基于一下內容:
STM32F103VET6
STM32Cube MX
Keil 5
用LED做一個基本功能的實現,主函數如下:
- int main(void)
- /* USER CODE BEGIN 1 */
- OS_ERR err;
- /* USER CODE END 1 */
- /* MCU Configuration----------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* Configure the system clock */
- SystemClock_Config();
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- /* USER CODE BEGIN 2 */
- CPU_Init();
- OSInit(&err);
- OSTaskCreate((OS_TCB *)&MyTaskTCB,
- (CPU_CHAR *)"MyTask",
- (OS_TASK_PTR)&MyTask,
- (void *)0,
- (OS_PRIO) STARTUP_TASK_PRIO,
- (CPU_STK *)&MyTaskStk[0],
- (CPU_STK_SIZE)STARTUP_TASK_STK_SIZE / 10,
- (CPU_STK_SIZE)STARTUP_TASK_STK_SIZE,
- (OS_MSG_QTY)0,
- (OS_TICK)0,
- (void *)0,
- (OS_OPT)(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
- (OS_ERR *)&err);
- OSStart(&err);
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
全部資料51hei下載地址:
STM32F103VET6-HAL-uCOS III.7z
(1.32 MB, 下載次數: 58)
2019-5-14 18:53 上傳
