只需一步,快速開(kāi)始
查看: 3144|回復(fù): 1
基于51單片機(jī)的TFT1.8彩屏字符顯示功能
ID:517871 發(fā)表于 2019-5-9 19:28 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<absacc.h>
#include<intrins.h>
#include<string.h>
sbit LCD_RST       =        P0^3;
sbit LCD_RS        =        P0^4;
sbit LCD_SDA       =        P0^5;
sbit LCD_SCL       =        P0^6;
sbit LCD_CS        =        P0^7;
uchar bdata bitdata;
sbit bit7=bitdata^7;
sbit bit6=bitdata^6;
sbit bit5=bitdata^5;
sbit bit4=bitdata^4;
sbit bit3=bitdata^3;
sbit bit2=bitdata^2;
sbit bit1=bitdata^1;
sbit bit0=bitdata^0;
uchar code Zk_ASCII8X16[]=
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x18,0x08,0xc8,0x08,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x7f,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60,0xe0,
  0x60,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x18,0x10,
  0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x08,0x0c,0x0c,0x0c,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x6c,0x38,0x10,0x00,0x7c,0xc6,0x70,0x1c,
  0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x38,0x6c,0x00,0x78,
  0x0c,0x7c,0xcc,0xcc,0x76,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x7c,0xc6,0x70,0xc0,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x6c,0x96,0x7c,0xd0,0xd6,0x6c,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0x06,0x06,0xc6,
  0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x6c,0xc6,0xc6,0xfe,
  0xc6,0xc6,0x6c,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x10,0x38,0x28,0x6c,0x44,0xc6,0xc6,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x7c,0xc6,0x06,0xfe,0xc6,0x7c,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xdc,0x66,0x66,0x66,0xf6,0x06,
  0x06,0x66,0x3c,0x00,0x00,0x00,0x00,0x6c,0x38,0xf8,0x0c,0x7e,0xc6,
  0xc6,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0e,0x1b,0x18,
  0x18,0x18,0x18,0x18,0x18,0x18,0xd8,0x70,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0xfe,0x86,0x0c,0x18,0x0c,0x06,0x06,0xc6,0x7c,0x00,0x00,
  0x00,0x00,0x76,0xdc,0x00,0x00,0x78,0x0c,0x7c,0xcc,0xcc,0x76,0x00,
  0x00,0x00,0x00,0x00,0x00,0x76,0xdc,0x00,0x00,0x7c,0xc6,0x06,0x06,
  0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x76,0xdc,0x00,0x00,0xdc,
  0x66,0x66,0x66,0x66,0x66,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x76,0x99,0x9f,0x98,0x99,0x6f,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0c,0x06,0x06,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,
  0x66,0x66,0x3c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x3c,
  0x3c,0x3c,0x18,0x18,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,
  0xc6,0xc6,0xc6,0x44,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x6c,0x6c,0xfe,0x6c,0x6c,0x6c,0xfe,0x6c,0x6c,
  0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x7c,0xc6,0xc2,0xc0,0x7c,0x06,
  0x86,0xc6,0x7c,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,
  0xc6,0x0c,0x18,0x30,0x63,0xc3,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x38,0x6c,0x6c,0x38,0x76,0xdc,0xcc,0xcc,0x76,0x00,0x00,0x00,0x00,
  0x00,0x00,0x30,0x30,0x30,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x30,0x60,0x60,0x60,0x60,0x60,
  0x30,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x0c,0x06,0x06,
  0x06,0x06,0x06,0x0c,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x6c,0x38,0xfe,0x38,0x6c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x18,0x18,0x18,0x7e,0x18,0x18,0x18,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,
  0x18,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,
  0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x02,0x06,0x0c,0x18,0x30,0x60,0xc0,0x80,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x7c,0xc6,0xce,0xde,0xf6,0xe6,0xc6,0xc6,0x7c,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x38,0x78,0x18,0x18,0x18,
  0x18,0x18,0x7e,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0x06,
  0x0c,0x18,0x30,0x60,0xc6,0xfe,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x7c,0xc6,0x06,0x06,0x3c,0x06,0x06,0xc6,0x7c,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x0c,0x1c,0x3c,0x6c,0xcc,0xfe,0x0c,0x0c,0x1e,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0xfe,0xc0,0xc0,0xc0,0xfc,0x06,0x06,
