2019-5-10 15:31 上傳
#include <reg51.h>
#include <intrins.h>
sbit dy_R=P2^0;
sbit dy_Y=P2^1;
sbit dy_G=P2^2;
sbit dy_Z=P2^3;
sbit dx_R=P2^4;
sbit dx_Y=P2^5;
sbit dx_G=P2^6;
sbit dx_Z=P2^7;
sbit led_A=P3^4;//ge
sbit led_B=P3^5;//shi
void Q();
void W();
void E();
void R();
void T();
void Y();
void U();
void I();
uchar N,num,shi,ge;
uchar tab_disp[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6f};
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void display(char shi,char ge)
led_A=0;
P1=tab_disp[shi];
if(shi)led_B=1;
delay(50);
led_B=0;
P1=tab_disp[ge];
led_A=1;
delay(50);
TMOD = 0x01;
TH0 = (65536 - 45872) / 256;
TL0 = (65536 - 45872) % 256;
EA = 1;
ET0 = 1;
TR0 =1;
Q();
W();
E();
R();
T();
Y();
U();
I();
void Q()
uint N;
N=60;
while(N<=60&&N>0)
if(num==20)
num=0;
shi=N/10;
ge=N%10;
N--;
display(shi,ge);
dx_R=0;dx_Y=0;dx_G=1;dx_Z=0;
dy_R=1;dy_Y=0;dy_G=0;dy_Z=0;
void W()
uint N;
N=5;
while(N<=5&&N>0)
if(num==20)
num=0;
shi=N/10;
ge=N%10;
N--;
display(shi,ge);
dx_R=0;dx_Y=1;dx_G=0;dx_Z=0;
dy_R=0;dy_Y=1;dy_G=0;dy_Z=0;
delay(50);
dx_Y=1;dy_Y=1;
delay(50);
dx_Y=0;dy_Y=0;
void E()
uint N;
N=20;
while(N<=20&&N>0)
if(num==20)
num=0;
shi=N/10;
ge=N%10;
N--;
display(shi,ge);
dx_R=0;dx_Y=0;dx_G=0;dx_Z=1;
void R()
uint N;
N=5;
while(N<=5&&N>0)
if(num==20)
num=0;
shi=N/10;
ge=N%10;
N--;
display(shi,ge);
delay(50);
dx_Y=1;dy_Y=1;
delay(50);
dx_Y=0;dy_Y=0;
void T()
uint N;
N=60;
while(N<=60&&N>0)
if(num==20)
num=0;
shi=N/10;
ge=N%10;
N--;
display(shi,ge);
dx_R=1;dx_Y=0;dx_G=0;dx_Z=0;
dy_R=0;dy_Y=0;dy_G=1;dy_Z=0;
void Y()
uint N;
N=5;
while(N<=5&&N>0)
if(num==20)
num=0;
shi=N/10;
ge=N%10;
N--;
display(shi,ge);
delay(50);
dx_Y=1;dy_Y=1;
delay(50);
dx_Y=0;dy_Y=0;
void U()
uint N;
N=20;
while(N<=20&&N>0)
if(num==20)
num=0;
shi=N/10;
ge=N%10;
N--;
display(shi,ge);
dy_R=0;dy_Y=0;dy_G=1;dy_Z=1;
void I()
uint N;
N=5;
while(N<=5&&N>0)
if(num==20)
num=0;
shi=N/10;
ge=N%10;
N--;
display(shi,ge);
delay(50);
dx_Y=1;dy_Y=1;
delay(50);
dx_Y=0;dy_Y=0;
void time_() interrupt 1
num++;
