用RC522模塊使用按鍵輸入密碼解除密碼鎖
- #include <intrins.h>
- #include "STC12C54xx.h"
- #include "mfrc522.h"
- #define MAXRLEN 18
- void Sent_Byte(unsigned char Sdata);
- //功 能:尋卡
- //參數說明: req_code[IN]:尋卡方式
- // 0x52 = 尋感應區內所有符合14443A標準的卡
- // 0x26 = 尋未進入休眠狀態的卡
- // pTagType[OUT]:卡片類型代碼
- // 0x4400 = Mifare_UltraLight
- // 0x0400 = Mifare_One(S50)
- // 0x0200 = Mifare_One(S70)
- // 0x0800 = Mifare_Pro(X)
- // 0x4403 = Mifare_DESFire
- //返 回: 成功返回MI_OK
- char PcdRequest(unsigned char req_code,unsigned char *pTagType)
- char status;
- unsigned int unLen;
- unsigned char ucComMF522Buf[MAXRLEN];
- ClearBitMask(Status2Reg,0x08);
- WriteRawRC(BitFramingReg,0x07);
- SetBitMask(TxControlReg,0x03);
- ucComMF522Buf[0] = req_code;
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,1,ucComMF522Buf,&unLen);
- if ((status == MI_OK) && (unLen == 0x10))
- *pTagType = ucComMF522Buf[0];
- *(pTagType+1) = ucComMF522Buf[1];
- else
- { status = MI_ERR; }
- return status;
- //功 能:防沖撞
- //參數說明: pSnr[OUT]:卡片序列號,4字節
- //返 回: 成功返回MI_OK
- char PcdAnticoll(unsigned char *pSnr)
- char status;
- unsigned char i,snr_check=0;
- WriteRawRC(BitFramingReg,0x00);
- ClearBitMask(CollReg,0x80);
- ucComMF522Buf[0] = PICC_ANTICOLL1;
- ucComMF522Buf[1] = 0x20;
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,2,ucComMF522Buf,&unLen);
- if (status == MI_OK)
- for (i=0; i<4; i++)
- *(pSnr+i) = ucComMF522Buf[i];
- snr_check ^= ucComMF522Buf[i];
- if (snr_check != ucComMF522Buf[i])
- SetBitMask(CollReg,0x80);
- return status;
- //功 能:選定卡片
- //參數說明: pSnr[IN]:卡片序列號,4字節
- //返 回: 成功返回MI_OK
- char PcdSelect(unsigned char *pSnr)
- char status;
- unsigned char i;
- ucComMF522Buf[1] = 0x70;
- ucComMF522Buf[6] = 0;
- ucComMF522Buf[i+2] = *(pSnr+i);
- ucComMF522Buf[6] ^= *(pSnr+i);
- CalulateCRC(ucComMF522Buf,7,&ucComMF522Buf[7]);
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,9,ucComMF522Buf,&unLen);
- if ((status == MI_OK) && (unLen == 0x18))
- { status = MI_OK; }
- else
- return status;
- //功 能:驗證卡片密碼
- //參數說明: auth_mode[IN]: 密碼驗證模式
- // 0x60 = 驗證A密鑰
- // 0x61 = 驗證B密鑰
- // addr[IN]:塊地址
- // pKey[IN]:密碼
- // pSnr[IN]:卡片序列號,4字節
- //返 回: 成功返回MI_OK
- char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
- char status;
- unsigned char i,ucComMF522Buf[MAXRLEN];
- ucComMF522Buf[0] = auth_mode;
- ucComMF522Buf[1] = addr;
- for (i=0; i<6; i++)
- { ucComMF522Buf[i+2] = *(pKey+i); }
- { ucComMF522Buf[i+8] = *(pSnr+i); }
- // memcpy(&ucComMF522Buf[2], pKey, 6);
- // memcpy(&ucComMF522Buf[8], pSnr, 4);
- status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
- if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
- return status;
- //功 能:讀取M1卡一塊數據
- //參數說明: addr[IN]:塊地址
- // pData[OUT]:讀出的數據,16字節
- //返 回: 成功返回MI_OK
- char PcdRead(unsigned char addr,unsigned char *pData)