  0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x60,0xc0,0xc0,
  0xfc,0xc6,0xc6,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,
  0xc6,0x06,0x0c,0x18,0x30,0x30,0x30,0x30,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x7c,0xc6,0xc6,0xc6,0x7c,0xc6,0xc6,0xc6,0x7c,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0xc6,0xc6,0x7e,0x06,0x06,0x0c,
  0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,
  0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,
  0x18,0x00,0x00,0x00,0x18,0x18,0x30,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x06,0x0c,0x18,0x30,0x60,0x30,0x18,0x0c,0x06,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7e,0x00,0x00,0x7e,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x30,0x18,0x0c,0x06,0x0c,
  0x18,0x30,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0xc6,
  0x0c,0x18,0x18,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x7c,0xc6,0xc6,0xde,0xde,0xde,0xdc,0xc0,0x7c,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x10,0x38,0x6c,0xc6,0xc6,0xfe,0xc6,0xc6,0xc6,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0xfc,0x66,0x66,0x66,0x7c,0x66,0x66,
  0x66,0xfc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,0x66,0xc2,0xc0,
  0xc0,0xc0,0xc2,0x66,0x3c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf8,
  0x6c,0x66,0x66,0x66,0x66,0x66,0x6c,0xf8,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0xfe,0x66,0x62,0x68,0x78,0x68,0x62,0x66,0xfe,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0xfe,0x66,0x62,0x68,0x78,0x68,0x60,0x60,
  0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,0x66,0xc2,0xc0,0xc0,
  0xde,0xc6,0x66,0x3a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,
  0xc6,0xc6,0xfe,0xc6,0xc6,0xc6,0xc6,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x3c,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x3c,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x1e,0x0c,0x0c,0x0c,0x0c,0x0c,0xcc,0xcc,0x78,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe6,0x66,0x6c,0x6c,0x78,0x6c,
  0x6c,0x66,0xe6,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf0,0x60,0x60,
  0x60,0x60,0x60,0x62,0x66,0xfe,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0xc6,0xee,0xfe,0xd6,0xc6,0xc6,0xc6,0xc6,0xc6,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0xc6,0xe6,0xf6,0xfe,0xde,0xce,0xc6,0xc6,0xc6,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x6c,0xc6,0xc6,0xc6,0xc6,0xc6,
  0x6c,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfc,0x66,0x66,0x66,
  0x7c,0x60,0x60,0x60,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,
  0xc6,0xc6,0xc6,0xd6,0xde,0x7c,0x0c,0x0e,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0xfc,0x66,0x66,0x66,0x7c,0x6c,0x66,0x66,0xe6,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0xc6,0x60,0x38,0x0c,0xc6,0xc6,
  0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7e,0x5a,0x18,0x18,0x18,
  0x18,0x18,0x18,0x3c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,
  0xc6,0xc6,0xc6,0xc6,0xc6,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0xc6,0xc6,0xc6,0xc6,0xc6,0xc6,0x6c,0x38,0x10,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0xc6,0xc6,0xc6,0xc6,0xc6,0xd6,0xfe,0xee,0xc6,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,0xc6,0x6c,0x38,0x6c,
  0xc6,0xc6,0xc6,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,0xc6,
  0x6c,0x38,0x38,0x38,0x38,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0xfe,0xc6,0x8c,0x18,0x30,0x60,0xc2,0xc6,0xfe,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x3c,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x3c,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xc0,0xe0,0x70,0x38,0x1c,0x0e,
  0x06,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3c,0x0c,0x0c,0x0c,
  0x0c,0x0c,0x0c,0x0c,0x3c,0x00,0x00,0x00,0x00,0x00,0x10,0x38,0x6c,
  0xc6,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,
  0x00,0x00,0x00,0x00,0x30,0x30,0x18,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,0x0c,
  0x7c,0xcc,0xcc,0x76,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe0,0x60,
