200黑幣
要做一個(gè)時(shí)鐘電路 有四個(gè)按鈕 k1切換狀態(tài):時(shí)鐘狀態(tài)或者調(diào)時(shí)狀態(tài) k2選擇調(diào)時(shí)調(diào)小時(shí) 分鐘還是秒 k3k4為加減
#include<reg51.h>
#include<intrins.h>
uchar code DSY_CODE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,
0x88,0x83,0xc6,0xa1,0x86,0x8e,0x00,0xbf};
uint a=0,b=0;
uchar shi=0;
uchar shi1=0;
uchar shi2=0;
uchar fen=0;
uchar fen1=0;
uchar fen2=0;
uchar miao=0;
uchar miao1=0;
uchar miao2=0;
uchar set1=1,set2=1;
sbit k1=P1^0;
sbit k2=P1^1;
sbit k3=P1^2;
sbit k4=P1^3;
//延時(shí)
void DelayMS(uint x)
uchar i;
while(x--) for(i=0;i<120;i++);
//顯示程序
void xianshi(shi,fen,miao)
shi=a/3600;
shi1=shi%10;
shi2=shi/10;
fen=(a-shi*3600)/60;
fen1=fen%10;
fen2=fen/10;
miao=a-shi*3600-fen*60;
miao1=miao%10;
miao2=miao/10;
P3=0x80;
P0=DSY_CODE[miao1];
DelayMS(5);
P3=0x00;
P3=0x40;
P0=DSY_CODE[miao2];
DelayMS(5);
P3=0x00;
P3=0x20;
P0=0xbf;
DelayMS(5);
P3=0x00;
P3=0x10;
P0=DSY_CODE[fen1];
DelayMS(5);
P3=0x00;
P3=0x08;
P0=DSY_CODE[fen2];
DelayMS(5);
P3=0x00;
P3=0x04;
P0=0xbf;
DelayMS(5);
P3=0x00;
P3=0x02;
P0=DSY_CODE[shi1];
DelayMS(5);
P3=0x00;
P3=0x01;
P0=DSY_CODE[shi2];
DelayMS(5);
P3=0x00;
uchar jia (uchar n)
if(k3==0)
DelayMS(20);
if(k3==0)
n++;
while(!k3);
return n;
uchar jian (uchar m)
if(k4==0)
DelayMS(20);
if(k4==0)
m++;
while(!k4);
if(m<0)
m=0;
return m;
void one()
if(k1==0)
DelayMS(20);
if(k1==0)
set1++;
while(!k1);
if(set1==3)
set1=1;
void two()
if(k2==0)
DelayMS(20);
if(k2==0)
set2++;
while(!k2);
if(set2==4)
set2=1;
void time()
if(set1==2)
if(set2==1)
shi=jia(shi);
if(shi==24)
shi=0;
if(shi==-1)
shi=23;
shi=jian(shi);
if(set2==2)
fen=jia(fen);
if(fen==60)
fen=0;
if(fen==-1)
fen=59;
fen=jian(fen);
if(set2==3)
miao=jia(miao);
if(miao==60)
miao=0;
if(miao==-1)
miao=59;
miao=jian(miao);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
IE=0x82;
TR0=1;
if(set1==1)
xianshi(shi,fen,miao);
if(set1==2)
one();
two();
time();
void zhongduan() interrupt 1
b++;
if(b==20)
{a++; b=0;}
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