- char status;
- ucComMF522Buf[0] = PICC_READ;
- CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
- if ((status == MI_OK) && (unLen == 0x90))
- // { memcpy(pData, ucComMF522Buf, 16); }
- for (i=0; i<16; i++)
- { *(pData+i) = ucComMF522Buf[i]; }
- else
- return status;
- //功 能:寫數據到M1卡一塊
- // pData[IN]:寫入的數據,16字節
- //返 回: 成功返回MI_OK
- /*char PcdWrite(unsigned char addr,unsigned char *pData)
- char status;
- ucComMF522Buf[0] = PICC_WRITE;
- if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
- //memcpy(ucComMF522Buf, pData, 16);
- { ucComMF522Buf[i] = *(pData+i); }
- CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
- return status;
- //功 能:扣款和充值
- //參數說明: dd_mode[IN]:命令字
- // 0xC0 = 扣款
- // 0xC1 = 充值
- // addr[IN]:錢包地址
- // pValue[IN]:4字節增(減)值,低位在前
- //返 回: 成功返回MI_OK
- /*char PcdValue(unsigned char dd_mode,unsigned char addr,unsigned char *pValue)
- char status;
- ucComMF522Buf[0] = dd_mode;
- // memcpy(ucComMF522Buf, pValue, 4);
- { ucComMF522Buf[i] = *(pValue+i); }
- CalulateCRC(ucComMF522Buf,4,&ucComMF522Buf[4]);
- unLen = 0;
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,6,ucComMF522Buf,&unLen);
- if (status != MI_ERR)
- ucComMF522Buf[0] = PICC_TRANSFER;
- return status;
- //功 能:備份錢包
- //參數說明: sourceaddr[IN]:源地址
- // goaladdr[IN]:目標地址
- //返 回: 成功返回MI_OK
- /*char PcdBakValue(unsigned char sourceaddr, unsigned char goaladdr)
- char status;
- ucComMF522Buf[0] = PICC_RESTORE;
- ucComMF522Buf[1] = sourceaddr;
- ucComMF522Buf[0] = 0;
- ucComMF522Buf[1] = 0;
- ucComMF522Buf[2] = 0;
- ucComMF522Buf[3] = 0;
- if (status != MI_OK)
- { return MI_ERR; }
- ucComMF522Buf[1] = goaladdr;
- return status;
- //功 能:命令卡片進入休眠狀態
- //返 回: 成功返回MI_OK
- char PcdHalt(void)
- char status;
- ucComMF522Buf[0] = PICC_HALT;
- return MI_OK;
- //用MF522計算CRC16函數
- void CalulateCRC(unsigned char *pIndata,unsigned char len,unsigned char *pOutData)
- unsigned char i,n;
- ClearBitMask(DivIrqReg,0x04);
- WriteRawRC(CommandReg,PCD_IDLE);
- SetBitMask(FIFOLevelReg,0x80);
- for (i=0; i<len; i++)
- { WriteRawRC(FIFODataReg, *(pIndata+i)); }
- WriteRawRC(CommandReg, PCD_CALCCRC);
- i = 0xFF;
- do
- n = ReadRawRC(DivIrqReg);
- i--;
- while ((i!=0) && !(n&0x04));
- pOutData[0] = ReadRawRC(CRCResultRegL);
- pOutData[1] = ReadRawRC(CRCResultRegM);
- //功 能:復位RC522
- //返 回: 成功返回MI_OK
- char PcdReset(void)
- MF522_RST=1;
- _nop_();
- MF522_RST=0;
- _nop_();
- MF522_RST=1;
- _nop_();
- WriteRawRC(CommandReg,PCD_RESETPHASE);
- _nop_();
- WriteRawRC(ModeReg,0x3D); //和Mifare卡通訊,CRC初始值0x6363
- WriteRawRC(TReloadRegL,30);
- WriteRawRC(TReloadRegH,0);
- WriteRawRC(TModeReg,0x8D);
- WriteRawRC(TPrescalerReg,0x3E);
- WriteRawRC(TxAskReg,0x40);
- return MI_OK;
復制代碼 由于Proteus里面是沒有rc522這么高端的玩意的,所以仿真就只是個簡單的模擬,大家直接略過看程序吧
設計.7z
(8.96 MB, 下載次數: 185)
2019-5-17 06:43 上傳