  0x60,0x78,0x6c,0x66,0x66,0x66,0xdc,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x7c,0xc6,0xc0,0xc0,0xc6,0x7c,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x1c,0x0c,0x0c,0x3c,0x6c,0xcc,0xcc,0xcc,0x76,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7c,0xc6,0xfe,
  0xc0,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1c,0x36,0x32,
  0x30,0x7c,0x30,0x30,0x30,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x76,0xcc,0xcc,0xcc,0x7c,0x0c,0xcc,0x78,0x00,0x00,
  0x00,0x00,0x00,0xe0,0x60,0x60,0x6c,0x76,0x66,0x66,0x66,0xe6,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x38,0x18,0x18,0x18,
  0x18,0x3c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x06,0x00,0x0e,
  0x06,0x06,0x06,0x06,0x66,0x66,0x3c,0x00,0x00,0x00,0x00,0x00,0xe0,
  0x60,0x60,0x66,0x6c,0x78,0x6c,0x66,0xe6,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x38,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x3c,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x44,0xfe,0xd6,0xd6,0xd6,
  0xd6,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xdc,0x66,
  0x66,0x66,0x66,0x66,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x7c,0xc6,0xc6,0xc6,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0xdc,0x66,0x66,0x66,0x7c,0x60,0x60,0xf0,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x76,0xcc,0xcc,0xcc,0x7c,0x0c,
  0x0c,0x1e,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xdc,0x76,0x66,
  0x60,0x60,0xf0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x7c,0xc6,0x70,0x1c,0xc6,0x7c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x10,0x30,0x30,0xfc,0x30,0x30,0x30,0x36,0x1c,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0xcc,0xcc,0xcc,0xcc,0xcc,0x76,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,0xc6,0x6c,
  0x38,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc6,
  0xc6,0xc6,0xd6,0xfe,0x6c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0xc6,0x6c,0x38,0x38,0x6c,0xc6,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0xc6,0xc6,0xc6,0xc6,0x7e,0x06,0x0c,0x78,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xfe,0xcc,0x18,0x30,0x66,
  0xfe,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0e,0x18,0x18,0x18,0x70,
  0x18,0x18,0x18,0x0e,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,
  0x18,0x18,0x00,0x18,0x18,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x70,0x18,0x18,0x18,0x0e,0x18,0x18,0x18,0x70,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x76,0xdc,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00
void delay(uint time)
uint i,j;
  for(i=0;i<time;i++)
   for(j=0;j<250;j++);
void delayms(uchar x)    //x*0.14MS
uchar i;
  while(x--)
  for (i = 0; i<10; i++) {}
void LCD_CtrlWrite_IC(uchar c)
bitdata=c;
LCD_CS=0;
LCD_RS=0;
LCD_SDA=bit7;LCD_SCL=0;LCD_SCL=1;
LCD_SDA=bit6;LCD_SCL=0;LCD_SCL=1;
LCD_SDA=bit5;LCD_SCL=0;LCD_SCL=1;
LCD_SDA=bit4;LCD_SCL=0;LCD_SCL=1;
LCD_SDA=bit3;LCD_SCL=0;LCD_SCL=1;
LCD_SDA=bit2;LCD_SCL=0;LCD_SCL=1;
LCD_SDA=bit1;LCD_SCL=0;LCD_SCL=1;
LCD_SDA=bit0;LCD_SCL=0;LCD_SCL=1;
LCD_CS=1;
void  LCD_DataWrite_IC(uchar d)
bitdata=d;
LCD_CS=0;
LCD_RS=1;
LCD_CS=1;
void LCD_DataWrite(uint LCD_Data)
LCD_DataWrite_IC(LCD_Data>>8);
LCD_DataWrite_IC(LCD_Data);
void Write_COM(uchar c)
bitdata=c;
LCD_CS=0;
LCD_RS=0;
LCD_CS=1;
void Write_DATA(uchar d)
bitdata=d;
LCD_CS=0;
LCD_RS=1;
LCD_CS=1;
void reset()
        LCD_RST=1;
    delay(100);
    LCD_RST=0;
    delay(100);
    LCD_RST=1;
    delay(100);
void lcd_initial()
  reset();
//--------------------------------End ST7735R LCD_RST Sequence --------------------------------------//
Write_COM(0x11); //Sleep out
delayms (120); //Delay 120ms
//------------------------------------ST7735R Frame Rate-----------------------------------------//
Write_COM(0xB1);
Write_DATA(0x01);  //01
Write_DATA(0x2C);
Write_DATA(0x2D);
Write_COM(0xB2);
Write_DATA(0x2C);
Write_DATA(0x2D);
Write_COM(0xB3);
Write_DATA(0x2C);
Write_DATA(0x2D);
Write_DATA(0x01);
Write_DATA(0x2C);
Write_DATA(0x2D);
//------------------------------------End ST7735R Frame Rate-----------------------------------------//
Write_COM(0xB4); //Column inveLCD_RSion
