void Uart_Send_Byte()  //發送握手口令,一個一個發送,簡單粗暴
  18. {
  19. SBUF = 0xef;
  20. while(!TI);
  21. TI = 0;
  22. SBUF = 0x01;
  23. while(!TI);
  24. TI = 0;
  25. SBUF = 0xff;
  26. while(!TI);
  27. TI = 0;
  28. SBUF = 0xff;
  29. while(!TI);
  30. TI = 0;
  31. SBUF = 0xff;
  32. while(!TI);
  33. TI = 0;
  34. SBUF = 0xff;
  35. while(!TI);
  36. TI = 0;
  37. SBUF = 0x01;
  38. while(!TI);
  39. TI = 0;
  40. SBUF = 0x00;
  41. while(!TI);
  42. TI = 0;
  43. SBUF = 0x07;
  44. while(!TI);
  45. TI = 0;
  46. SBUF = 0x13;
  47. while(!TI);
  48. TI = 0;
  49. SBUF = 0x00;
  50. while(!TI);
  51. TI = 0;
  52. SBUF = 0x00;
  53. while(!TI);
  54. TI = 0;
  55. SBUF = 0x00;
  56. while(!TI);
  57. TI = 0;
  58. SBUF = 0x00;
  59. while(!TI);
  60. TI = 0;
  61. SBUF = 0x00;
  62. while(!TI);
  63. TI = 0;
  64. SBUF = 0x1b;
  65. while(!TI);
  66. TI = 0;
  67. }
  68. void jieshou(uchar x)
  69. {
  70. uchar i;
  71. for(i=0;i<x;i++)
  72. {
  73. while(!RI);
  74. RI=0;
  75. receive_LY[i]=SBUF;
  76. }
  77. }
  78. void liangdeng()//如果接受到,將會把接收到的指令轉換為P1口的燈光顯示。可事實上啥都不亮 0_0
  79. {
  80. uchar i;
  81. for(i=0;i<12;i++)
  82. {
  83. P1=FPM10A_RECEICE_BUFFER[i];
  84. delay(5000);
  85. P1=0xff;
  86. }
  87. }
  88. void main()
  89. {
  90. SCON=0x50;
  91. TMOD=0x20;
  92. PCON=0x00;
  93. EA=1;
  94. TR1=1;
  95. TH1=0xFD;
  96. TL1=0xFD;
  97. Uart_Send_Byte();
  98. while(1)
  99. {
  100.    jieshou(12);
  101.    liangdeng();
  102. }
  103. }
////51單片機與as608的問題屢見不鮮,求指導。
ID:718485 發表于 2020-5-3 22:00 來自觸屏版 | 只看該作者
樓主,你好,我也遇到這種問題了,請問你解決這個問題了么?