Write_DATA(0x03);  //0x07
Write_COM(0xB6);   //
Write_DATA(0xB4); //
Write_DATA(0xF0); //
//------------------------------------ST7735R Power Sequence-----------------------------------------//
Write_COM(0xC0);
Write_DATA(0xA2);
Write_DATA(0x02);
Write_DATA(0x84);
Write_COM(0xC1);
Write_DATA(0xC5);
Write_COM(0xC2);
Write_DATA(0x0A);
Write_DATA(0x00);
Write_COM(0xC3);
Write_DATA(0x8A);
Write_DATA(0x2A);
Write_COM(0xC4);
Write_DATA(0x8A);
Write_DATA(0xEE);
//---------------------------------End ST7735R Power Sequence-------------------------------------//
Write_COM(0xC5); //VCOM
Write_DATA(0x0A);   //0x0E
Write_COM(0x36); //MX, MY, RGB mode
Write_DATA(0xC8);   //0x68
//------------------------------------ST7735R Gamma Sequence-----------------------------------------//
Write_COM(0xe0);
Write_DATA(0x02);
Write_DATA(0x1c);
Write_DATA(0x07);
Write_DATA(0x12);
Write_DATA(0x37);
Write_DATA(0x32);
Write_DATA(0x29);
Write_DATA(0x2d);
Write_DATA(0x29);
Write_DATA(0x25);
Write_DATA(0x2b);
Write_DATA(0x39);
Write_DATA(0x00);
Write_DATA(0x01);
Write_DATA(0x03);
Write_DATA(0x10);
Write_COM(0xe1);
Write_DATA(0x03);
Write_DATA(0x1d);
Write_DATA(0x07);
Write_DATA(0x06);
Write_DATA(0x2e);
Write_DATA(0x2c);
Write_DATA(0x29);
Write_DATA(0x2d);
Write_DATA(0x2e);
Write_DATA(0x2e);
Write_DATA(0x37);
Write_DATA(0x3f);
Write_DATA(0x00);
Write_DATA(0x00);
Write_DATA(0x02);
Write_DATA(0x10);
//------------------------------------End ST7735R Gamma Sequence-----------------------------------------//
Write_COM(0x2a);
Write_DATA(0x00);
Write_DATA(0x00);
Write_DATA(0x00);
Write_DATA(0x7f);
   Write_COM(0x2b);
   Write_DATA(0x00);
   Write_DATA(0x00);
   Write_DATA(0x00);
   Write_DATA(0x9f);
Write_COM(0xF0); //Enable test command
Write_DATA(0x01);
Write_COM(0xF6); //Disable ram power save mode
Write_DATA(0x00);
Write_COM(0x3A); //65k mode
Write_DATA(0x05);
Write_COM(0x29); //Display on
    delay(120);
void dsp_single_colour(uint DHL)
uchar i,j;
//RamAdressSet();
for (i=0;i<160;i++)
    for (j=0;j<128;j++)
        LCD_DataWrite(DHL);
void  RamAdressSet()
   Write_COM(0x2A);
   Write_DATA(0x00);
   Write_DATA(0x02);
   Write_DATA(0x00);
   Write_DATA(0x81);
   Write_COM(0x2B);
   Write_DATA(0x00);
   Write_DATA(0x01);
   Write_DATA(0x00);
   Write_DATA(0xA0);
void Output_Pixel(uint x,uint y)
    LCD_CtrlWrite_IC(0x2A);  //Column Address Set        ****
        LCD_DataWrite_IC(x);//xsh
        LCD_DataWrite_IC(x);//xsl
        LCD_CtrlWrite_IC(0x2B);//Row Address Set             ****
        LCD_DataWrite_IC(y);//ysl
        LCD_CtrlWrite_IC(0x2c);
        LCD_DataWrite(0xf800);
    RamAdressSet();
void Display_ASCII8X16(uint x0,uint y0,uchar *s)
        int i,j,k,x,y,xx;
        unsigned char qm;
        long int ulOffset;
        char  ywbuf[32],temp[2];
        for(i = 0; i<strlen((char*)s);i++)
                if(((unsigned char)(*(s+i))) >= 161)
                        temp[0] = *(s+i);
                        temp[1] = '\0';
                        return;
                        qm = *(s+i);
                        ulOffset = (long int)(qm) * 16;
            for (j = 0; j < 16; j ++)
                                ywbuf[j]=Zk_ASCII8X16[ulOffset+j];
            for(y = 0;y < 16;y++)
                          for(x=0;x<8;x++)
                        k=x % 8;
                                          if(ywbuf[y]&(0x80 >> k))
                                                  xx=x0+x+i*8;
                                            Output_Pixel(xx,y+y0);
void Display_Desc()
        Display_ASCII8X16(1,28,"bstmcu.taobao");
        Display_ASCII8X16(1,40,"hello world");
    Display_ASCII8X16(1,52,"MD:T18008");
    Display_ASCII8X16(1,64,"Pro:T4528B00");
    Display_ASCII8X16(1,76,"Dots:128*160");
    Display_ASCII8X16(1,88,"IC: ST7735B");
    Display_ASCII8X16(1,100,"VA:6 o'clock");
    Display_ASCII8X16(1,112,"2012.08.16");
main()
lcd_initial();
Write_COM(0x2C);
    dsp_single_colour(0xffff);
    Display_Desc();         //版本
    delay(500);
基于51單片機(jī)的TFT1.8彩屏字符顯示功能.zip
34.88 KB, 下載次數(shù): 49, 下載積分: 黑幣 -5
ID:715591 發(fā)表于 2020-4-28 17:32 | 顯示全部樓層
剛好有需求,下載來(lái)試試
